PDB trigger input source
1,508 次查看
anita_tranzillo
Hi all, I have a question about the external trigger source for PDB-ADC peripheral.
At pag. 1182 of S32K manual, I read:
"...A trigger input event is defined as a rising edge being detected on a selected
trigger input source…."
I would like to know if there is the possibility to generate a trigger also when a falling edge is detecte.
Thanks a lot
1,459 次查看
Alexis_A
Hi anita tranzillo,
Unfortunately, in the section 44.4.1 PDB pre-trigger and trigger outputs only explains how to use the rising edge and in the registers doesn't explain how to change the polarity.
Alexis Andalon
