J-link debugging S32k3
2,629 次查看
chuanlin
Hello,Debugging S32K344 using J-LINK found that the program can be downloaded normally, but cannot be debugged online. But PEmicro debugging is fine.
2,609 次查看
VaneB
Hi @chuanlin
Does this happen if you try to debug an example?
Also, please check if the optimization level is set to none:
B.R.
VaneB
2,442 次查看
YXE
Hi VaneB any other solution to solve the problem? I also have the some problem.
2,557 次查看
BorisChen
I have got the same problem. I set the optimization level to “None” it doesn’t work.
标记 (1)
