RDBESSK358BMU Ethernet configuration
gferretts
I'm currently working on RDBESSK358BMU from NXP, the board has S32K358 with GMAC connected to Marvell Alaska 88e1510 transceiver and a eth gigabit port (HW scheme attached).
I'm wondering if i can use tcpip stack with lwip_baremetal examples with this configuration.
The example with Gmac_Loopback works, butlwip_baremetal_example fails on Gmac_initDMA like i saw in other posts it is a clock reference problem, but the board i'm using has an external clock on it, so i don't understand how to adapt the example to my hardware. Can someone give help? Thanks!
PavelL
Hello @gferretts ,
I apologize for delayed reply.
Unfortunately, RD-BESSK358BMU is not in  my possession, so I'm not able to adapt lwip example for you. Anyway, I adapted lwip example for S32K358EVB-Q289, RGMII 100Mbps without any issues. Let me share basic steps I use for adoption (please note that some details might be related to S32K3 RTD / TCPIP version):
  • Config Tool - Pins
    • Adopting pins to fit board's wiring
    • Set Slew rate as Fastest settings, if applicable
    • TX_CLK should be output for RGMII
  • Config Tool - Clocks
    • GMAC clocks should look like that (note for GMAC 1Gbps: 25MHz -> 125MHz ; 50MHz -> 250MHz)
  • Config Tool - GMAC driver
    • ETH_MAC_LAYE_TYPE_XGMII, REDUCED, set correct speed ETH_MAC_LAYER_SPEED_xxx
  • Source code - device.c
    • Add RTD workaround as the very first rows of device_init()
/* Set RGMII mode configuration for GMAC0 in DCM module */
IP_DCM_GPR->DCMRWF1 |= DCM_GPR_DCMRWF1_MAC_CONF_SEL(0x01) | DCM_GPR_DCMRWF1_MAC_TX_RMII_CLK_LPBCK_EN_MASK;
/* Set RGMII RX_CLK arrives directly from the RX_CLK pin for GMAC in DCM module */
IP_DCM_GPR->DCMRWF3 |= DCM_GPR_DCMRWF3_MAC_RX_CLK_MUX_BYPASS(0x01);
  • Source code - test.c
    • Alternatively, comment out section which shuts down TCP/IP stack after some time
This was the easier part.
Looking to schematic, you need to define GPIO PTC1 to provide valid reset pulse signal to the PHY and wait for a while before initializing GMAC. PHY usually works independently, in unmanaged mode, just configured by pin strapping. Sometimes, PHY requires management via SMI.
What S32K3 RTD version and what TCP/IP stack version do you use?
Pavel
PavelL
Hello @gferretts ,
Pavel
gferretts
Hi @PavelL , thanks for your reply. I'm still having problems with lwip, i also have s32k3x8evb-q289 but i don't have a TJA daughter board so i need to test Ethernet on my S32K358BMU.
I'm using RTD3.0.0 with "TCPIP STACK 1.0.3 D2306", i attach my .mex config file where i tryied to replicate what you showed (clock configuration, GMAC pheripheral and pinout) and "device.c" with ETH_RESET from pin.
I tryied also to replicate your RTD turnaround manually since my rtd has no loopback define:
void device_init(void) {
uint16 pitPeriod;
/* Set RMII configuration for EMAC in DCM module */
//IP_DCM_GPR->DCMRWF1 = (IP_DCM_GPR->DCMRWF1 & ~DCM_GPR_DCMRWF1_EMAC_CONF_SEL_MASK) | DCM_GPR_DCMRWF1_EMAC_CONF_SEL(1U);
/* Manual RTD turnaround */
IP_DCM_GPR->DCMRWF1 = 0x80000040;
IP_DCM_GPR->DCMRWF3 = 0x2000;
With this configuration, the example is able to achieve Gmac_Ip_InitDMA without Timeout and reaches mainloop, but pinging 192.168.0.200 from my Pc results in not reachable host and ping timeout.
With oscilloscope i verified RXC is present (25MHz when Phy negotiates 100Mbps or 125MHz when 1Gbps) so there is some traffic coming from ETH port. Meanwhile on TXC now i see 125MHz too but TXD0,1 are never triggered.
I hope you can find what is happening wrong here.
Tags (4)
gferretts
Thank you very much @PavelL! I noticed i still had 100m as GMAC speed, by setting it to 1G to match 125MHz clock now it works fine with ping and TCP echo on port 7!
I also commented "Eth_T_InitPhys();" since my PHY was not in the phy list and it is configured via straps.
PavelL
Hello @gferretts ,
yes, that's what I have found. You were faster.
You may copy missing definition from RTD 5.0.0:
#define DCM_GPR_DCMRWF1_MAC_TX_RMII_CLK_LPBCK_EN_MASK (0x80000000U)
#define DCM_GPR_DCMRWF1_MAC_TX_RMII_CLK_LPBCK_EN_SHIFT (31U)
#define DCM_GPR_DCMRWF1_MAC_TX_RMII_CLK_LPBCK_EN_WIDTH (1U)
#define DCM_GPR_DCMRWF1_MAC_TX_RMII_CLK_LPBCK_EN(x) (((uint32_t)(((uint32_t)(x)) << DCM_GPR_DCMRWF1_MAC_TX_RMII_CLK_LPBCK_EN_SHIFT)) & DCM_GPR_DCMRWF1_MAC_TX_RMII_CLK_LPBCK_EN_MASK)
... just notice that the RTD workaround uses |=
Regarding Eth_T_InitPhys() - yes, that was also right mode - this routine deserves a deep inspection.
Pavel
%3CLINGO-SUB%20id%3D%22lingo-sub-2354614%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERDBESSK358BMU%20Ethernet%20configuration%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2354614%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI'm%20currently%20working%20on%20RDBESSK358BMU%20from%20NXP%2C%20the%20board%20has%20S32K358%20with%20GMAC%20connected%20to%20Marvell%20Alaska%2088e1510%20transceiver%20and%20a%20eth%20gigabit%20port%20(HW%20scheme%20attached).%3C%2FP%3E%3CP%3EI'm%20wondering%20if%20i%20can%20use%20tcpip%20stack%20with%20lwip_baremetal%20examples%20with%20this%20configuration.%3C%2FP%3E%3CP%3EThe%20example%20with%20Gmac_Loopback%20works%2C%20butlwip_baremetal_example%20fails%20on%20Gmac_initDMA%20like%20i%20saw%20in%20other%20posts%20it%20is%20a%20clock%20reference%20problem%2C%20but%20the%20board%20i'm%20using%20has%20an%20external%20clock%20on%20it%2C%20so%20i%20don't%20understand%20how%20to%20adapt%20the%20example%20to%20my%20hardware.%20Can%20someone%20give%20help%3F%20Thanks!%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Screenshot%202026-04-22%20103818.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202026-04-22%20103818.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F383172i89DEBF3D64EE4CF6%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Screenshot%202026-04-22%20103818.png%22%20alt%3D%22Screenshot%202026-04-22%20103818.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E2%80%83%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2355795%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDBESSK358BMU%20Ethernet%20configuration%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2355795%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F260147%22%20target%3D%22_blank%22%3E%40gferretts%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%0A%3CP%3Eyes%2C%20that's%20what%20I%20have%20found.%20You%20were%20faster.%3C%2FP%3E%0A%3CP%3EYou%20may%20copy%20missing%20definition%20from%20RTD%205.0.0%3A%3CBR%20%2F%3E%23define%20DCM_GPR_DCMRWF1_MAC_TX_RMII_CLK_LPBCK_EN_MASK%20(0x80000000U)%3CBR%20%2F%3E%23define%20DCM_GPR_DCMRWF1_MAC_TX_RMII_CLK_LPBCK_EN_SHIFT%20(31U)%3CBR%20%2F%3E%23define%20DCM_GPR_DCMRWF1_MAC_TX_RMII_CLK_LPBCK_EN_WIDTH%20(1U)%3CBR%20%2F%3E%23define%20DCM_GPR_DCMRWF1_MAC_TX_RMII_CLK_LPBCK_EN(x)%20(((uint32_t)(((uint32_t)(x))%20%26lt%3B%26lt%3B%20DCM_GPR_DCMRWF1_MAC_TX_RMII_CLK_LPBCK_EN_SHIFT))%20%26amp%3B%20DCM_GPR_DCMRWF1_MAC_TX_RMII_CLK_LPBCK_EN_MASK)%3C%2FP%3E%0A%3CP%3E...%20just%20notice%20that%20the%20RTD%20workaround%20uses%20%7C%3D%26nbsp%3B%3C%2FP%3E%0A%3CP%3ERegarding%20Eth_T_InitPhys()%20-%20yes%2C%20that%20was%20also%20right%20mode%20-%20this%20routine%20deserves%20a%20deep%20inspection.%3C%2FP%3E%0A%3CP%3EBest%20regards%2C%3C%2FP%3E%0A%3CP%3EPavel%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2355789%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDBESSK358BMU%20Ethernet%20configuration%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2355789%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThank%20you%20very%20much%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F233505%22%20target%3D%22_blank%22%3E%40PavelL%3C%2FA%3E!%20I%20noticed%20i%20still%20had%20100m%20as%20GMAC%20speed%2C%20by%20setting%20it%20to%201G%20to%20match%20125MHz%20clock%20now%20it%20works%20fine%20with%20ping%20and%20TCP%20echo%20on%20port%207!%3C%2FP%3E%3CP%3EI%20also%20commented%20%22Eth_T_InitPhys()%3B%22%20since%20my%20PHY%20was%20not%20in%20the%20phy%20list%20and%20it%20is%20configured%20via%20straps.%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Screenshot%202026-04-24%20121606.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202026-04-24%20121606.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F383478i7F0803F13F5A9209%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Screenshot%202026-04-24%20121606.png%22%20alt%3D%22Screenshot%202026-04-24%20121606.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E2%80%83%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Screenshot%202026-04-24%20121640.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202026-04-24%20121640.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F383479i2A529C8724B42B67%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Screenshot%202026-04-24%20121640.png%22%20alt%3D%22Screenshot%202026-04-24%20121640.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E2%80%83%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2355772%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDBESSK358BMU%20Ethernet%20configuration%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2355772%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F233505%22%20target%3D%22_blank%22%3E%40PavelL%3C%2FA%3E%20%2C%20thanks%20for%20your%20reply.%20I'm%20still%20having%20problems%20with%20lwip%2C%20i%20also%20have%20s32k3x8evb-q289%20but%20i%20don't%20have%20a%20TJA%20daughter%20board%20so%20i%20need%20to%20test%20Ethernet%20on%20my%20S32K358BMU.%3C%2FP%3E%3CP%3EI'm%20using%20RTD3.0.0%20with%20%22TCPIP%20STACK%201.0.3%20D2306%22%2C%20i%20attach%20my%20.mex%20config%20file%20where%20i%20tryied%20to%20replicate%20what%20you%20showed%20(clock%20configuration%2C%20GMAC%20pheripheral%20and%20pinout)%20and%20%22device.c%22%20with%20ETH_RESET%20from%20pin.%3C%2FP%3E%3CP%3EI%20tryied%20also%20to%20replicate%20your%20RTD%20turnaround%20manually%20since%20my%20rtd%20has%20no%20loopback%20define%3A%3C%2FP%3E%3CDIV%3Evoid%20device_init(void)%20%7B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Euint16%20pitPeriod%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%2F*%20Set%20RMII%20configuration%20for%20EMAC%20in%20DCM%20module%20*%2F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%2F%2FIP_DCM_GPR-%26gt%3BDCMRWF1%20%3D%20(IP_DCM_GPR-%26gt%3BDCMRWF1%20%26amp%3B%20~DCM_GPR_DCMRWF1_EMAC_CONF_SEL_MASK)%20%7C%20DCM_GPR_DCMRWF1_EMAC_CONF_SEL(1U)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%2F*%20Manual%20RTD%20turnaround%20*%2F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EIP_DCM_GPR-%26gt%3BDCMRWF1%20%3D%200x80000040%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EIP_DCM_GPR-%26gt%3BDCMRWF3%20%3D%200x2000%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E....%3C%2FSPAN%3E%3CSPAN%3E%7D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EWith%20this%20configuration%2C%20the%20example%20is%20able%20to%20achieve%20Gmac_Ip_InitDMA%20without%20Timeout%20and%20reaches%20mainloop%2C%20but%20pinging%20192.168.0.200%20from%20my%20Pc%20results%20in%20not%20reachable%20host%20and%20ping%20timeout.%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EWith%20oscilloscope%20i%20verified%20RXC%20is%20present%20(25MHz%20when%20Phy%20negotiates%20100Mbps%20or%20125MHz%20when%201Gbps)%20so%20there%20is%20some%20traffic%20coming%20from%20ETH%20port.%20Meanwhile%20on%20TXC%20now%20i%20see%20125MHz%20too%20but%20TXD0%2C1%20are%20never%20triggered.%3C%2FDIV%3E%3CDIV%3EI%20hope%20you%20can%20find%20what%20is%20happening%20wrong%20here.%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2355696%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDBESSK358BMU%20Ethernet%20configuration%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2355696%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F260147%22%20target%3D%22_blank%22%3E%40gferretts%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%0A%3CP%3EI%20apologize%20for%20delayed%20reply.%3C%2FP%3E%0A%3CP%3EUnfortunately%2C%26nbsp%3BRD-BESSK358BMU%20is%20not%20in%26nbsp%3B%20my%20possession%2C%20so%20I'm%20not%20able%20to%20adapt%20lwip%20example%20for%20you.%20Anyway%2C%20I%20adapted%20lwip%20example%20for%26nbsp%3BS32K358EVB-Q289%2C%20RGMII%20100Mbps%20without%20any%20issues.%20Let%20me%20share%20basic%20steps%20I%20use%20for%20adoption%20(please%20note%20that%20some%20details%20might%20be%20related%20to%20S32K3%20RTD%20%2F%20TCPIP%20version)%3A%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3EConfig%20Tool%20-%20Pins%0A%3CUL%3E%0A%3CLI%3EAdopting%20pins%20to%20fit%20board's%20wiring%3C%2FLI%3E%0A%3CLI%3ESet%20Slew%20rate%20as%20Fastest%20settings%2C%20if%20applicable%3C%2FLI%3E%0A%3CLI%3ETX_CLK%20should%20be%20output%20for%20RGMII%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FLI%3E%0A%3CLI%3EConfig%20Tool%20-%20Clocks%0A%3CUL%3E%0A%3CLI%3EGMAC%20clocks%20should%20look%20like%20that%20(note%20for%20GMAC%201Gbps%3A%2025MHz%20-%26gt%3B%20125MHz%20%3B%2050MHz%20-%26gt%3B%20250MHz)%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22PavelL_0-1777015189023.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22PavelL_0-1777015189023.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F383445i246B6EC68DC45A5A%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22PavelL_0-1777015189023.png%22%20alt%3D%22PavelL_0-1777015189023.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3EConfig%20Tool%20-%20GMAC%20driver%0A%3CUL%3E%0A%3CLI%3EETH_MAC_LAYE_TYPE_XGMII%2C%20REDUCED%2C%20set%20correct%20speed%20ETH_MAC_LAYER_SPEED_xxx%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FLI%3E%0A%3CLI%3ESource%20code%20-%20device.c%0A%3CUL%3E%0A%3CLI%3EAdd%20RTD%20workaround%20as%20the%20very%20first%20rows%20of%20device_init()%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%2F*%20Set%20RGMII%20mode%20configuration%20for%20GMAC0%20in%20DCM%20module%20*%2F%3CBR%20%2F%3EIP_DCM_GPR-%26gt%3BDCMRWF1%20%7C%3D%20DCM_GPR_DCMRWF1_MAC_CONF_SEL(0x01)%20%7C%20DCM_GPR_DCMRWF1_MAC_TX_RMII_CLK_LPBCK_EN_MASK%3B%3CBR%20%2F%3E%2F*%20Set%20RGMII%20RX_CLK%20arrives%20directly%20from%20the%20RX_CLK%20pin%20for%20GMAC%20in%20DCM%20module%20*%2F%3CBR%20%2F%3EIP_DCM_GPR-%26gt%3BDCMRWF3%20%7C%3D%20DCM_GPR_DCMRWF3_MAC_RX_CLK_MUX_BYPASS(0x01)%3B%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3ESource%20code%20-%20test.c%0A%3CUL%3E%0A%3CLI%3EAlternatively%2C%20comment%20out%20section%20which%20shuts%20down%20TCP%2FIP%20stack%20after%20some%20time%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CBR%20%2F%3E%0A%3CP%3EThis%20was%20the%20easier%20part.%3C%2FP%3E%0A%3CP%3ELooking%20to%20schematic%2C%20you%20need%20to%20define%20GPIO%20PTC1%20to%20provide%20valid%20reset%20pulse%20signal%20to%20the%20PHY%20and%20wait%20for%20a%20while%20before%20initializing%20GMAC.%20PHY%20usually%20works%20independently%2C%20in%20unmanaged%20mode%2C%20just%20configured%20by%20pin%20strapping.%20Sometimes%2C%20PHY%20requires%20management%20via%20SMI.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EWhat%20S32K3%20RTD%20version%20and%20what%20TCP%2FIP%20stack%20version%20do%20you%20use%3F%3C%2FP%3E%0A%3CP%3EBest%20regards%2C%3C%2FP%3E%0A%3CP%3EPavel%3C%2FP%3E%3C%2FLINGO-BODY%3E
