Hello NXP Team,
I have an S32K311 microcontroller, and I am working on a bootloader.
I can erase sector 72, but when writing to it, the following error appears:
STATUS_C40_IP_ERROR
What is the solution to this issue?
S32K3
Hi @adem_marangoz,
STATUS_C40_IP_ERROR is not used in the latest RTD.
Which RTD version do you use?
Thank you,
BR, Daniel
Please specify the RTD version - like RTD 5.0.0, not the Autosar version.
Thank you
I don't know which older version of the RTD driver you use - so, I'm not able to look into it.
If I have the number of the specific RTD version, I can test it to verify the issue, I can also check for any previous reports with similar symptoms in that version.
