Key Catalogs in S32K344
1,422 次查看
silvia_zandoli2
Hello, I'm doing a crypto test in Basic Secure Boot. I attach main.c file
At this point
rsp = HSE_ECC_ComputeSecretAndSetAes(peerPubKey);
if (rsp != HSE_SRV_RSP_OK) while (1);
it goes into while (1) because rsp has error code 0x55A5A399
Maybe the problem is how I am formatting key catalogs
标记 (2)
1,322 次查看
lukaszadrapa
Hi @silvia_zandoli2
I can't see HSE_ECC_ComputeSecretAndSetAes function in your code. And such function is not present in the HSE framework.
Lukas
1,197 次查看
silvia_zandoli2
Hello, that function si defined by myself.
I report the definition. The code of the function is in the attached file. Thank you
The HSE_ECC_ComputeSecretAndSetAes function orchestrates the secure key exchange protocol. It first imports the external Peer Public Key into the HSE secure memory. Subsequently, it triggers the ECDH (Elliptic Curve Diffie-Hellman) algorithm to calculate a Shared Secret using the device's internal private key. Finally, it derives a usable 128-bit AES Session Key from this secret, which remains locked inside the HSE for secure data encryption and decryption.
%3CLINGO-SUB%20id%3D%22lingo-sub-2265311%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32K344%20%E7%9A%84%E4%B8%BB%E8%A6%81%E4%BA%A7%E5%93%81%E7%9B%AE%E5%BD%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2265311%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E6%88%91%E6%AD%A3%E5%9C%A8%E5%9F%BA%E6%9C%AC%E5%AE%89%E5%85%A8%E5%90%AF%E5%8A%A8%E4%B8%AD%E8%BF%9B%E8%A1%8C%E5%8A%A0%E5%AF%86%E6%B5%8B%E8%AF%95%E3%80%82%E9%99%84%E4%B8%8A%20main.c%E6%96%87%E4%BB%B6%3CBR%20%2F%3E%E6%AD%A4%E6%97%B6%3CBR%20%2F%3Ersp%20%3D%20HSE_ECC_ComputeSecretAndSetAes(peerPubKey)%3B%3CBR%20%2F%3Eif%20(rsp%20!%3D%20HSE_SRV_RSP_OK)%20while%20(1)%EF%BC%9B%3C%2FP%3E%3CP%3E%E8%BF%9B%E5%85%A5%20while%20(1)%EF%BC%8C%E5%9B%A0%E4%B8%BA%20rsp%20%E6%9C%89%E9%94%99%E8%AF%AF%E4%BB%A3%E7%A0%81%3CSPAN%3E0x55A5A399%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E4%B9%9F%E8%AE%B8%E9%97%AE%E9%A2%98%E5%87%BA%E5%9C%A8%E6%88%91%E5%A6%82%E4%BD%95%E6%A0%BC%E5%BC%8F%E5%8C%96%E5%85%B3%E9%94%AE%E7%9B%AE%E5%BD%95%E4%B8%8A%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2266567%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Key%20Catalogs%20in%20S32K344%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2266567%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F248858%22%20target%3D%22_blank%22%3E%40silvia_zandoli2%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%88%91%E5%9C%A8%E4%BD%A0%E7%9A%84%E4%BB%A3%E7%A0%81%E4%B8%AD%E7%9C%8B%E4%B8%8D%E5%88%B0%20HSE_ECC_ComputeSecretAndSetAes%20%E5%87%BD%E6%95%B0%E3%80%82%E8%80%8C%20HSE%20%E6%A1%86%E6%9E%B6%E4%B8%AD%E5%B9%B6%E6%B2%A1%E6%9C%89%E8%BF%99%E7%A7%8D%E5%8A%9F%E8%83%BD%E3%80%82%20%3C%2FP%3E%0A%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%0A%3CP%3ELukas%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2268254%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Key%20Catalogs%20in%20S32K344%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2268254%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E8%BF%99%E4%B8%AA%E5%87%BD%E6%95%B0%E6%98%AF%E6%88%91%E8%87%AA%E5%B7%B1%E5%AE%9A%E4%B9%89%E7%9A%84%E3%80%82%3CBR%20%2F%3E%E6%88%91%E6%8A%A5%E5%91%8A%E4%BA%86%E5%AE%9A%E4%B9%89%E3%80%82%E5%87%BD%E6%95%B0%E4%BB%A3%E7%A0%81%E8%A7%81%E9%99%84%E4%BB%B6%E3%80%82%E8%B0%A2%E8%B0%A2%3CBR%20%2F%3E%3CSTRONG%3EHSE_ECC_ComputeSecretAndSetAes%3C%2FSTRONG%3E%E5%87%BD%E6%95%B0%E8%B4%9F%E8%B4%A3%E5%8D%8F%E8%B0%83%E5%AE%89%E5%85%A8%E5%AF%86%E9%92%A5%E4%BA%A4%E6%8D%A2%E5%8D%8F%E8%AE%AE%E3%80%82%E5%AE%83%E9%A6%96%E5%85%88%E5%B0%86%E5%A4%96%E9%83%A8%E5%AF%B9%E7%AD%89%E5%85%AC%E5%BC%80%E5%AF%86%E9%92%A5%E5%AF%BC%E5%85%A5%20HSE%20%E5%AE%89%E5%85%A8%E5%AD%98%E5%82%A8%E5%99%A8%E3%80%82%E9%9A%8F%E5%90%8E%EF%BC%8C%E5%AE%83%E4%BC%9A%E8%A7%A6%E5%8F%91%E4%BF%A1%E5%8F%B7%20ECDH%EF%BC%88%E6%A4%AD%E5%9C%86%E6%9B%B2%E7%BA%BF%20Diffie-Hellman%EF%BC%89%E7%AE%97%E6%B3%95%EF%BC%8C%E4%BD%BF%E7%94%A8%E8%AE%BE%E5%A4%87%E7%9A%84%E5%86%85%E9%83%A8%E7%A7%81%E9%92%A5%E8%AE%A1%E7%AE%97%E5%85%B1%E4%BA%AB%E5%AF%86%E9%92%A5%E3%80%82%E6%9C%80%E5%90%8E%EF%BC%8C%E5%AE%83%E4%BB%8E%E8%AF%A5%E5%AF%86%E9%92%A5%E4%B8%AD%E6%8F%90%E5%8F%96%E5%87%BA%E5%8F%AF%E7%94%A8%E7%9A%84%20128%20%E4%BD%8D%20AES%20%E4%BC%9A%E8%AF%9D%E5%AF%86%E9%92%A5%EF%BC%8C%E5%B9%B6%E5%B0%86%E5%85%B6%E9%94%81%E5%AE%9A%E5%9C%A8%20HSE%20%E5%86%85%EF%BC%8C%E4%BB%A5%E7%A1%AE%E4%BF%9D%E6%95%B0%E6%8D%AE%E5%8A%A0%E5%AF%86%E5%92%8C%E8%A7%A3%E5%AF%86%E7%9A%84%E5%AE%89%E5%85%A8%E6%80%A7%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
