Open SDA Firmware Question
wj_kwak
I purchased the FRDM-A-S32K358 development board and checked the JTAG port for changing the firmware on the MK26 chip responsible for Open SDA. If I accidentally install the firmware on J13, I will need to obtain the Open SDA firmware. In this case, can I obtain the firmware by requesting it via a support ticket?
lukaszadrapa
Hi @wj_kwak
If the MK26 OpenSDA device has been overwritten via J13, the standard OpenSDA update procedure may no longer be applicable, since it relies on a functioning OpenSDA bootloader. The OpenSDA recovery firmware is not generally distributed as a standalone programming image.
The OpenSDA firmware and bootloader are PEmicro technology rather than NXP-developed software. PEmicro provides the firmware updates, bootloader update applications, and related support for OpenSDA.
Therefore, if the MK26 has been erased or reprogrammed via JTAG/SWD and the OpenSDA bootloader is no longer functional, PEmicro would be the primary contact for recovery guidance and firmware availability.
https://www.pemicro.com/support/index.cfm
Lukas
lukaszadrapa
Hi @wj_kwak
Lukas
%3CLINGO-SUB%20id%3D%22lingo-sub-2398022%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EOpen%20SDA%20Firmware%20Question%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2398022%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20purchased%20the%20FRDM-A-S32K358%20development%20board%20and%20checked%20the%20JTAG%20port%20for%20changing%20the%20firmware%20on%20the%20MK26%20chip%20responsible%20for%20Open%20SDA.%20If%20I%20accidentally%20install%20the%20firmware%20on%20J13%2C%20I%20will%20need%20to%20obtain%20the%20Open%20SDA%20firmware.%20In%20this%20case%2C%20can%20I%20obtain%20the%20firmware%20by%20requesting%20it%20via%20a%20support%20ticket%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2398540%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Open%20SDA%20Firmware%20Question%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2398540%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F263485%22%20target%3D%22_blank%22%3E%40wj_kwak%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EIf%20the%20MK26%20OpenSDA%20device%20has%20been%20overwritten%20via%20J13%2C%20the%20standard%20OpenSDA%20update%20procedure%20may%20no%20longer%20be%20applicable%2C%20since%20it%20relies%20on%20a%20functioning%20OpenSDA%20bootloader.%20The%20OpenSDA%20recovery%20firmware%20is%20not%20generally%20distributed%20as%20a%20standalone%20programming%20image.%3C%2FP%3E%0A%3CP%3EThe%20OpenSDA%20firmware%20and%20bootloader%20are%20PEmicro%20technology%20rather%20than%20NXP-developed%20software.%20PEmicro%20provides%20the%20firmware%20updates%2C%20bootloader%20update%20applications%2C%20and%20related%20support%20for%20OpenSDA.%3C%2FP%3E%0A%3CP%3ETherefore%2C%20if%20the%20MK26%20has%20been%20erased%20or%20reprogrammed%20via%20JTAG%2FSWD%20and%20the%20OpenSDA%20bootloader%20is%20no%20longer%20functional%2C%20PEmicro%20would%20be%20the%20primary%20contact%20for%20recovery%20guidance%20and%20firmware%20availability.%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.pemicro.com%2Fsupport%2Findex.cfm%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.pemicro.com%2Fsupport%2Findex.cfm%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3ERegards%2C%3C%2FP%3E%0A%3CP%3ELukas%3C%2FP%3E%3C%2FLINGO-BODY%3E
