S32DS RTD3.0.0 IDE tool stuck problem
BillWen
Hi :
I have a question is that S32DS IDE tool very lag every time I change each component or variable on mex file.
Is there any auto generate code or related config of S32DS IDE tool that I can close it?
For example, I just want move the sequence of can hardware object, but it will stuck for a while every time I move a step. It is really bother me.
BR, BillWen
Robin_Shen
Hi BillWen,
The S32K3 RTD 3.0.0 was released many years ago.
We always recommend that customers use the latest RFP-quality S32K3 RTD and the S32DS version mentioned in its release note.
This issue has been fixed in S32DS v3.5 Update 12.
Robin
- If this post answers your question, please click the "ACCEPT AS SOLUTION" button. Thank you!
Robin_Shen
Hi BillWen,
Robin
BillWen
Hi Robin_Shen:
Thanks for your reply.
My software environment is S32DS 3.5 and RTD 3.0.0, do yo mean that I need update S32DS from version 3.5 to 3.6?
BR, BillWen
Robin_Shen
This issue was fixed in S32DS Update 12 and later. It is recommended to update to a later version.
You can choose to update online: Open S32DS Extensions and Updates and update the S32 Design Studio Platform Package and S32 Design Studio Platform Tools Package.
Or download an offline update package, such as S32DS Update 12(SW32_S32DS_3.5.12_D2405.zip).
Or extend JVM memory. Go to similar location  C:\NXP\S32DS.3.5\eclipse\s32ds.ini and increase -Xmx parameter to 8Gb.
BillWen
Hi @Robin_Shen :
I already updated to 3.5.14 but still very slow, and I also change the Xmx to 12G, it seems same.
Do you have other suggestion? Or I should use S32DS 3.6 version?
BR, BillWen
Robin_Shen
I suggest you install S32DSv3.6.1 + S32K3 RTD 6.0.0, and then check if the performance of configuring peripherals in the MCAL project improves.
BillWen
Hi @Robin_Shen :
Can I use S32DSv3.6.1 + S32K3 RTD 3.0.0? Is it possible? Because we develop BMS based on RTD3.0.0, if we change to RTD6.0.0 need much effort to do. Temporarily, we want to focus on other implementation.
BR, BillWen
Robin_Shen
Since I haven't done this before, I can't guarantee there won't be any problems. Please contact me if you encounter any issues during installation.
%3CLINGO-SUB%20id%3D%22lingo-sub-2204061%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32DS%20RTD3.0.0%20IDE%20tool%20stuck%20problem%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2204061%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20%3A%3C%2FP%3E%3CP%3EI%20have%20a%20question%20is%20that%20S32DS%20IDE%20tool%20very%20lag%20every%20time%20I%20change%20each%20component%20or%20variable%20on%20mex%20file.%3C%2FP%3E%3CP%3EIs%20there%20any%20auto%20generate%20code%20or%20related%20config%20of%20S32DS%20IDE%20tool%20that%20I%20can%20close%20it%3F%3C%2FP%3E%3CP%3EFor%20example%2C%20I%20just%20want%20move%20the%20sequence%20of%20can%20hardware%20object%2C%20but%20it%20will%20stuck%20for%20a%20while%20every%20time%20I%20move%20a%20step.%20It%20is%20really%20bother%20me.%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22BillWen_0-1763003762143.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22BillWen_0-1763003762143.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F365402i6E1FE37305D88997%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22BillWen_0-1763003762143.png%22%20alt%3D%22BillWen_0-1763003762143.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EThanks%3C%2FP%3E%3CP%3EBR%2C%20BillWen%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2205757%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32DS%20RTD3.0.0%20IDE%20tool%20stuck%20problem%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2205757%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ESince%20I%20haven't%20done%20this%20before%2C%20I%20can't%20guarantee%20there%20won't%20be%20any%20problems.%20Please%20contact%20me%20if%20you%20encounter%20any%20issues%20during%20installation.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2205753%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32DS%20RTD3.0.0%20IDE%20tool%20stuck%20problem%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2205753%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EHi%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F57959%22%20target%3D%22_blank%22%3E%40Robin_Shen%3C%2FA%3E%20%3A%3CBR%20%2F%3EThanks%20for%20your%20reply.%3CBR%20%2F%3ECan%20I%20use%20S32DSv3.6.1%20%2B%20S32K3%20RTD%203.0.0%3F%20Is%20it%20possible%3F%20Because%20we%20develop%20BMS%20based%20on%20RTD3.0.0%2C%20if%20we%20change%20to%20RTD6.0.0%20need%20much%20effort%20to%20do.%20Temporarily%2C%20we%20want%20to%20focus%20on%20other%20implementation.%3CBR%20%2F%3E%3CBR%20%2F%3EThanks%3CBR%20%2F%3EBR%2C%20BillWen%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2205683%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32DS%20RTD3.0.0%20IDE%20tool%20stuck%20problem%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2205683%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20suggest%20you%20install%20S32DSv3.6.1%20%2B%20S32K3%20RTD%206.0.0%2C%20and%20then%20check%20if%20the%20performance%20of%20configuring%20peripherals%20in%20the%20MCAL%20project%20improves.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2205671%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32DS%20RTD3.0.0%20IDE%20tool%20stuck%20problem%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2205671%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F57959%22%20target%3D%22_blank%22%3E%40Robin_Shen%3C%2FA%3E%26nbsp%3B%3A%3C%2FP%3E%3CP%3EI%20already%20updated%20to%203.5.14%20but%20still%20very%20slow%2C%20and%20I%20also%20change%20the%26nbsp%3BXmx%20to%2012G%2C%20it%20seems%20same.%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22BillWen_0-1763345083821.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22BillWen_0-1763345083821.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F365790iDF1886CED02363B4%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22BillWen_0-1763345083821.png%22%20alt%3D%22BillWen_0-1763345083821.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EDo%20you%20have%20other%20suggestion%3F%20Or%20I%20should%20use%20S32DS%203.6%20version%3F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EThanks%3C%2FP%3E%3CP%3EBR%2C%20BillWen%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2204918%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32DS%20RTD3.0.0%20IDE%20tool%20stuck%20problem%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2204918%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThis%20issue%20was%20fixed%20in%20S32DS%20Update%2012%20and%20later.%20It%20is%20recommended%20to%20update%20to%20a%20later%20version.%3C%2FP%3E%0A%3CP%3EYou%20can%20choose%20to%20update%20online%3A%20Open%20%3CSTRONG%3ES32DS%20Extensions%20and%20Updates%3C%2FSTRONG%3E%20and%20update%20the%20%3CSTRONG%3ES32%20Design%20Studio%20Platform%20Package%3C%2FSTRONG%3E%20and%20%3CSTRONG%3ES32%20Design%20Studio%20Platform%20Tools%20Package%3C%2FSTRONG%3E.%3C%2FP%3E%0A%3CP%3EOr%20download%20an%20offline%20update%20package%2C%20such%20as%20S32DS%20Update%2012(%3CSTRONG%3ESW32_S32DS_3.5.12_D2405.zip%3C%2FSTRONG%3E).%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EOr%20extend%20JVM%20memory.%20Go%20to%20similar%20location%26nbsp%3B%20C%3A%5CNXP%5CS32DS.3.5%5Ceclipse%5Cs32ds.ini%20and%20increase%20-Xmx%20parameter%20to%208Gb.%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2204904%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32DS%20RTD3.0.0%20IDE%20tool%20stuck%20problem%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2204904%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EHi%20Robin_Shen%3A%3CBR%20%2F%3EThanks%20for%20your%20reply.%3CBR%20%2F%3EMy%20software%20environment%20is%20S32DS%203.5%20and%20RTD%203.0.0%2C%20do%20yo%20mean%20that%20I%20need%20update%20S32DS%20from%20version%203.5%20to%203.6%3F%3CBR%20%2F%3E%3CBR%20%2F%3EThanks%3CBR%20%2F%3EBR%2C%20BillWen%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2204233%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32DS%20RTD3.0.0%20IDE%20tool%20stuck%20problem%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2204233%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CSPAN%3EBillWen%2C%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EThe%20S32K3%20RTD%203.0.0%20was%20released%20many%20years%20ago.%3C%2FP%3E%0A%3CP%3EWe%20always%20recommend%20that%20customers%20use%20the%20latest%20RFP-quality%20S32K3%20RTD%20and%20the%20S32DS%20version%20mentioned%20in%20its%20release%20note.%3C%2FP%3E%0A%3CP%3EThis%20issue%20has%20been%20fixed%20in%20S32DS%20v3.5%20Update%2012.%3C%2FP%3E%0A%3CP%3EBest%20Regards%2C%3CBR%20%2F%3ERobin%3CBR%20%2F%3E-------------------------------------------------------------------------------%3CBR%20%2F%3ENote%3A%3CBR%20%2F%3E-%20If%20this%20post%20answers%20your%20question%2C%20please%20click%20the%20%22ACCEPT%20AS%20SOLUTION%22%20button.%20Thank%20you!%3C%2FP%3E%0A%3CP%3E-%20We%20are%20following%20threads%20for%207%20weeks%20after%20the%20last%20post%2C%20later%20replies%20are%20ignored%3CBR%20%2F%3EPlease%20open%20a%20new%20thread%20and%20refer%20to%20the%20closed%20one%2C%20if%20you%20have%20a%20related%20question%20at%20a%20later%20point%20in%20time.%3CBR%20%2F%3E-------------------------------------------------------------------------------%3C%2FP%3E%3C%2FLINGO-BODY%3E
