Missing TCP/IP stack in example project
sergioGeronimo
I am working with S32K1 series boards, S32K148 more concretely.
The issue I face is that not even the example project compiles. I create it using S32DS IDE and "New -> Project from Example", from which I select the lwip_FreeRTOS_S32K148.
The documentation says it should be possible to build it straight from there. However, that is not the case because a lot of files are missing. After opening the S32 Configuration Tools and Updating the Code, most of the issues are gone. However, the lwip stacks folder is still missing and I get an error in the Peripherals tab saying that the tcp/ip stack is not included in the toolchain.
As stated in the Release Notes of the stack, I installed S32K1_S32M24X Real Time Drivers AUTOSAR R21-11 Version 3.0.0 and S32K1 FreeRTOS 10.5.1
version 2.0.0 packages and I am using S32DS 3.6.3.
PavelL
Hello @sergioGeronimo ,
This is caused by a mismatch in manifest SDK version between RTD 3.0.0 (version 2.0.0) and TCP/IP 3.0.0 (version 3.0.0) releases.
To solve this please follow these steps:
1. Go in S32DS installation folder, or the equivalent path for your machine.
C:\NXP\S32DS.3.6.1\S32DS\software\PlatformSDK_S32K1_S32M24
2. Open the tcpip_itm_manifest.xml and change the version from 3.0.0 to 2.0.0
3. Restart S32DS
4. Open peripheral view and run "Update Code"
5. run Build again
Pavel
PavelL
3. Restart S32DS
5. run Build again
Pavel
%3CLINGO-SUB%20id%3D%22lingo-sub-2166495%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMissing%20TCP%2FIP%20stack%20in%20example%20project%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2166495%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%26nbsp%3B%3C%2FP%3E%0A%3CP%3EI%20am%20working%20with%20S32K1%20series%20boards%2C%20S32K148%20more%20concretely.%3C%2FP%3E%0A%3CP%3EThe%20issue%20I%20face%20is%20that%20not%20even%20the%20example%20project%20compiles.%20I%20create%20it%20using%20S32DS%20IDE%20and%20%22New%20-%26gt%3B%20Project%20from%20Example%22%2C%20from%20which%20I%20select%20the%20lwip_FreeRTOS_S32K148.%3C%2FP%3E%0A%3CP%3EThe%20documentation%20says%20it%20should%20be%20possible%20to%20build%20it%20straight%20from%20there.%20However%2C%20that%20is%20not%20the%20case%20because%20a%20lot%20of%20files%20are%20missing.%20After%20opening%20the%20S32%20Configuration%20Tools%20and%20Updating%20the%20Code%2C%20most%20of%20the%20issues%20are%20gone.%20However%2C%20the%20lwip%20stacks%20folder%20is%20still%20missing%20and%20I%20get%20an%20error%20in%20the%20Peripherals%20tab%20saying%20that%20the%20tcp%2Fip%20stack%20is%20not%20included%20in%20the%20toolchain.%3C%2FP%3E%0A%3CP%3EAs%20stated%20in%20the%20Release%20Notes%20of%20the%20stack%2C%20I%20installed%26nbsp%3BS32K1_S32M24X%20Real%20Time%20Drivers%20AUTOSAR%20R21-11%20Version%203.0.0%20and%20S32K1%20FreeRTOS%2010.5.1%3CBR%20%2F%3Eversion%202.0.0%20packages%20and%20I%20am%20using%20S32DS%203.6.3.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2166566%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Missing%20TCP%2FIP%20stack%20in%20example%20project%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2166566%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F254540%22%20target%3D%22_blank%22%3E%40sergioGeronimo%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%0A%3CP%3EThis%20is%20caused%20by%20a%20mismatch%20in%20manifest%20SDK%20version%20between%20RTD%203.0.0%20(%3CSTRONG%3Eversion%202.0.0%3C%2FSTRONG%3E)%20and%20TCP%2FIP%203.0.0%20(%3CSTRONG%3Eversion%203.0.0%3C%2FSTRONG%3E)%20releases.%3C%2FP%3E%0A%3CP%3ETo%20solve%20this%20please%20follow%20these%20steps%3A%3C%2FP%3E%0A%3CP%3E1.%20Go%20in%20S32DS%20installation%20folder%2C%20or%20the%20equivalent%20path%20for%20your%20machine.%3C%2FP%3E%0A%3CP%3E%3CEM%3EC%3A%5CNXP%5CS32DS.3.6.1%5CS32DS%5Csoftware%5CPlatformSDK_S32K1_S32M24%3C%2FEM%3E%3C%2FP%3E%0A%3CP%3E2.%20Open%20the%26nbsp%3B%3CSTRONG%3Etcpip_itm_manifest.xml%26nbsp%3B%3C%2FSTRONG%3Eand%20change%20the%20version%20from%203.0.0%20to%202.0.0%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22PavelL_0-1757499391080.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22PavelL_0-1757499391080.png%22%20style%3D%22width%3A%20397px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F356233i7695E3290C4ECA2E%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22PavelL_0-1757499391080.png%22%20alt%3D%22PavelL_0-1757499391080.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E3.%20Restart%20S32DS%3C%2FP%3E%0A%3CP%3E4.%20Open%20peripheral%20view%20and%20run%20%22Update%20Code%22%3C%2FP%3E%0A%3CP%3E5.%20run%20Build%20again%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBest%20regards%2C%3C%2FP%3E%0A%3CP%3EPavel%3C%2FP%3E%3C%2FLINGO-BODY%3E
