MCSPTE1AK144_BLDC_6Step with hall sensor feedback
1,341 次查看
sarwath
Hello Community,
I am working on the BLDC motor controlling by Hall sensor feedback. I download the NXP sample code for the same. In actuate_s32k.c file, the 6 step commutation is given. my doubt is  for this comutation ui8FTM3OutmaskVal[0][0] and ui16FTM3SwOctrlVal[0][0] which two channel PWM is driven among 6 channels. How to find the channel with commutation input.
Thanks in advance,
Sarwath
标记 (2)
3 回复数
1,334 次查看
Senlent
Hi@sarwath
please take a look at this document.
The chapter :4.2.2. FlexTimer Module (FTM)
https://www.nxp.com.cn/docs/en/application-note/AN12435.pdf
1,328 次查看
sarwath
Hello Senlent,
I want the doc for the Sensor based control technique with the Hall sensor feedback.
Where can I get the above doc.
Sarwath
1,324 次查看
Senlent
Hi@sarwath
I didn't find any such article, about hall seneor there is only some description in chapter 4.2.2.3 of AN12435
