JA1101-RMII DEV Board software
Daryl_Popig
Are there any example projects available for the S32K3X4EVB-Q257 Dev Board to use the Ethernet ADTJA1101-RMII TJA1101 Adapter Card?
lukaszadrapa
you can install TCPIP stack:
https://www.nxp.com/webapp/swlicensing/sso/downloadSoftware.sp?catid=SW32K3-REFSW-D
There's an example which can use either TJA1100/1101 or DP83848.
Lukas
lukaszadrapa
Lukas
