Reception supported through both Rx FIFO and individual buffer at same instance
1,441 次查看
chandru_v
In S32K148, is reception supported through both Rx FIFO and individual buffer at same instance.
For Example:
-> I will enable FIFO.
-> 0-10 buffers are provided for FIFO reception.
-> 11-15 are provided for dedicated reception, will hardware try to find a match in 11-15 buffers if reception doesn't pass through FIFO filters.
1,380 次查看
PetrS
yes. this is possible.
You can refer to simple example on https://community.nxp.com/docs/DOC-343091
BR, Petr
