Is using one FCCU pin enough for ASIL D?
ソリューションへジャンプ
457件の閲覧回数
haythemLtifi
hello ,
I was wondering if using one FCCU pin is enough for the ASIL D or i have to use both?
I found this table in one of the presentation so i belive one pin is enough.
Also in case of the S32K3 MCU , does it support one FCCU pin or it has to be in pair bi stable ?
i found this in the application note AN14068 page 25 but its not clear to me :
FCCU monitoring by pair (bi-stable protocol)
When connected to the S32K3 MCU FCCU_ERR0 and FCCU_ERR1 pins, the FCCU1 and FCCU2 input
pins must be configured by pair to work in bi-stable protocol by default. This configuration cannot be changed
because the S32K3 only supports this protocol. The FCCU pins' polarity and the SBC reaction upon a fault can
be changed nonetheless.
The default settings for FCCU pins are configured as below:
• FCCU1 = 0 or FCCU2 = 1 is considered as a fault (can be reversed using FCCU12_FLT_POL bits)
• When a fault occurs, the impact can be configured on RSTB, FS0B, and LIMP0 (using FCCU12_[RSTB/
FS0B/LIMP0]_IMPACT)
thank you
タグ(5)
392件の閲覧回数
danielmartynek
Hello @haythemLtifi,
S32K3xx is a SEooC, therefore ASIL‑D applies to the complete system, not just the MCU.
ASIL‑D is possible with a single FCCU EOUT signal; however, this introduces a latent fault scenario on the safety path (e.g. the pin stuck at “no fault” due to a short to GND or VDD, depending on polarity).
Referring to the FMEDA (SM3.FCCU_MON), the justification assumes a high diagnostic coverage (~99%). This requires external monitoring, typically implemented by the SBC (e.g. FS26). When both FCCU EOUT signals are used and monitored in a bi‑stable (or fault‑toggle) configuration, the SBC can achieve the required diagnostic coverage. as it detects stuck‑at and line faults structurally. In contrast, when using a single FCCU signal, additional independent mechanisms are required to reach the same level of coverage.
393件の閲覧回数
danielmartynek
%3CLINGO-SUB%20id%3D%22lingo-sub-2360385%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EASIL%20D%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81FCCU%E3%83%94%E3%83%B3%E3%82%921%E6%9C%AC%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A0%E3%81%91%E3%81%A7%E5%8D%81%E5%88%86%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2360385%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%20%E3%80%81%3C%2FP%3E%3CP%3EASIL%20D%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81FCCU%E3%83%94%E3%83%B3%E3%82%921%E3%81%A4%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A0%E3%81%91%E3%81%A7%E5%8D%81%E5%88%86%E3%81%AA%E3%81%AE%E3%81%8B%E3%80%81%E3%81%9D%E3%82%8C%E3%81%A8%E3%82%82%E4%B8%A1%E6%96%B9%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%81%AE%E3%81%8B%E7%96%91%E5%95%8F%E3%81%AB%E6%80%9D%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E8%A1%A8%E3%81%AF%E3%83%97%E3%83%AC%E3%82%BC%E3%83%B3%E3%83%86%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E8%B3%87%E6%96%99%E3%81%AE%E4%B8%80%E3%81%A4%E3%81%A7%E8%A6%8B%E3%81%A4%E3%81%91%E3%81%9F%E3%81%AE%E3%81%A7%E3%80%81%E3%83%94%E3%83%B3%E3%81%AF%E4%B8%80%E3%81%A4%E3%81%A7%E5%8D%81%E5%88%86%E3%81%A0%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22haythemLtifi_0-1777974700032.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22haythemLtifi_0-1777974700032.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F384325iD2072D0E7FF35D32%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22haythemLtifi_0-1777974700032.png%22%20alt%3D%22haythemLtifi_0-1777974700032.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E3%81%BE%E3%81%9F%E3%80%81S32K3%20MCU%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81FCCU%E3%83%94%E3%83%B3%E3%81%AF1%E3%81%A4%E3%81%A0%E3%81%91%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%E3%80%81%E3%81%9D%E3%82%8C%E3%81%A8%E3%82%82%E5%8F%8C%E5%AE%89%E5%AE%9A%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AB%E3%83%9A%E3%82%A2%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%8E%E3%83%BC%E3%83%88AN14068%E3%81%AE25%E3%83%9A%E3%83%BC%E3%82%B8%E3%81%A7%E3%81%93%E3%82%8C%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%81%9F%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E3%82%88%E3%81%8F%E5%88%86%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3EFCCU%E3%81%AE%E3%83%9A%E3%82%A2%E3%81%AB%E3%82%88%E3%82%8B%E3%83%A2%E3%83%8B%E3%82%BF%E3%83%AA%E3%83%B3%E3%82%B0%EF%BC%88%E5%8F%8C%E5%AE%89%E5%AE%9A%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%EF%BC%89%3C%2FP%3E%3CP%3ES32K3%20MCU%E3%81%AEFCCU_ERR0%E3%83%94%E3%83%B3%E3%81%A8FCCU_ERR1%E3%83%94%E3%83%B3%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81FCCU1%E3%81%A8FCCU2%E3%81%AE%E5%85%A5%E5%8A%9B%E3%81%AF%3C%2FP%3E%3CP%3E%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%A7%E3%81%AF%E3%80%81%E5%8F%8C%E5%AE%89%E5%AE%9A%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%81%A7%E5%8B%95%E4%BD%9C%E3%81%95%E3%81%9B%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E3%83%94%E3%83%B3%E3%82%92%E3%83%9A%E3%82%A2%E3%81%94%E3%81%A8%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%AF%E5%A4%89%E6%9B%B4%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3ES32K3%E3%81%AF%E3%81%93%E3%81%AE%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%81%AE%E3%81%BF%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%9F%E3%82%81%E3%81%A7%E3%81%99%E3%80%82FCCU%E3%83%94%E3%83%B3%E3%81%AE%E6%A5%B5%E6%80%A7%E3%81%A8%E6%95%85%E9%9A%9C%E6%99%82%E3%81%AESBC%E3%81%AE%E5%8F%8D%E5%BF%9C%E3%81%AF%3C%2FP%3E%3CP%3E%E3%81%9D%E3%82%8C%E3%81%A7%E3%82%82%E5%A4%89%E6%9B%B4%E3%81%95%E3%82%8C%E3%82%8B%E3%81%A0%E3%82%8D%E3%81%86%E3%80%82%3C%2FP%3E%3CP%3EFCCU%E3%83%94%E3%83%B3%E3%81%AE%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E8%A8%AD%E5%AE%9A%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E2%80%A2%20FCCU1%20%3D%200%20%E3%81%BE%E3%81%9F%E3%81%AF%20FCCU2%20%3D%201%20%E3%81%AF%E6%95%85%E9%9A%9C%E3%81%A8%E3%81%BF%E3%81%AA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%EF%BC%88FCCU12_FLT_POL%20%E3%83%93%E3%83%83%E3%83%88%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E5%8F%8D%E8%BB%A2%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3E%E2%80%A2%20%E9%9A%9C%E5%AE%B3%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%80%81RSTB%E3%80%81FS0B%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3LIMP0%E3%81%B8%E3%81%AE%E5%BD%B1%E9%9F%BF%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%EF%BC%88FCCU12_%5BRSTB%2F%3C%2FP%3E%3CP%3EFS0B%2FLIMP0%5D_IMPACT)%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E7%94%B3%E3%81%97%E4%B8%8A%E3%81%92%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2360887%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Is%20using%20one%20FCCU%20pin%20enough%20for%20ASIL%20D%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2360887%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F258585%22%20target%3D%22_blank%22%3E%40haythemLtifi%20%E3%81%95%E3%82%93%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3ES32K3xx%E3%81%AFSEooC%E3%81%A7%E3%81%82%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81ASIL-D%E3%81%AFMCU%E3%81%A0%E3%81%91%E3%81%A7%E3%81%AA%E3%81%8F%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E5%85%A8%E4%BD%93%E3%81%AB%E9%81%A9%E7%94%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3EASIL-D%E3%81%AF%E5%8D%98%E4%B8%80%E3%81%AEFCCU%20EOUT%E4%BF%A1%E5%8F%B7%E3%81%A7%E5%AE%9F%E7%8F%BE%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E3%81%93%E3%82%8C%E3%81%AB%E3%82%88%E3%82%8A%E3%82%BB%E3%83%BC%E3%83%95%E3%83%86%E3%82%A3%E7%B5%8C%E8%B7%AF%E3%81%AB%E6%BD%9C%E5%9C%A8%E7%9A%84%E3%81%AA%E9%9A%9C%E5%AE%B3%E3%82%B7%E3%83%8A%E3%83%AA%E3%82%AA%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%EF%BC%88%E4%BE%8B%E3%81%88%E3%81%B0%E3%80%81%E6%A5%B5%E6%80%A7%E3%81%AB%E5%BF%9C%E3%81%98%E3%81%A6GND%E3%81%BE%E3%81%9F%E3%81%AFVDD%E3%81%B8%E3%81%AE%E7%9F%AD%E7%B5%A1%E3%81%AB%E3%82%88%E3%82%8A%E3%83%94%E3%83%B3%E3%81%8C%E3%80%8C%E9%9A%9C%E5%AE%B3%E3%81%AA%E3%81%97%E3%80%8D%E3%81%AE%E7%8A%B6%E6%85%8B%E3%81%AB%E5%9B%BA%E5%AE%9A%E3%81%95%E3%82%8C%E3%82%8B%E3%81%AA%E3%81%A9%EF%BC%89%E3%80%82%3CBR%20%2F%3EFMEDA%EF%BC%88SM3.FCCU_MON%EF%BC%89%E3%82%92%E5%8F%82%E7%85%A7%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%81%93%E3%81%AE%E6%A0%B9%E6%8B%A0%E3%81%AF%E9%AB%98%E3%81%84%E8%A8%BA%E6%96%AD%E3%82%AB%E3%83%90%E3%83%AC%E3%83%83%E3%82%B8%EF%BC%88%E7%B4%8499%25%EF%BC%89%E3%82%92%E5%89%8D%E6%8F%90%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%80%82%E3%81%93%E3%82%8C%E3%81%AB%E3%81%AF%E5%A4%96%E9%83%A8%E7%9B%A3%E8%A6%96%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81%E9%80%9A%E5%B8%B8%E3%81%AFSBC%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E5%AE%9F%E8%A3%85%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%EF%BC%88%E4%BE%8B%EF%BC%9AFS26%EF%BC%89%E3%80%82FCCU%E3%81%AEEOUT%E4%BF%A1%E5%8F%B7%E3%81%AE%E4%B8%A1%E6%96%B9%E3%82%92%E5%8F%8C%E5%AE%89%E5%AE%9A%EF%BC%88%E3%81%BE%E3%81%9F%E3%81%AF%E6%95%85%E9%9A%9C%E3%83%88%E3%82%B0%E3%83%AB%EF%BC%89%E6%A7%8B%E6%88%90%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%8A%E3%82%88%E3%81%B3%E7%9B%A3%E8%A6%96%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81SBC%E3%81%AF%E5%BF%85%E8%A6%81%E3%81%AA%E8%A8%BA%E6%96%AD%E7%AF%84%E5%9B%B2%E3%82%92%E9%81%94%E6%88%90%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E6%A7%8B%E9%80%A0%E7%9A%84%E3%81%AB%E3%82%B9%E3%82%BF%E3%83%83%E3%82%AF%E3%82%A2%E3%83%83%E3%83%88%E6%95%85%E9%9A%9C%E3%82%84%E3%83%A9%E3%82%A4%E3%83%B3%E6%95%85%E9%9A%9C%E3%82%92%E6%A4%9C%E5%87%BA%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%80%82%E5%AF%BE%E7%85%A7%E7%9A%84%E3%81%AB%E3%80%81%E5%8D%98%E4%B8%80%E3%81%AEFCCU%E4%BF%A1%E5%8F%B7%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81%E5%90%8C%E3%83%AC%E3%83%99%E3%83%AB%E3%81%AE%E3%82%AB%E3%83%90%E3%83%BC%E7%8E%87%E3%82%92%E9%81%94%E6%88%90%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E8%BF%BD%E5%8A%A0%E3%81%AE%E7%8B%AC%E7%AB%8B%E3%81%97%E3%81%9F%E3%83%A1%E3%82%AB%E3%83%8B%E3%82%BA%E3%83%A0%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A8%E3%81%AA%E3%82%8B%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%83%80%E3%83%8B%E3%82%A8%E3%83%AB%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
