S32DS Environment variable
2,138 次查看
乔国栋
Why are there errors and how do you fix them
2,097 次查看
Senlent
Hi@乔国栋
from the first picture you provided, the error means your project link file(xx.ld) may not right.
please double check your link file settings.
PS:I can't get more info based on the picture you provided,I suggest you confirm the software environment and SDK version and some other changes with the person who provided this project.
2,083 次查看
乔国栋
It was a link file error, but I didn't fix it. I copied the previous file, so I can recreate it and write it without a problem. The SDK uses 3.0.0
2,133 次查看
乔国栋
