Key Import HSE API
3,448件の閲覧回数
ale_di_vi
Hi, I have a question regarding cryptographic keys stored inside the NVM of HSE_B module.
Is it possible to update these keys from the context of the application running on host microcontroller using  "Key import" API of the HSE (chapter 7.2.3 of the HSE_B Firmware Reference Manual Rev. 2.1 11/2022)?
In case it can be useful, the microcontroller used is MWCT2015S.
Thank you in advance
3,410件の閲覧回数
lukaszadrapa
Hi @ale_di_vi
Yes, the keys can be updated by application running on the microcontroller. You can take a look at HSE_DEMOAPP for details.
Lukas
2 返答(返信)
3,411件の閲覧回数
lukaszadrapa
Hi @ale_di_vi
Lukas
3,389件の閲覧回数
ale_di_vi
Ok, clear. Thank you!
