Power consumption S32K148
ultra12
#S32K148
Dear Team,
I am preparing a power tree for my board.My board contains S32K148 also.
I want to know the worst case current drawn from my 5V supply.
Let us take 125Mhz and 719mA . May I know what you mean by IDD/MHz (μA/MHz) .Does it mean for every 1Mhz the IC will consume 719mA?(I know I am wrong,if it was like that then the current will be huge!!!!)
In general how do we calculate the worst case current consumption of a microcontroller.
#S32K148
Hari
_Leo_
_Leo_
Thank you so much for your interest in our products and for using our community.
I think the table is being misinterpreted.
The data of 125 that you remark is temperature, not frequency.
On the other hand, note 4 says:
"4. Values mentioned for S32K14x devices are measured at RUN@80 MHz with peripherals disabled and values mentioned for S32K11x devices are measured at RUN@48 MHz with peripherals disabled."
So, based on the RUN@80 MHz (mA) - Peripherals disabled column, the calculation 57.5mA/80MHz = 718.75uA/MHz, rounded matches the 719uA/MHz described in the table.
Hope it helps you.
Have a nice day!
ultra12
Thank you very much.
"So, based on the RUN@80 MHz (mA) - Peripherals disabled column, the calculation 57.5mA/80MHz = 718.75uA/MHz, rounded matches the 719uA/MHz described in the table." so at 80Mhz peripherals disabled the microcontroller is taking 57.mA.Correct me if I am wrong
May I know how to calculate the total current consumption of a microcontroller.Please take S32K148 as an example.
HA
_Leo_
