LPIT0
LPIT0
Bhuvana
void Timer_0_Initilization(void)
status_t status;
lpit1_ChnConfig0.period =80000;
LPIT_DRV_Init(INST_LPIT_CONFIG_1, &lpit1_InitConfig);
status = LPIT_DRV_InitChannel(INST_LPIT_CONFIG_1, LPIT_CHANNEL, &lpit1_ChnConfig0);
DEV_ASSERT(status == STATUS_SUCCESS);
INT_SYS_InstallHandler(LPIT_Channel_IRQn, &LPIT_ISR, NULL);
void Timer_0_Start(void)
LPIT_DRV_StartTimerChannels(INST_LPIT_CONFIG_1, (1 << LPIT_CHANNEL));
void Timer_1_Initilization(unsigned int period_count)
status_t status;
lpit1_ChnConfig0.period =period_count;
status = LPIT_DRV_InitChannel(INST_LPIT_CONFIG_1, LPIT_CHANNEL1, &lpit1_ChnConfig1);
INT_SYS_InstallHandler(LPIT_Channel1_IRQn, &LPIT_ISR1, NULL);
void Timer_1_Start()
LPIT_DRV_StartTimerChannels(INST_LPIT_CONFIG_1, (1 << LPIT_CHANNEL1));
void Timer_2_Initilization(void)
status_t status;
status = LPIT_DRV_InitChannel(INST_LPIT_CONFIG_1, LPIT_CHANNEL2, &lpit1_ChnConfig2);
INT_SYS_InstallHandler(LPIT_Channel2_IRQn, &LPIT_ISR2, NULL);
void Timer_2_Start(void)
LPIT_DRV_StartTimerChannels(INST_LPIT_CONFIG_1, (1 << LPIT_CHANNEL2));
void Timer_3_Initilization(void)
status_t status;
status = LPIT_DRV_InitChannel(INST_LPIT_CONFIG_1, LPIT_CHANNEL3, &lpit1_ChnConfig3);
INT_SYS_InstallHandler(LPIT_Channel3_IRQn, &LPIT_ISR3, NULL);
void Timer_3_Start(void)
LPIT_DRV_StartTimerChannels(INST_LPIT_CONFIG_1, (1 << LPIT_CHANNEL3));
void Timer_Initialization(void)
Timer_0_Initilization();
Timer_1_Initilization(16000000);
Timer_2_Initilization();
Timer_3_Initilization();
int main()
Timer_Initialization();
Timer_3_Start();
if I do like this below its not working,
int main()
Timer_0_Start();
or
Timer_1_Start();
or
Timer_2_Start();
like this I'm using its working fine but, In Timer_Initilization() function I have initialized Timer_3_Initilization(); last so if i call timer_3_start() its working in this same situation if i call  timer_0 or1,2_nitilization(); its not working... whatever i have initialized last its related start if i call only its  working. why?
I have attached timer configuration also
/* lPIT global configuration */
const lpit_user_config_t lpit1_InitConfig = {
.enableRunInDebug = false,
.enableRunInDoze = false
/* Channel configuration 0*/
lpit_user_channel_config_t lpit1_ChnConfig0 = {
.timerMode = LPIT_PERIODIC_COUNTER,
.periodUnits = LPIT_PERIOD_UNITS_COUNTS,
.period = 8000UL,
.triggerSource = LPIT_TRIGGER_SOURCE_INTERNAL,
.triggerSelect = 0U,
.enableReloadOnTrigger = false,
.enableStopOnInterrupt = false,
.enableStartOnTrigger = false,
.chainChannel = false,
.isInterruptEnabled = true
/* Channel configuration 1*/
lpit_user_channel_config_t lpit1_ChnConfig1 = {
.period = 80000UL,
.triggerSelect = 1U,
/* Channel configuration 2*/
lpit_user_channel_config_t lpit1_ChnConfig2 = {
.period = 6400UL,
.triggerSelect = 2U,
/* Channel configuration 3*/
lpit_user_channel_config_t lpit1_ChnConfig3 = {
.period = 5600UL,
.triggerSelect = 3U,
everyone is different channel , then it should work na.. otherwise I need to call timer initialize for every timer start how to avoid it?
Robin_Shen
Hi Bhuvana,
I'm not sure if I understand your question.
Do you mean this works:
int main()
Timer_3_Start();
But below code not work:
int main()
Timer_0_Start();
or
Timer_1_Start();
or
Timer_2_Start();
Please refer to the description of LPIT_StartTimerChannels to check whether the input parameters(mask) of LPIT_DRV_StartTimerChannels match the description.
Robin
Bhuvana
Hi @Robin_Shen
I have attached my project file in this before while(1) Timer_3_Initilization(); is there so if I call Timer_3_Start(); its working but instead of Timer_3_Start() if I call Timer_0_Start() why its not working. If I call Timer_0_Initilization(); next line Timer_0_Start() that time its working.
so whatever I have Initialize finally that related timer start only working. how to avoid it?
Robin_Shen
You don't need to call LPIT_DRV_Init in each channel initializes function.
Please check if each channel is able to run.
Bhuvana
@Robin_Shen Hi sir I have tried after removing LPIT_DRV_INIT() from every initialization now its working fine. Thanks for your guidance
Robin_Shen
You are welcome!
I am glad to hear that it works now.
