JA1101-RMII DEV Board software
ソリューションへジャンプ
2,059件の閲覧回数
Daryl_Popig
Are there any example projects available for the S32K3X4EVB-Q257 Dev Board to use the Ethernet ADTJA1101-RMII TJA1101 Adapter Card?
2,042件の閲覧回数
lukaszadrapa
you can install TCPIP stack:
https://www.nxp.com/webapp/swlicensing/sso/downloadSoftware.sp?catid=SW32K3-REFSW-D
There's an example which can use either TJA1100/1101 or DP83848.
Lukas
2,043件の閲覧回数
lukaszadrapa
Lukas
