Modify crystal oscillator value,CAN can't communicate?
1,001件の閲覧回数
jingfang
For EMI/C problems, change the crystal value from 40M ->16M(include HW&SW) in S32K116.
The cyrstal vibration is OK after the hardware test and modification.
I change SOSC to 16M and check Configuration compare as below:
Check can communication through the tool,found no data ,and the LED light is not on ,as blow.
Is there something I should configure or something I didn't configure?
Modify SOSC.pngConfiguration compare:
CAN not communication:
987件の閲覧回数
Senlent
Hi@jingfang
It should be incorrectly configured, try this CAN configuration,
Is your PE's clock 4MHz?
