S32 K118 Internal clock Lin
Jianfeng2
I use S32k118, there is no external crystal oscillator, so i use internal clock.
The problem is that the system is works fine in debug mode.  And If power off, then power on, it can't run normally.
Attached is the clock config. Is there anything special when use internal clock? Could you give me some supports?
Thanks very much!
Robin_Shen
Hi Jianfeng2,
If you are using S32K1 SDK, please check if "START_FROM_FLASH" Symbols are missing? refer to the discussion:   S32K188 runs with debugger, but not witout
If you suspect the clock is inaccurate, please observe the frequency of internal clock through the CLKOUT pin.
Robin
- If this post answers your question, please click the "ACCEPT AS SOLUTION" button. Thank you!
Robin_Shen
Hi Jianfeng2,
Robin
Jianfeng2
Solved, Thank you very much!
%3CLINGO-SUB%20id%3D%22lingo-sub-2025686%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32%20K118%20Internal%20clock%20Lin%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2025686%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20use%20S32k118%2C%20there%20is%20no%20external%20crystal%20oscillator%2C%20so%20i%20use%20internal%20clock.%26nbsp%3B%3C%2FP%3E%3CP%3EThe%20problem%20is%20that%20the%20system%20is%20works%20fine%20in%20debug%20mode.%26nbsp%3B%20And%20If%20power%20off%2C%20then%20power%20on%2C%20it%20can't%20run%20normally.%3C%2FP%3E%3CP%3EAttached%20is%20the%20clock%20config.%20Is%20there%20anything%20special%20when%20use%20internal%20clock%3F%20Could%20you%20give%20me%20some%20supports%3F%3C%2FP%3E%3CP%3EThanks%20very%20much!%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2026420%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20S32%20K118%20Internal%20clock%20Lin%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2026420%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ESolved%2C%20Thank%20you%20very%20much!%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2026230%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20S32%20K118%20Internal%20clock%20Lin%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2026230%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3BJianfeng2%2C%3C%2FP%3E%0A%3CP%3EIf%20you%20are%20using%20S32K1%20SDK%2C%20please%20check%20if%20%22%3CSTRONG%3ESTART_FROM_FLASH%3C%2FSTRONG%3E%22%20Symbols%20are%20missing%3F%20refer%20to%20the%20discussion%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K%2FS32K188-runs-with-debugger-but-not-witout%2Ftd-p%2F1203150%22%20target%3D%22_self%22%3ES32K188%20runs%20with%20debugger%2C%20but%20not%20witout%3C%2FA%3E%3C%2FP%3E%0A%3CP%3EIf%20you%20suspect%20the%20clock%20is%20inaccurate%2C%20please%20observe%20the%20frequency%20of%20internal%20clock%20through%20the%20CLKOUT%20pin.%3C%2FP%3E%0A%3CP%3EBest%20Regards%2C%3CBR%20%2F%3ERobin%3CBR%20%2F%3E-------------------------------------------------------------------------------%3CBR%20%2F%3ENote%3A%3CBR%20%2F%3E-%20If%20this%20post%20answers%20your%20question%2C%20please%20click%20the%20%22ACCEPT%20AS%20SOLUTION%22%20button.%20Thank%20you!%3C%2FP%3E%0A%3CP%3E-%20We%20are%20following%20threads%20for%207%20weeks%20after%20the%20last%20post%2C%20later%20replies%20are%20ignored%3CBR%20%2F%3EPlease%20open%20a%20new%20thread%20and%20refer%20to%20the%20closed%20one%2C%20if%20you%20have%20a%20related%20question%20at%20a%20later%20point%20in%20time.%3C%2FP%3E%3C%2FLINGO-BODY%3E
