LWIP TCP/IP Server-Client Hands-On
19,776 次查看
thosewhowish2b
I came across this cool PDF, apparently from a workshop about LWIP and Ethernet with S32K148 MCUs:
Hands-On Workshop: S32K148 Using ENET
It has a hands-on part, which relies on two example projects:
  1. lwip_s32k148_HandsOn_Server
  2. lwip_s32k148_HandsOn_Client
Unfortunately, I couldn't find these project anywhere.
Please, could NXP make these projects available somewhere? They seem to be really helpful.
19,758 次查看
PetrS
I have sent files to you directly.
Let me know if you have received it.
BR, Petr
24 回复数
1,156 次查看
ssattva1
Hi @PetrS , It will be very helpful if you could send those 2 projects as I am working on ethernet development .
My mail:  [email protected]
Thank you
6,098 次查看
liuweiliang
 can you sent files to me?I'm working on the 148+LWIP project.but, the SOCKET was not successfully debugged.thank you.
[email protected]
or
[email protected]
6,158 次查看
fshah30
I need the same files for MK64 FRDM Board.
lwIP client and Server.
Thank you,
6,096 次查看
thosewhowish2b
Hi there,
I have received the files.
Thanks so much!
Best regards.
