Hello Daniel,
1. Assume that we classify the software components into different COREs of S32K3 by ASIL level, with one soft watchdog per CORE. Can the soft watchdog reset only CORE1 and keep CORE2 running when the APP in CORE1 fails? Do we need to use XRDC to implement it?
2. Assume that within a CORE of S32K3, we use MPU tools to rank software components into ASIL levels. Which architecture within S32K will result in the above design scheme not meeting the independent requirements of functional security?
3. Assuming that we have three software components of different security levels, QM, ASILB, ASILD, how many COREs of S32K are recommended?
