S32146 implement RSA4096 Algorithm
1,247 次查看
alexsun
I want to use S32146 to implement RSA4096 algorithm, if NXP provide some software lib can be use?
标记 (1)
1,228 次查看
lukaszadrapa
Hi @alexsun
CSEc on S32K146 follows only SHE specification, so this function is not supported by hardware. For software emulation, you can use a library like wolfssl:
https://www.wolfssl.com/
Notice that this packages is included in SDK for S32K1xx. Latest version of SDK is 4.0.3. It can be installed to S32 Design Studio IDE 3.4 using menu Help -> S32DS Extensions and Updates.
Lukas
1,175 次查看
alexsun
Hi @lukaszadrapa
Thank you of your reply, where can I get some example project that how to use wolfSSL library in S32K146EVB?
1,173 次查看
lukaszadrapa
Now I can see that it's somehow used only in lwip example on S32K148. That's the only device from S32K1 family which has ethernet module.
So, there's no example for S32K146.
If you have any questions about wolfssl, please follow:
https://www.wolfssl.com/products/support-and-maintenance/
Lukas
