LPSPI read extra byte
2,569件の閲覧回数
rmaier
I am struggling with the LPSPI module on the S32K144. I want to send some bytes and receive some bytes of varying length. This works with the exception that I have to send an additional dummy byte. Let's say I want to Tx 2 bytes and Rx 2 bytes, I have to Tx a total of 5 bytes. What am I missing to only have to send 4 bytes to write/read 4 bytes?
Here's my function:
void Spi_Transceive(uint8_t txLen, uint8_t *txBuf, uint8_t rxLen, uint8_t *rxBuf, uint8_t module, uint8_t pcs)
    uint16_t total = rxLen + txLen - 1;
    uint32_t totalBytes = 0;
    const uint32_t tcr_base =
        LPSPI_TCR_FRAMESZ(7) | // 8-bit frames
        LPSPI_TCR_PCS(pcs) |
        LPSPI_TCR_CPOL(0) |
        LPSPI_TCR_CPHA(1) |
        LPSPI_TCR_PRESCALE(0) |
        LPSPI_TCR_WIDTH(0) |
        LPSPI_TCR_CONTC(1);
    LPSPI2->CR |= LPSPI_CR_RTF_MASK | LPSPI_CR_RRF_MASK;
    LPSPI2->SR = 0xFFFFFFFFu;
    LPSPI2->FCR = LPSPI_FCR_TXWATER(0) | LPSPI_FCR_RXWATER(0);
    while (!(LPSPI2->SR & LPSPI_SR_TDF_MASK))
    LPSPI2->TCR = tcr_base | LPSPI_TCR_CONT(1);
    LPSPI2->TDR = (uint8_t)txBuf[0];
    totalBytes++;
    for (uint8_t i = 1; i < txLen; i++)
        if (totalBytes == total)
            LPSPI2->TCR = tcr_base | LPSPI_TCR_CONT(0);
        LPSPI2->TDR = (uint8_t)txBuf[i];
        totalBytes++;
        while (!(LPSPI2->SR & LPSPI_SR_RDF_MASK))
        (void)LPSPI2->RDR;
    if (rxLen > 0)
        LPSPI2->TDR = 0x00; // NOP
        (void)LPSPI2->RDR;
    else
        return;
    for (uint8_t i = 0; i < rxLen; i++)
        totalBytes++;
        rxBuf[i] = (uint8_t)LPSPI2->RDR;
Here's the initialization:
    PCC->PCCn[PCC_LPSPI2_INDEX] = 0;                  /* Disable clocks to modify PCS ( default) 	*/
    PCC->PCCn[PCC_LPSPI2_INDEX] = PCC_PCCn_PR_MASK    /* (default) Peripheral is present.			*/
                                  | PCC_PCCn_CGC_MASK /* Enable PCS=SPLL_DIV2 (40 MHz func'l clock) 	*/
                                  | PCC_PCCn_PCS(6);
    LPSPI2->CR = 0x00000000;
    LPSPI2->IER = 0x00000000;
    LPSPI2->DER = 0x00000000;
    LPSPI2->CFGR0 = 0x00000000;
    LPSPI2->CFGR1 = LPSPI_CFGR1_MASTER_MASK | LPSPI_CFGR1_SAMPLE(1) | LPSPI_CFGR1_AUTOPCS(0) | LPSPI_CFGR1_PCSPOL(0b0000);
    LPSPI2->TCR = LPSPI_TCR_CPHA_MASK | LPSPI_TCR_PRESCALE(2) | LPSPI_TCR_PCS(0) | LPSPI_TCR_FRAMESZ(7) | LPSPI_TCR_CONT(1);
    LPSPI2->CCR = LPSPI_CCR_SCKPCS(4) | LPSPI_CCR_PCSSCK(4) | LPSPI_CCR_DBT(8) | LPSPI_CCR_SCKDIV(8);
    LPSPI2->FCR = LPSPI_FCR_TXWATER(3);
    LPSPI2->CR = LPSPI_CR_MEN_MASK | LPSPI_CR_DBGEN_MASK;
タグ(2)
2,449件の閲覧回数
PetrS
clear CONTC bit in TCR.
See attached main.c file I used in S32K144_Project_LPSPI demo.
It gives right frames. I tested below sequences
PetrS_0-1755679051074.pngPetrS_0-1755679051074.pngPetrS_1-1755679060431.pngPetrS_1-1755679060431.png
BR, Petr
4 返答(返信)
2,518件の閲覧回数
PetrS
for each write to TDR you should increment your totalBytes. For each TDR write there should be RDR reading. After CONT is cleared you should read RDR finally. Try below one, but I did not tested that.
    uint16_t total = rxLen + txLen;
        LPSPI_TCR_CPOL(0) |
        LPSPI_TCR_CPHA(1) |
        LPSPI_TCR_CONTC(1);
    if (txLen>0)
		while (!(LPSPI2->SR & LPSPI_SR_TDF_MASK));
		LPSPI2->TDR = *txBuf++;
		totalBytes++;
		while(totalBytes < txLen)
			totalBytes++;
			while (!(LPSPI2->SR & LPSPI_SR_RDF_MASK));
			(void)LPSPI2->RDR;
		if(rxLen==0)
			(void)LPSPI2->RDR;
    if (rxLen>0)
    	if(txLen==0) LPSPI2->TCR = tcr_base | LPSPI_TCR_CONT(1);
		totalBytes++;
		if(txLen>0)
			(void)LPSPI2->RDR;
     	while(totalBytes < total)
			totalBytes++;
			*rxBuf++ = LPSPI2->RDR;
 BR, Petr
2,470件の閲覧回数
rmaier
Hello Petr,
Thanks for your support. The first read attempt always stays forever in the while RDF mask loop. Even with your code. Any idea why?
if (rxLen == 0)
            while (!(LPSPI2->SR & LPSPI_SR_RDF_MASK)) // Stuck here on 1st read
            (void)LPSPI2->RDR;
2,450件の閲覧回数
PetrS
BR, Petr
2,423件の閲覧回数
rmaier
Thanks for your help, Petr.
タグ(2)
%3CLINGO-SUB%20id%3D%22lingo-sub-2152890%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ELPSPI%20%E8%BF%BD%E5%8A%A0%E3%83%90%E3%82%A4%E3%83%88%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2152890%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%3CBR%20%2F%3E%3CP%3ES32K144%20%E4%B8%8A%E3%81%AE%20LPSPI%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%AB%E8%8B%A6%E5%8A%B4%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E3%83%90%E3%82%A4%E3%83%88%E3%82%92%E9%80%81%E4%BF%A1%E3%81%97%E3%80%81%E3%81%95%E3%81%BE%E3%81%96%E3%81%BE%E3%81%AA%E9%95%B7%E3%81%95%E3%81%AE%E3%83%90%E3%82%A4%E3%83%88%E3%82%92%E5%8F%97%E4%BF%A1%E3%81%97%E3%81%9F%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81%E8%BF%BD%E5%8A%A0%E3%81%AE%E3%83%80%E3%83%9F%E3%83%BC%20%E3%83%90%E3%82%A4%E3%83%88%E3%82%92%E9%80%81%E4%BF%A1%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%81%A8%E3%81%84%E3%81%86%E4%BE%8B%E5%A4%96%E3%82%92%E9%99%A4%E3%81%84%E3%81%A6%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%BE%E3%81%99%E3%80%822%20%E3%83%90%E3%82%A4%E3%83%88%E3%82%92%E9%80%81%E4%BF%A1%E3%81%97%E3%80%812%20%E3%83%90%E3%82%A4%E3%83%88%E3%82%92%E5%8F%97%E4%BF%A1%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81%E5%90%88%E8%A8%88%205%20%E3%83%90%E3%82%A4%E3%83%88%E3%82%92%E9%80%81%E4%BF%A1%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%824%20%E3%83%90%E3%82%A4%E3%83%88%E3%81%AE%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%2F%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%AB%204%20%E3%83%90%E3%82%A4%E3%83%88%E3%81%AE%E3%81%BF%E9%80%81%E4%BF%A1%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%81%AE%E3%81%AF%E3%81%AA%E3%81%9C%E3%81%A7%E3%81%99%E3%81%8B%3F%3CBR%20%2F%3E%3CBR%20%2F%3E%E7%A7%81%E3%81%AE%E9%96%A2%E6%95%B0%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%3A%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%20translate%3D%22no%22%3Evoid%20Spi_Transceive(uint8_t%20txLen%2C%20uint8_t%20*txBuf%2C%20uint8_t%20rxLen%2C%20uint8_t%20*rxBuf%2C%20uint8_t%20module%2C%20uint8_t%20pcs)%0A%7B%0A%0A%20%20%20%20uint16_t%20total%20%3D%20rxLen%20%2B%20txLen%20-%201%3B%0A%20%20%20%20uint32_t%20totalBytes%20%3D%200%3B%0A%20%20%20%20const%20uint32_t%20tcr_base%20%3D%0A%20%20%20%20%20%20%20%20LPSPI_TCR_FRAMESZ(7)%20%7C%20%2F%2F%208-bit%20frames%0A%20%20%20%20%20%20%20%20LPSPI_TCR_PCS(pcs)%20%7C%0A%20%20%20%20%20%20%20%20LPSPI_TCR_CPOL(0)%20%7C%20%0A%20%20%20%20%20%20%20%20LPSPI_TCR_CPHA(1)%20%7C%0A%20%20%20%20%20%20%20%20LPSPI_TCR_PRESCALE(0)%20%7C%0A%20%20%20%20%20%20%20%20LPSPI_TCR_WIDTH(0)%20%7C%0A%20%20%20%20%20%20%20%20LPSPI_TCR_CONTC(1)%3B%0A%0A%20%20%20%20LPSPI2-%26gt%3BCR%20%7C%3D%20LPSPI_CR_RTF_MASK%20%7C%20LPSPI_CR_RRF_MASK%3B%0A%20%20%20%20LPSPI2-%26gt%3BSR%20%3D%200xFFFFFFFFu%3B%0A%20%20%20%20LPSPI2-%26gt%3BFCR%20%3D%20LPSPI_FCR_TXWATER(0)%20%7C%20LPSPI_FCR_RXWATER(0)%3B%0A%0A%20%20%20%20while%20(!(LPSPI2-%26gt%3BSR%20%26amp%3B%20LPSPI_SR_TDF_MASK))%0A%20%20%20%20%20%20%20%20%3B%0A%20%20%20%20LPSPI2-%26gt%3BTCR%20%3D%20tcr_base%20%7C%20LPSPI_TCR_CONT(1)%3B%0A%20%20%20%20LPSPI2-%26gt%3BTDR%20%3D%20(uint8_t)txBuf%5B0%5D%3B%0A%20%20%20%20totalBytes%2B%2B%3B%0A%0A%20%20%20%20for%20(uint8_t%20i%20%3D%201%3B%20i%20%26lt%3B%20txLen%3B%20i%2B%2B)%0A%20%20%20%20%7B%0A%20%20%20%20%20%20%20%20if%20(totalBytes%20%3D%3D%20total)%0A%20%20%20%20%20%20%20%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20LPSPI2-%26gt%3BTCR%20%3D%20tcr_base%20%7C%20LPSPI_TCR_CONT(0)%3B%0A%20%20%20%20%20%20%20%20%7D%0A%0A%20%20%20%20%20%20%20%20while%20(!(LPSPI2-%26gt%3BSR%20%26amp%3B%20LPSPI_SR_TDF_MASK))%0A%20%20%20%20%20%20%20%20%20%20%20%20%3B%0A%0A%20%20%20%20%20%20%20%20LPSPI2-%26gt%3BTDR%20%3D%20(uint8_t)txBuf%5Bi%5D%3B%0A%20%20%20%20%20%20%20%20totalBytes%2B%2B%3B%0A%0A%20%20%20%20%20%20%20%20while%20(!(LPSPI2-%26gt%3BSR%20%26amp%3B%20LPSPI_SR_RDF_MASK))%0A%20%20%20%20%20%20%20%20%20%20%20%20%3B%0A%20%20%20%20%20%20%20%20(void)LPSPI2-%26gt%3BRDR%3B%0A%20%20%20%20%7D%0A%0A%20%20%20%20if%20(rxLen%20%26gt%3B%200)%0A%20%20%20%20%7B%0A%20%20%20%20%20%20%20%20while%20(!(LPSPI2-%26gt%3BSR%20%26amp%3B%20LPSPI_SR_TDF_MASK))%0A%20%20%20%20%20%20%20%20%20%20%20%20%3B%0A%20%20%20%20%20%20%20%20LPSPI2-%26gt%3BTDR%20%3D%200x00%3B%20%2F%2F%20NOP%0A%20%20%20%20%20%20%20%20while%20(!(LPSPI2-%26gt%3BSR%20%26amp%3B%20LPSPI_SR_RDF_MASK))%0A%20%20%20%20%20%20%20%20%20%20%20%20%3B%0A%20%20%20%20%20%20%20%20(void)LPSPI2-%26gt%3BRDR%3B%0A%20%20%20%20%7D%0A%20%20%20%20else%0A%20%20%20%20%7B%0A%20%20%20%20%20%20%20%20return%3B%0A%20%20%20%20%7D%0A%0A%20%20%20%20for%20(uint8_t%20i%20%3D%200%3B%20i%20%26lt%3B%20rxLen%3B%20i%2B%2B)%0A%20%20%20%20%7B%0A%20%20%20%20%20%20%20%20if%20(totalBytes%20%3D%3D%20total)%0A%20%20%20%20%20%20%20%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20LPSPI2-%26gt%3BTCR%20%3D%20tcr_base%20%7C%20LPSPI_TCR_CONT(0)%3B%0A%20%20%20%20%20%20%20%20%7D%0A%20%20%20%20%20%20%20%20while%20(!(LPSPI2-%26gt%3BSR%20%26amp%3B%20LPSPI_SR_TDF_MASK))%0A%20%20%20%20%20%20%20%20%20%20%20%20%3B%0A%0A%20%20%20%20%20%20%20%20LPSPI2-%26gt%3BTDR%20%3D%200x00%3B%20%2F%2F%20NOP%0A%20%20%20%20%20%20%20%20totalBytes%2B%2B%3B%0A%0A%20%20%20%20%20%20%20%20while%20(!(LPSPI2-%26gt%3BSR%20%26amp%3B%20LPSPI_SR_RDF_MASK))%0A%20%20%20%20%20%20%20%20%20%20%20%20%3B%0A%20%20%20%20%20%20%20%20rxBuf%5Bi%5D%20%3D%20(uint8_t)LPSPI2-%26gt%3BRDR%3B%0A%20%20%20%20%7D%0A%7D%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3E%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%20translate%3D%22no%22%3E%20%20%20%20PCC-%26gt%3BPCCn%5BPCC_LPSPI2_INDEX%5D%20%3D%200%3B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%2F*%20Disable%20clocks%20to%20modify%20PCS%20(%20default)%20%09*%2F%0A%20%20%20%20PCC-%26gt%3BPCCn%5BPCC_LPSPI2_INDEX%5D%20%3D%20PCC_PCCn_PR_MASK%20%20%20%20%2F*%20(default)%20Peripheral%20is%20present.%09%09%09*%2F%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%7C%20PCC_PCCn_CGC_MASK%20%2F*%20Enable%20PCS%3DSPLL_DIV2%20(40%20MHz%20func'l%20clock)%20%09*%2F%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%7C%20PCC_PCCn_PCS(6)%3B%0A%0A%20%20%20%20LPSPI2-%26gt%3BCR%20%3D%200x00000000%3B%20%20%20%20%0A%20%20%20%20LPSPI2-%26gt%3BIER%20%3D%200x00000000%3B%20%20%20%0A%20%20%20%20LPSPI2-%26gt%3BDER%20%3D%200x00000000%3B%20%20%0A%20%20%20%20LPSPI2-%26gt%3BCFGR0%20%3D%200x00000000%3B%20%0A%20%20%20%20LPSPI2-%26gt%3BCFGR1%20%3D%20LPSPI_CFGR1_MASTER_MASK%20%7C%20LPSPI_CFGR1_SAMPLE(1)%20%7C%20LPSPI_CFGR1_AUTOPCS(0)%20%7C%20LPSPI_CFGR1_PCSPOL(0b0000)%3B%20%0A%0A%20%20%20%20LPSPI2-%26gt%3BTCR%20%3D%20LPSPI_TCR_CPHA_MASK%20%7C%20LPSPI_TCR_PRESCALE(2)%20%7C%20LPSPI_TCR_PCS(0)%20%7C%20LPSPI_TCR_FRAMESZ(7)%20%7C%20LPSPI_TCR_CONT(1)%3B%0A%0A%20%20%20%20LPSPI2-%26gt%3BCCR%20%3D%20LPSPI_CCR_SCKPCS(4)%20%7C%20LPSPI_CCR_PCSSCK(4)%20%7C%20LPSPI_CCR_DBT(8)%20%7C%20LPSPI_CCR_SCKDIV(8)%3B%20%0A%20%20%20%20LPSPI2-%26gt%3BFCR%20%3D%20LPSPI_FCR_TXWATER(3)%3B%20%0A%20%20%20%20LPSPI2-%26gt%3BCR%20%3D%20LPSPI_CR_MEN_MASK%20%7C%20LPSPI_CR_DBGEN_MASK%3B%20%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%26nbsp%3B%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2156154%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LPSPI%20read%20extra%20byte%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2156154%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%8A%A9%E3%81%91%E3%81%A6%E3%81%8F%E3%82%8C%E3%81%A6%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%81%E3%83%9A%E3%83%88%E3%83%AB%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2155092%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LPSPI%20read%20extra%20byte%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2155092%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%0A%3CP%3ETCR%20%E3%81%AE%20CONTC%20%E3%83%93%E3%83%83%E3%83%88%E3%82%92%E3%82%AF%E3%83%AA%E3%82%A2%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E6%B7%BB%E4%BB%98%E3%81%AEmain.c%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82S32K144_Project_LPSPI%20%E3%83%87%E3%83%A2%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%82%3CBR%20%2F%3E%E6%AD%A3%E3%81%97%E3%81%84%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%B7%E3%83%BC%E3%82%B1%E3%83%B3%E3%82%B9%E3%82%92%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22PetrS_0-1755679051074.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22PetrS_0-1755679051074.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F353245iD13120E3F257AAE8%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22PetrS_0-1755679051074.png%22%20alt%3D%22PetrS_0-1755679051074.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPetrS_0-1755679051074.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22PetrS_1-1755679060431.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22PetrS_1-1755679060431.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F353246iACAB54CAA732EA52%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22PetrS_1-1755679060431.png%22%20alt%3D%22PetrS_1-1755679060431.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPetrS_1-1755679060431.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EBR%E3%80%81%E3%83%9A%E3%83%88%E3%83%AB%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2154465%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LPSPI%20read%20extra%20byte%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2154465%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EPetr%E6%A7%98%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E6%9C%80%E5%88%9D%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E8%A9%A6%E8%A1%8C%E3%81%AF%E3%80%81RDF%20%E3%83%9E%E3%82%B9%E3%82%AF%20%E3%83%AB%E3%83%BC%E3%83%97%E3%81%AE%E9%96%93%E4%B8%AD%E3%80%81%E5%B8%B8%E3%81%AB%E6%B0%B8%E4%B9%85%E3%81%AB%E7%B6%99%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%E3%81%A7%E3%81%82%E3%81%A3%E3%81%A6%E3%82%82%E3%80%82%E7%90%86%E7%94%B1%E3%81%8C%E5%88%86%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%20translate%3D%22no%22%3Eif%20(rxLen%20%3D%3D%200)%0A%20%20%20%20%20%20%20%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20LPSPI2-%26gt%3BTCR%20%3D%20tcr_base%20%7C%20LPSPI_TCR_CONT(0)%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20while%20(!(LPSPI2-%26gt%3BSR%20%26amp%3B%20LPSPI_SR_RDF_MASK))%20%2F%2F%20Stuck%20here%20on%201st%20read%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20(void)LPSPI2-%26gt%3BRDR%3B%0A%20%20%20%20%20%20%20%20%7D%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2153659%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LPSPI%20read%20extra%20byte%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2153659%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%0A%3CP%3ETDR%20%E3%81%B8%E3%81%AE%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%81%94%E3%81%A8%E3%81%AB%E3%80%81totalBytes%20%E3%82%92%E5%A2%97%E3%82%84%E3%81%99%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E5%90%84%20TDR%20%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%81%94%E3%81%A8%E3%81%AB%20RDR%20%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%80%82CONT%20%E3%81%8C%E3%82%AF%E3%83%AA%E3%82%A2%E3%81%95%E3%82%8C%E3%81%9F%E3%82%89%E3%80%81%E6%9C%80%E5%BE%8C%E3%81%AB%20RDR%20%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E4%BB%A5%E4%B8%8B%E3%82%92%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%E7%A7%81%E3%81%AF%E3%81%9D%E3%82%8C%E3%82%92%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Evoid%20Spi_Transceive(uint8_t%20txLen%2C%20uint8_t%20*txBuf%2C%20uint8_t%20rxLen%2C%20uint8_t%20*rxBuf%2C%20uint8_t%20module%2C%20uint8_t%20pcs)%0A%7B%0A%0A%20%20%20%20uint16_t%20total%20%3D%20rxLen%20%2B%20txLen%3B%0A%20%20%20%20uint32_t%20totalBytes%20%3D%200%3B%0A%20%20%20%20const%20uint32_t%20tcr_base%20%3D%0A%20%20%20%20%20%20%20%20LPSPI_TCR_FRAMESZ(7)%20%7C%20%2F%2F%208-bit%20frames%0A%20%20%20%20%20%20%20%20LPSPI_TCR_PCS(pcs)%20%7C%0A%20%20%20%20%20%20%20%20LPSPI_TCR_CPOL(0)%20%7C%20%0A%20%20%20%20%20%20%20%20LPSPI_TCR_CPHA(1)%20%7C%0A%20%20%20%20%20%20%20%20LPSPI_TCR_PRESCALE(0)%20%7C%0A%20%20%20%20%20%20%20%20LPSPI_TCR_WIDTH(0)%20%7C%0A%20%20%20%20%20%20%20%20LPSPI_TCR_CONTC(1)%3B%0A%0A%20%20%20%20LPSPI2-%26gt%3BCR%20%7C%3D%20LPSPI_CR_RTF_MASK%20%7C%20LPSPI_CR_RRF_MASK%3B%0A%20%20%20%20LPSPI2-%26gt%3BSR%20%3D%200xFFFFFFFFu%3B%0A%20%20%20%20LPSPI2-%26gt%3BFCR%20%3D%20LPSPI_FCR_TXWATER(0)%20%7C%20LPSPI_FCR_RXWATER(0)%3B%0A%0A%20%20%20%20if%20(txLen%26gt%3B0)%0A%09%7B%0A%20%20%20%20%09LPSPI2-%26gt%3BTCR%20%3D%20tcr_base%20%7C%20LPSPI_TCR_CONT(1)%3B%0A%09%09while%20(!(LPSPI2-%26gt%3BSR%20%26amp%3B%20LPSPI_SR_TDF_MASK))%3B%0A%09%09LPSPI2-%26gt%3BTDR%20%3D%20*txBuf%2B%2B%3B%0A%09%09totalBytes%2B%2B%3B%0A%09%09while(totalBytes%20%26lt%3B%20txLen)%0A%09%09%7B%0A%09%09%09while%20(!(LPSPI2-%26gt%3BSR%20%26amp%3B%20LPSPI_SR_TDF_MASK))%3B%0A%09%09%09LPSPI2-%26gt%3BTDR%20%3D%20*txBuf%2B%2B%3B%0A%09%09%09totalBytes%2B%2B%3B%0A%09%09%09while%20(!(LPSPI2-%26gt%3BSR%20%26amp%3B%20LPSPI_SR_RDF_MASK))%3B%0A%09%09%09(void)LPSPI2-%26gt%3BRDR%3B%0A%09%09%7D%0A%09%09if(rxLen%3D%3D0)%20%0A%09%09%7B%0A%09%09%09LPSPI2-%26gt%3BTCR%20%3D%20tcr_base%20%7C%20LPSPI_TCR_CONT(0)%3B%0A%09%09%09while%20(!(LPSPI2-%26gt%3BSR%20%26amp%3B%20LPSPI_SR_RDF_MASK))%3B%0A%09%09%09(void)LPSPI2-%26gt%3BRDR%3B%0A%09%09%7D%0A%09%09%0A%09%7D%0A%20%20%20%20%0A%20%20%20%20if%20(rxLen%26gt%3B0)%0A%20%20%20%20%7B%0A%20%20%20%20%09if(txLen%3D%3D0)%20LPSPI2-%26gt%3BTCR%20%3D%20tcr_base%20%7C%20LPSPI_TCR_CONT(1)%3B%0A%09%09while%20(!(LPSPI2-%26gt%3BSR%20%26amp%3B%20LPSPI_SR_TDF_MASK))%3B%0A%09%09LPSPI2-%26gt%3BTDR%20%3D%200x00%3B%20%2F%2F%20NOP%0A%09%09totalBytes%2B%2B%3B%0A%09%09if(txLen%26gt%3B0)%0A%09%09%7B%0A%09%09%09while%20(!(LPSPI2-%26gt%3BSR%20%26amp%3B%20LPSPI_SR_RDF_MASK))%3B%0A%09%09%09(void)LPSPI2-%26gt%3BRDR%3B%0A%20%20%20%20%09%7D%0A%20%20%20%20%20%09while(totalBytes%20%26lt%3B%20total)%0A%09%09%7B%0A%20%20%20%20%09%09while%20(!(LPSPI2-%26gt%3BSR%20%26amp%3B%20LPSPI_SR_TDF_MASK))%3B%0A%20%20%20%20%09%09LPSPI2-%26gt%3BTDR%20%3D%200x00%3B%20%2F%2F%20NOP%0A%09%09%09totalBytes%2B%2B%3B%0A%09%09%09while%20(!(LPSPI2-%26gt%3BSR%20%26amp%3B%20LPSPI_SR_RDF_MASK))%3B%0A%09%09%09*rxBuf%2B%2B%20%3D%20LPSPI2-%26gt%3BRDR%3B%0A%09%09%7D%0A%20%20%20%20%09LPSPI2-%26gt%3BTCR%20%3D%20tcr_base%20%7C%20LPSPI_TCR_CONT(0)%3B%0A%09%09while%20(!(LPSPI2-%26gt%3BSR%20%26amp%3B%20LPSPI_SR_RDF_MASK))%3B%0A%09%09*rxBuf%2B%2B%20%3D%20LPSPI2-%26gt%3BRDR%3B%0A%20%20%20%20%7D%0A%09%0A%7D%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%3EBR%E3%80%81%E3%83%9A%E3%83%88%E3%83%AB%3C%2FP%3E%3C%2FLINGO-BODY%3E
