Parameter passing from c to assembly code
SreejithN
Have one requirement to pass one parameter  from c to Assembly code.  And it  has to be done by using stack. Kindly provide one example code to pass the parameter from c to a assembly function.
danielmartynek
Can you elaborate?
What it should do exactly?
What S32K part and compiler do you use?
SreejithN
The project is build and complied in IAR.
The requirement is to pass one Parameter form C file to assembly function. The c file has to call the assembly function with one variable. How the assembly cod can access this parameter?
danielmartynek
Hi @SreejithN,
Something like that?
https://wwwfiles.iar.com/arm/webic/doc/EWARM_DevelopmentGuide.ENU.pdf
