Ld error: MCSPTE1AK144_BLDC_6Step.elf section `.text'
已解决
跳至解决方案
2,807 次查看
sarwath
Hello Community,
During Build All I am getting this .text error.
Can anyone help me to resolve this.
Sarwath
1 解答
2,794 次查看
Robin_Shen
Hi sarwath,
Do not Build All, please build FLASH. (RAM space is not big enough.)
Robin
在原帖中查看解决方案
4 回复数
2,795 次查看
Robin_Shen
Hi sarwath,
Robin
2,785 次查看
sarwath
Hello robin,
If I do some modification in other file (not main.c), then I have to give Build All right ?
If I give only build FLASH how the modification reflect in final output.
BR,
Sarwath
2,779 次查看
Robin_Shen
No. Please read: HOWTO: Build a Project and Setup a Debug Configuration for debugging in S32 Design Studio
Hope it will let you know the difference.
2,776 次查看
sarwath
Thank you Robin
