MCSPTE1AK344 code generation
3,181件の閲覧回数
Albatros
I tried to generate the MCSPTE1AK344_PMSM_FOC_2Sh_as_tr code from S32DS peripherals and I can see that my motor is working properly in debug mode but when I am done with the debug mode my motor stops working. What causing this problem?
タグ(3)
3,099件の閲覧回数
tomasfedor
I have 2 points:
1) verify steps from getting started  https://www.nxp.com/document/guide/get-started-with-the-mcspte1ak344-development-kit:GS-MCSPTE1AK344
and I also recommend S32K3 Motor Control Training. You can find there detailed explanation as well as hands on part starting at 33:00 https://www.nxp.com/design/training/s32k3-motor-control-training:TIP-S32K3-MOT-CNT
2) if fault appears you can clear the fault by pressings SW5 and SW6 simultaneously or you can clear fault using MCAT (see  "5. FreeMASTER and MCAT user interface" in AN13884 or AN13767).
details about the fault can be found in FreeMASTER tab "Faults & Trips"
Tomas Fedor
3 返答(返信)
3,137件の閲覧回数
tomasfedor
if you want to leave debugging with running target I recommend to use
instead of
Tomas Fedor
3,127件の閲覧回数
Albatros
Okay, it worked, but when I reset my board, my motor was not working again. Do you have any other suggestions?
3,100件の閲覧回数
tomasfedor
I have 2 points:
Tomas Fedor
