RTD version for S32K3 microcontrollers that supports Fls component
Djuric
What is the latest RTD version for K3 microcontrollers, specifically S32K344, that has a Fls component?
I have a problem in source code with backward compatibility, because Fls is now divided into two components.
I see that the Fls component is present in S32K3 Real-Time Drivers Version 3.0.0 P01 HotFix 02, and not in S32K3_M27X Real-Time Drivers Version 3.0.0 P07
Q1:   Are there any RTD driver versions between these two that have a Fls component ?
Q2:   Which FS26 SBC AUTOSAR drivers is compatible with S32K3 Real-Time Drivers Version 3.0.0 P01 HotFix 02 ?
Julián_AragónM
Hi @Djuric
In Autosar R21-11, the Fls Driver has been replaced by Mem_InFls/Mem_ExFls. RTD 3.0.0 P07 is ASR 4.7 (R21-11) compliant, while P01 is ASR 4.4. The latest RTD package which still contains the Fls component is S32K3_S32M27x Real-Time Drivers AUTOSAR 4.4 Version 4.0.0 P24.
Q1. I'm guessing you mean between P01 and P07? Unfortunately, there is not.
Q2. I'm not sure if there is a specific package, as the only ones I've seen only support 3.0.0 P07. Since I mainly support S32K3 devices, and not FS26 SBC, please enter another post (or a case) so an engineer from the analog team can support you instead.
Julián
Djuric
Thank you for your answer.
Julián_AragónM
Hi @Djuric
Julián
%3CLINGO-SUB%20id%3D%22lingo-sub-2061553%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERTD%20version%20for%20S32K3%20microcontrollers%20that%20supports%20Fls%20component%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2061553%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%3CP%3EWhat%20is%20the%20latest%20RTD%20version%20for%20K3%20microcontrollers%2C%26nbsp%3Bspecifically%20S32K344%2C%20that%20has%20a%20Fls%20component%3F%3CBR%20%2F%3EI%20have%20a%20problem%20in%20source%20code%20with%20backward%20compatibility%2C%26nbsp%3Bbecause%20Fls%20is%20now%20divided%20into%20two%20components.%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CP%3EI%20see%20that%20the%20Fls%20component%20is%20present%20in%20S32K3%20Real-Time%20Drivers%20Version%203.0.0%E2%80%AFP01%20HotFix%2002%2C%20and%20not%20in%26nbsp%3BS32K3_M27X%20Real-Time%20Drivers%20Version%203.0.0%20P07%3C%2FP%3E%3CP%3EQ1%3A%26nbsp%3B%20%26nbsp%3BAre%20there%20any%20RTD%20driver%20versions%20between%20these%20two%20that%20have%20a%20Fls%20component%20%3F%3C%2FP%3E%3CP%3EQ2%3A%26nbsp%3B%20%26nbsp%3BWhich%26nbsp%3BFS26%20SBC%20AUTOSAR%20drivers%20is%20compatible%20with%26nbsp%3BS32K3%20Real-Time%20Drivers%20Version%203.0.0%E2%80%AFP01%20HotFix%2002%20%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2061617%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20RTD%20version%20for%20S32K3%20microcontrollers%20that%20supports%20Fls%20component%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2061617%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThank%20you%20for%20your%20answer.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2061593%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20RTD%20version%20for%20S32K3%20microcontrollers%20that%20supports%20Fls%20component%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2061593%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F232904%22%20target%3D%22_blank%22%3E%40Djuric%3C%2FA%3E%3C%2FP%3E%0A%3CP%3EIn%20Autosar%20R21-11%2C%20the%20Fls%20Driver%20has%20been%20replaced%20by%20Mem_InFls%2FMem_ExFls.%20RTD%203.0.0%20P07%20is%20ASR%204.7%20(R21-11)%20compliant%2C%20while%20P01%20is%20ASR%204.4.%20The%20latest%20RTD%20package%20which%20still%20contains%20the%20Fls%20component%20is%26nbsp%3B%3CSTRONG%3ES32K3_S32M27x%20Real-Time%20Drivers%20AUTOSAR%204.4%20Version%204.0.0%20P24.%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3EQ1.%20I'm%20guessing%20you%20mean%20between%20P01%20and%20P07%3F%20Unfortunately%2C%20there%20is%20not.%3C%2FP%3E%0A%3CP%3EQ2.%20I'm%20not%20sure%20if%20there%20is%20a%20specific%20package%2C%20as%20the%20only%20ones%20I've%20seen%20only%20support%26nbsp%3B3.0.0%20P07.%20Since%20I%20mainly%20support%20S32K3%20devices%2C%20and%20not%20FS26%20SBC%2C%20please%20enter%20another%20post%20(or%20a%20case)%20so%20an%20engineer%20from%20the%20analog%20team%20can%20support%20you%20instead.%3C%2FP%3E%0A%3CP%3EBest%20regards%2C%3CBR%20%2F%3EJuli%C3%A1n%26nbsp%3B%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E
