Pin Functions of S32K342NHT0MPBSR
Divyashree1
Hi Team,
Please share the Pin functions for the below mentioned pin numbers of Part number S32K342NHT0MPBSR:
Pin NumberPin Name
Signal Name
167PTA5RESETS.MCU_POR
123PTA3MCU_ERR1
124PTA2MCU_ERR0
137PTA0POWER_MONITOR.P8V0_CABLE_MON
49PTC3MCU_FLASH_QSPI_BUS.QSPI_MCU_FLASH_CS
50PTC2MCU_FLASH_QSPI_BUS.QSPI_MCU_FLASH_IO3
51PTD7MCU_FLASH_QSPI_BUS.QSPI_MCU_FLASH_IO1
54PTD12MCU_FLASH_QSPI_BUS.QSPI_MCU_FLASH_IO2
55PTD11MCU_FLASH_QSPI_BUS.QSPI_MCU_FLASH_IO0
56PTD10MCU_FLASH_QSPI_BUS.QSPI_MCU_FLASH_SCLK
72PTB25POWER_CONTROL.LO_BAT_IRQ
82PTC28POWER_MONITOR.VBATT_SENSE
45PTB21FPGA_PROG_BUS.FPGA_DONE
66PTC16FPGA_PROG_BUS.FPGA_INIT_B
51PTD6FPGA_PROG_BUS.FPGA_PROG_B
danielmartynek
Hello @Divyashree1,
Where can I find the table?
Is it taken from an NXP demo?
All the pin functions can be found in the S32K342_S32K322_IOMUX.xlsx file that is attached to the Reference Manual.
For example:
BR, Daniel
