Parameter passing from c to assembly code
2,740件の閲覧回数
SreejithN
Have one requirement to pass one parameter  from c to Assembly code.  And it  has to be done by using stack. Kindly provide one example code to pass the parameter from c to a assembly function.
3 返答(返信)
2,715件の閲覧回数
danielmartynek
Can you elaborate?
What it should do exactly?
What S32K part and compiler do you use?
2,689件の閲覧回数
SreejithN
The project is build and complied in IAR.
The requirement is to pass one Parameter form C file to assembly function. The c file has to call the assembly function with one variable. How the assembly cod can access this parameter?
2,679件の閲覧回数
danielmartynek
