Regards Example Code Async SPI ON WB s32k344
AbhishekK
Hello
can anyone will help with WB S32k344 (SPI Async loopback ) example code or something .
we are struggling here with it .
The scenario is like ,
We want to get SPI UP . we are configured SPI and called below functions .
Spi_Init(NULL_PTR);
Spi_SetAsyncMode(SPI_INTERRUPT_MODE);
Spi_SetupEB(0u, TxChBuf0, RxChBuf0, 20u);
WriteIB(1u, TxChBuf1);
Spi_AsyncTransmit(SpiConf_SpiSequence_SpiSequence_Slave);
but we are not able to check the clock pulses also on SPI_CLK line .
kindly guide us with method to verify all conditions to up spi .
1. one doubt i need to clerify about spi ?
SPIclk will get only when some data is transfering SPI_OUT or SPI_IN . is it corrct ?
Tags (2)
ekmas-19
Robin_Shen,
I have the s32K344-WB board. From what you said, the example projects won't run here. What is the difference in this board to the compatible boards, S32K3X4EVB-Q257 or S32K3X4EVB-T172? what changes would need to be made to the examples?
This is most unfortunate.
AbhishekK
Hello robin
Is there any document avaliable which guide the about EB project import and compile ,build it .
As it seems process is too much complicated .I am struggling here to import and compile it
Please help me with it
As you see project structure is too much different .
Abhishek
AbhishekK
Hi Robin
I got version 1 RTD package
It is Available here
AbhishekK
Hi Robin
Please let me know which RTD package is used for these plugins . as I am not able to get these Plugins
Kindly provide me path .
Abhishek
Robin_Shen
Did you install SW32K3_RTD_4.4_1.0.0_D2110.exe by follow the chapter "2.3.2. Install Real-Time Drivers" of S32K344_Whiteboard_Software_User_Guide.pdf?  (C:\NXP\S32K344_Whiteboard_Example_RTM_1.0.0\S32K344_Whiteboard_Example_RTM_1.0.0\S32K344_Whiteboard_Software_User_Guide.pdf)
Please download RTD by click S32K3 Standard Software -> Automotive SW - S32K3/S32M27x - Real-Time Drivers for Cortex-M ->
Q: Is there any document avaliable which guide the about EB project import and compile ,build it
A: Please follow the guide of S32K344_Whiteboard_Software_User_Guide.pdf, for example: 5.2. Import EB tresos Project.
AbhishekK
Hi Robin
I have gone throught above document . In this document it is mentioned only how to generate code but I want info about Compilation of this code and elf generation .
Kindly help on it .
Here only S32ds build info is there not about EB tresos build info
Robin_Shen
Sorry, the EB configuration project in S32K344_Whiteboard_Example_RTM_1.0.0 seems to only build in S32DS and generate elf files. It does not provide makefile to build like other EB projects in S32K3 RTD.
AbhishekK
Can you please help me with how to build in S32DS ?
As This info I am not able to find it .
Robin_Shen
I followed the following order:
6. Generate Code
5.1. Import S32DS Project
7.1. Build in S32DS
AbhishekK
 Not able to understand this Error . Can you please help me with it .
Robin_Shen
The video in the attachment records how I imported the EB project to generate code and then built the project with S32DS. I don't have S32K3 RTD 1.0.0 installed but I have RTD 1.0.0 HF01 installed. But I don't think this is the cause of this problem.
Have you tried to import the RTD 1.0.0 project and build it? (File->New->S32DS Project from Example)
If not, I'm afraid you need to raise a new question in the S32DS community and ask my colleagues for help.
Or reinstall S32DS v3.4 with S32K3 RTD 1.0.0:
Please start from page 17 of S32K3xx Real-Time Drivers (RTD) Installation Guide - Training
Click S32K3 Standard Software - > Automotive SW - S32K3/S32M27x - Real-Time Drivers for Cortex-M -> Previous -> S32K3 Real Time Drivers Version 1.0.0
Click S32K3 Standard Software - > Automotive SW - S32K3 - S32 Design Studio -> 3.4.1_D2110 S32 Design Studio for S32 Platform v.3.4 Update with Service Pack 2 for S32K3 devices
Robin_Shen
Yes.
Please tell me which board you are using. Is it the S32K344-WB Evaluation Board for Automotive General Purpose? There is a Spi_Example_47478A_440_100 project in the S32K344 Whiteboard Example Project for your reference. (C:\NXP\S32K344_Whiteboard_Example_RTM_1.0.0\S32K344_Whiteboard_Example_RTM_1.0.0\SPI\Spi_Example_47478A_440_100)
Unfortunately, the S32K3 RTD is usually an example on the S32K3X4EVB-Q257 or S32K3X4EVB-T172, so if you use the project in the RTD, you need to modify it according to the S32K344-WB hardware.
Robin
- If this post answers your question, please click the "ACCEPT AS SOLUTION" button. Thank you!
%3CLINGO-SUB%20id%3D%22lingo-sub-2041415%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERegards%20Example%20Code%20Async%20SPI%20%20ON%20WB%20s32k344%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2041415%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3C%2FP%3E%3CBR%20%2F%3E%3CP%3Ecan%20anyone%20will%20help%20with%20WB%20S32k344%20(SPI%20Async%20loopback%20)%20example%20code%20or%20something%20.%3C%2FP%3E%3CP%3Ewe%20are%20struggling%20here%20with%20it%20.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EThe%20scenario%20is%20like%20%2C%3C%2FP%3E%3CP%3EWe%20want%20to%20get%20SPI%20UP%20.%20we%20are%20configured%20SPI%20and%20called%20below%20functions%20.%3C%2FP%3E%3CP%3ESpi_Init(NULL_PTR)%3B%3C%2FP%3E%3CP%3ESpi_SetAsyncMode(SPI_INTERRUPT_MODE)%3B%3C%2FP%3E%3CP%3ESpi_SetupEB(0u%2C%20TxChBuf0%2C%20RxChBuf0%2C%2020u)%3B%3C%2FP%3E%3CP%3EWriteIB(1u%2C%20TxChBuf1)%3B%3C%2FP%3E%3CP%3ESpi_AsyncTransmit(SpiConf_SpiSequence_SpiSequence_Slave)%3B%3C%2FP%3E%3CP%3Ebut%20we%20are%20not%20able%20to%20check%20the%20clock%20pulses%20also%20on%20SPI_CLK%20line%20.%3C%2FP%3E%3CP%3Ekindly%20guide%20us%20with%20method%20to%20verify%20all%20conditions%20to%20up%20spi%20.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E1.%20one%20doubt%20i%20need%20to%20clerify%20about%20spi%20%3F%26nbsp%3B%3C%2FP%3E%3CP%3ESPIclk%20will%20get%20only%20when%20some%20data%20is%20transfering%20SPI_OUT%20or%20SPI_IN%20.%20is%20it%20corrct%20%3F%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2154659%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Regards%20Example%20Code%20Async%20SPI%20%20ON%20WB%20s32k344%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2154659%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ERobin_Shen%2C%3C%2FP%3E%3CP%3EI%20have%20the%20s32K344-WB%20board.%20From%20what%20you%20said%2C%20the%20example%20projects%20won't%20run%20here.%20What%20is%20the%20difference%20in%20this%20board%20to%20the%20compatible%20boards%2C%26nbsp%3B%3CSPAN%3ES32K3X4EVB-Q257%20or%20S32K3X4EVB-T172%3F%20what%20changes%20would%20need%20to%20be%20made%20to%20the%20examples%3F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EThis%20is%20most%20unfortunate.%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2047037%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Regards%20Example%20Code%20Async%20SPI%20%20ON%20WB%20s32k344%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2047037%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThe%20video%20in%20the%20attachment%20records%20how%20I%20imported%20the%20EB%20project%20to%20generate%20code%20and%20then%20built%20the%20project%20with%20S32DS.%20I%20don't%20have%20S32K3%20RTD%201.0.0%20installed%20but%20I%20have%20RTD%201.0.0%20HF01%20installed.%20But%20I%20don't%20think%20this%20is%20the%20cause%20of%20this%20problem.%3CBR%20%2F%3EHave%20you%20tried%20to%20import%20the%20RTD%201.0.0%20project%20and%20build%20it%3F%20(File-%26gt%3BNew-%26gt%3BS32DS%20Project%20from%20Example)%3C%2FP%3E%0A%3CP%3EIf%20not%2C%20I'm%20afraid%20you%20need%20to%20raise%20a%20new%20question%20in%20the%20S32DS%20community%20and%20ask%20my%20colleagues%20for%20help.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EOr%20reinstall%20S32DS%20v3.4%20with%20S32K3%20RTD%201.0.0%3A%3C%2FP%3E%0A%3CP%3EPlease%20start%20from%20page%2017%20of%26nbsp%3B%3CA%20id%3D%22relatedDocsClickPDF_16%22%20class%3D%22dtmcustomrulelink%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fsupporting-information%2F02_S32K3xx_Real_Time_Drivers_(RTD)_Installation_Guide_Training.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%20data-dtmaction%3D%22Documentation%20Section%20-%20Results%20Link%20Click%22%20data-dtmsubaction%3D%22S32K3xx%20Real-Time%20Drivers%20(RTD)%20Installation%20Guide%20-%20Training%20-%20NXP%20-%20Training%20Presentation%20-%20English%22%3E%3CSPAN%3ES32K3xx%20Real-Time%20Drivers%20(RTD)%20Installation%20Guide%20-%20Training%3C%2FSPAN%3E%3C%2FA%3E%3C%2FP%3E%0A%3CP%3EClick%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fwebapp%2Fswlicensing%2Fsso%2FdownloadSoftware.sp%3Fcatid%3DSW32K3-STDSW-D%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ES32K3%20Standard%20Software%3C%2FA%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E-%20%26gt%3B%26nbsp%3BAutomotive%20SW%20-%20S32K3%2FS32M27x%20-%20Real-Time%20Drivers%20for%20Cortex-M%20-%26gt%3B%26nbsp%3BPrevious%20-%26gt%3B%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fnxp.flexnetoperations.com%2Fcontrol%2Ffrse%2Fdownload%3Felement%3D13023347%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ES32K3%20Real%20Time%20Drivers%20Version%201.0.0%3C%2FA%3E%3C%2FP%3E%0A%3CP%3EClick%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fwebapp%2Fswlicensing%2Fsso%2FdownloadSoftware.sp%3Fcatid%3DSW32K3-STDSW-D%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ES32K3%20Standard%20Software%3C%2FA%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E-%20%26gt%3B%26nbsp%3BAutomotive%20SW%20-%20S32K3%20-%20S32%20Design%20Studio%20-%26gt%3B%26nbsp%3B3.4.1_D2110%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fnxp.flexnetoperations.com%2Fcontrol%2Ffrse%2Fdownload%3Felement%3D13024787%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ES32%20Design%20Studio%20for%20S32%20Platform%20v.3.4%20Update%20with%20Service%20Pack%202%20for%20S32K3%20devices%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2046321%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Regards%20Example%20Code%20Async%20SPI%20%20ON%20WB%20s32k344%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2046321%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22AbhishekK_0-1739879165661.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22AbhishekK_0-1739879165661.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F324513iC8CA03ACCCB2711C%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22AbhishekK_0-1739879165661.png%22%20alt%3D%22AbhishekK_0-1739879165661.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%26nbsp%3BNot%20able%20to%20understand%20this%20Error%20.%20Can%20you%20please%20help%20me%20with%20it%20.%26nbsp%3B%3C%2FP%3E%3CP%3EThanks%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2045965%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Regards%20Example%20Code%20Async%20SPI%20%20ON%20WB%20s32k344%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2045965%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20followed%20the%20following%20order%3A%3CBR%20%2F%3E5.2.%20Import%20EB%20tresos%20Project%3CBR%20%2F%3E6.%20Generate%20Code%3CBR%20%2F%3E5.1.%20Import%20S32DS%20Project%3CBR%20%2F%3E7.1.%20Build%20in%20S32DS%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2045508%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Regards%20Example%20Code%20Async%20SPI%20%20ON%20WB%20s32k344%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2045508%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ECan%20you%20please%20help%20me%20with%20how%20to%20build%20in%20S32DS%20%3F%3CBR%20%2F%3EAs%20This%20info%20I%20am%20not%20able%20to%20find%20it%20.%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2045318%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Regards%20Example%20Code%20Async%20SPI%20%20ON%20WB%20s32k344%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2045318%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ESorry%2C%20the%20EB%20configuration%20project%20in%20S32K344_Whiteboard_Example_RTM_1.0.0%20seems%20to%20only%20build%20in%20S32DS%20and%20generate%20elf%20files.%20It%20does%20not%20provide%20makefile%20to%20build%20like%20other%20EB%20projects%20in%20S32K3%20RTD.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2045154%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Regards%20Example%20Code%20Async%20SPI%20%20ON%20WB%20s32k344%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2045154%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Robin%3C%2FP%3E%3CP%3EI%20have%20gone%20throught%20above%20document%20.%20In%20this%20document%20it%20is%20mentioned%20only%20how%20to%20generate%20code%20but%20I%20want%20info%20about%20Compilation%20of%20this%20code%20and%20elf%20generation%20.%3C%2FP%3E%3CP%3EKindly%20help%20on%20it%20.%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22AbhishekK_0-1739772758144.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22AbhishekK_0-1739772758144.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F324195i3C68B33F6540A969%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22AbhishekK_0-1739772758144.png%22%20alt%3D%22AbhishekK_0-1739772758144.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22AbhishekK_1-1739772829957.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22AbhishekK_1-1739772829957.png%22%20style%3D%22width%3A%20352px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F324196iA3B8350085274079%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22AbhishekK_1-1739772829957.png%22%20alt%3D%22AbhishekK_1-1739772829957.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EHere%20only%20S32ds%20build%20info%20is%20there%20not%20about%20EB%20tresos%20build%20info%26nbsp%3B%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2044992%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Regards%20Example%20Code%20Async%20SPI%20%20ON%20WB%20s32k344%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2044992%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EDid%20you%20install%26nbsp%3B%3CSTRONG%3ESW32K3_RTD_4.4_1.0.0_D2110.exe%3C%2FSTRONG%3E%20by%20follow%20the%20chapter%20%22%3CEM%3E%3CSTRONG%3E2.3.2.%20Install%20Real-Time%20Drivers%3C%2FSTRONG%3E%3C%2FEM%3E%22%20of%26nbsp%3B%3CSTRONG%3E%3CEM%3ES32K344_Whiteboard_Software_User_Guide.pdf%3C%2FEM%3E%3C%2FSTRONG%3E%3F%26nbsp%3B%20(C%3A%5CNXP%5CS32K344_Whiteboard_Example_RTM_1.0.0%5CS32K344_Whiteboard_Example_RTM_1.0.0%5CS32K344_Whiteboard_Software_User_Guide.pdf)%3C%2FP%3E%0A%3CP%3EPlease%20download%20RTD%20by%20click%20%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fwebapp%2Fswlicensing%2Fsso%2FdownloadSoftware.sp%3Fcatid%3DSW32K3-STDSW-D%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ES32K3%20Standard%20Software%3C%2FA%3E%20-%26gt%3B%20Automotive%20SW%20-%20S32K3%2FS32M27x%20-%20Real-Time%20Drivers%20for%20Cortex-M%20-%26gt%3B%26nbsp%3B%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EQ%3A%20Is%20there%20any%20document%20avaliable%20which%20guide%20the%20about%20EB%20project%20import%20and%20compile%20%2Cbuild%20it%3CBR%20%2F%3EA%3A%20Please%20follow%20the%20guide%20of%20S32K344_Whiteboard_Software_User_Guide.pdf%2C%20for%20example%3A%205.2.%20Import%20EB%20tresos%20Project.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2044314%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Regards%20Example%20Code%20Async%20SPI%20%20ON%20WB%20s32k344%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2044314%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%20robin%26nbsp%3B%3C%2FP%3E%3CP%3EIs%20there%20any%20document%20avaliable%20which%20guide%20the%20about%20EB%20project%20import%20and%20compile%20%2Cbuild%20it%20.%3C%2FP%3E%3CP%3EAs%20it%20seems%20process%20is%20too%20much%20complicated%20.I%20am%20struggling%20here%20to%20import%20and%20compile%20it%26nbsp%3B%3C%2FP%3E%3CP%3EPlease%20help%20me%20with%20it%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22AbhishekK_0-1739516862606.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22AbhishekK_0-1739516862606.png%22%20style%3D%22width%3A%20228px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F323962i3B418327982905F1%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22AbhishekK_0-1739516862606.png%22%20alt%3D%22AbhishekK_0-1739516862606.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EAs%20you%20see%20project%20structure%20is%20too%20much%20different%20.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EThanks%26nbsp%3B%3C%2FP%3E%3CP%3EAbhishek%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2044307%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Regards%20Example%20Code%20Async%20SPI%20%20ON%20WB%20s32k344%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2044307%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Robin%26nbsp%3B%3C%2FP%3E%3CP%3EI%20got%20version%201%20RTD%20package%26nbsp%3B%3C%2FP%3E%3CP%3EIt%20is%20Available%20here%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2044289%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Regards%20Example%20Code%20Async%20SPI%20%20ON%20WB%20s32k344%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2044289%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Robin%3C%2FP%3E%3CP%3EPlease%20let%20me%20know%20which%20RTD%20package%20is%20used%20for%20these%20plugins%20.%20as%20I%20am%20not%20able%20to%20get%20these%20Plugins%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22AbhishekK_0-1739514494240.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22AbhishekK_0-1739514494240.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F323959iF4D05DD0F1C33234%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22AbhishekK_0-1739514494240.png%22%20alt%3D%22AbhishekK_0-1739514494240.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EKindly%20provide%20me%20path%20.%3C%2FP%3E%3CP%3EThanks%3C%2FP%3E%3CP%3EAbhishek%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2041482%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Regards%20Example%20Code%20Async%20SPI%20%20ON%20WB%20s32k344%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2041482%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EYes.%3C%2FP%3E%0A%3CP%3EPlease%20tell%20me%20which%20board%20you%20are%20using.%20Is%20it%20the%20%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesign-center%2Fdevelopment-boards-and-designs%2FS32K344-WB%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ES32K344-WB%20Evaluation%20Board%20for%20Automotive%20General%20Purpose%3C%2FA%3E%3F%20There%20is%20a%20%3CSTRONG%3ESpi_Example_47478A_440_100%3C%2FSTRONG%3E%20project%20in%20the%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K%2FS32K344-Whiteboard-Example-Project%2Fm-p%2F1500850%22%20target%3D%22_self%22%3E%20S32K344%20Whiteboard%20Example%20Project%3C%2FA%3E%20for%20your%20reference.%20(C%3A%5CNXP%5CS32K344_Whiteboard_Example_RTM_1.0.0%5CS32K344_Whiteboard_Example_RTM_1.0.0%5CSPI%5CSpi_Example_47478A_440_100)%3C%2FP%3E%0A%3CP%3EUnfortunately%2C%20the%20S32K3%20RTD%20is%20usually%20an%20example%20on%20the%20S32K3X4EVB-Q257%20or%20S32K3X4EVB-T172%2C%20so%20if%20you%20use%20the%20project%20in%20the%20RTD%2C%20you%20need%20to%20modify%20it%20according%20to%20the%20S32K344-WB%20hardware.%3C%2FP%3E%0A%3CP%3EBest%20Regards%2C%3CBR%20%2F%3ERobin%3CBR%20%2F%3E-------------------------------------------------------------------------------%3CBR%20%2F%3ENote%3A%3CBR%20%2F%3E-%20If%20this%20post%20answers%20your%20question%2C%20please%20click%20the%20%22ACCEPT%20AS%20SOLUTION%22%20button.%20Thank%20you!%3C%2FP%3E%0A%3CP%3E-%20We%20are%20following%20threads%20for%207%20weeks%20after%20the%20last%20post%2C%20later%20replies%20are%20ignored%3CBR%20%2F%3EPlease%20open%20a%20new%20thread%20and%20refer%20to%20the%20closed%20one%2C%20if%20you%20have%20a%20related%20question%20at%20a%20later%20point%20in%20time.%3CBR%20%2F%3E-------------------------------------------------------------------------------%3C%2FP%3E%3C%2FLINGO-BODY%3E
