Is using one FCCU pin enough for ASIL D?
1,022 次查看
haythemLtifi
hello ,
I was wondering if using one FCCU pin is enough for the ASIL D or i have to use both?
I found this table in one of the presentation so i belive one pin is enough.
Also in case of the S32K3 MCU , does it support one FCCU pin or it has to be in pair bi stable ?
i found this in the application note AN14068 page 25 but its not clear to me :
FCCU monitoring by pair (bi-stable protocol)
When connected to the S32K3 MCU FCCU_ERR0 and FCCU_ERR1 pins, the FCCU1 and FCCU2 input
pins must be configured by pair to work in bi-stable protocol by default. This configuration cannot be changed
because the S32K3 only supports this protocol. The FCCU pins' polarity and the SBC reaction upon a fault can
be changed nonetheless.
The default settings for FCCU pins are configured as below:
• FCCU1 = 0 or FCCU2 = 1 is considered as a fault (can be reversed using FCCU12_FLT_POL bits)
• When a fault occurs, the impact can be configured on RSTB, FS0B, and LIMP0 (using FCCU12_[RSTB/
FS0B/LIMP0]_IMPACT)
thank you
标记 (5)
957 次查看
danielmartynek
Hello @haythemLtifi,
S32K3xx is a SEooC, therefore ASIL‑D applies to the complete system, not just the MCU.
ASIL‑D is possible with a single FCCU EOUT signal; however, this introduces a latent fault scenario on the safety path (e.g. the pin stuck at “no fault” due to a short to GND or VDD, depending on polarity).
Referring to the FMEDA (SM3.FCCU_MON), the justification assumes a high diagnostic coverage (~99%). This requires external monitoring, typically implemented by the SBC (e.g. FS26). When both FCCU EOUT signals are used and monitored in a bi‑stable (or fault‑toggle) configuration, the SBC can achieve the required diagnostic coverage. as it detects stuck‑at and line faults structurally. In contrast, when using a single FCCU signal, additional independent mechanisms are required to reach the same level of coverage.
958 次查看
danielmartynek
%3CLINGO-SUB%20id%3D%22lingo-sub-2360385%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E4%BD%BF%E7%94%A8%E4%B8%80%E4%B8%AA%20FCCU%20%E5%BC%95%E8%84%9A%E6%98%AF%E5%90%A6%E8%B6%B3%E4%BB%A5%E6%BB%A1%E8%B6%B3%20ASIL%20D%20%E7%9A%84%E8%A6%81%E6%B1%82%EF%BC%9F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2360385%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%E3%80%81%20%3C%2FP%3E%3CP%3E%E6%88%91%E6%83%B3%E7%9F%A5%E9%81%93%E4%BD%BF%E7%94%A8%E4%B8%80%E4%B8%AA%20FCCU%20%E5%BC%95%E8%84%9A%E6%98%AF%E5%90%A6%E8%B6%B3%E4%BB%A5%E6%BB%A1%E8%B6%B3%20ASIL%20D%20%E7%9A%84%E8%A6%81%E6%B1%82%EF%BC%8C%E8%BF%98%E6%98%AF%E5%BF%85%E9%A1%BB%E5%90%8C%E6%97%B6%E4%BD%BF%E7%94%A8%E4%B8%A4%E4%B8%AA%E5%BC%95%E8%84%9A%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%88%91%E5%9C%A8%E4%B8%80%E4%B8%AA%E6%BC%94%E7%A4%BA%E6%96%87%E7%A8%BF%E4%B8%AD%E6%89%BE%E5%88%B0%E4%BA%86%E8%BF%99%E4%B8%AA%E8%A1%A8%E6%A0%BC%EF%BC%8C%E6%89%80%E4%BB%A5%E6%88%91%E7%9B%B8%E4%BF%A1%E4%B8%80%E4%B8%AA%E9%92%88%E8%84%9A%E5%B0%B1%E8%B6%B3%E5%A4%9F%E4%BA%86%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22haythemLtifi_0-1777974700032.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22haythemLtifi_0-1777974700032.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F384325iD2072D0E7FF35D32%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22haythemLtifi_0-1777974700032.png%22%20alt%3D%22haythemLtifi_0-1777974700032.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E5%8F%A6%E5%A4%96%EF%BC%8C%E5%AF%B9%E4%BA%8E%20S32K3%20MCU%EF%BC%8C%E5%AE%83%E6%98%AF%E6%94%AF%E6%8C%81%E4%B8%80%E4%B8%AA%20FCCU%20%E5%BC%95%E8%84%9A%E8%BF%98%E6%98%AF%E5%BF%85%E9%A1%BB%E6%88%90%E5%AF%B9%E5%8F%8C%E7%A8%B3%E6%80%81%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%88%91%E5%9C%A8%E5%BA%94%E7%94%A8%E7%AC%94%E8%AE%B0%20AN14068%20%E7%AC%AC%2025%20%E9%A1%B5%E4%B8%AD%E6%89%BE%E5%88%B0%E4%BA%86%E8%BF%99%E4%B8%AA%E4%BD%86%E6%88%91%E8%BF%98%E4%B8%8D%E6%B8%85%E6%A5%9A%EF%BC%9A%3C%2FP%3E%3CP%3EFCCU%20%E6%88%90%E5%AF%B9%E7%9B%91%E6%8E%A7%EF%BC%88%E5%8F%8C%E7%A8%B3%E6%80%81%E5%8D%8F%E8%AE%AE%EF%BC%89%3C%2FP%3E%3CP%3E%E5%BD%93%E8%BF%9E%E6%8E%A5%E5%88%B0%20S32K3%20MCU%20FCCU_ERR0%20%E5%92%8C%20FCCU_ERR1%20%E5%BC%95%E8%84%9A%E6%97%B6%EF%BC%8CFCCU1%20%E5%92%8C%20FCCU2%20%E8%BE%93%E5%85%A5%3C%2FP%3E%3CP%3E%E5%BC%95%E8%84%9A%E5%BF%85%E9%A1%BB%E6%8C%89%E9%85%8D%E5%AF%B9%E9%85%8D%E7%BD%AE%EF%BC%8C%E9%BB%98%E8%AE%A4%E6%83%85%E5%86%B5%E4%B8%8B%E4%BB%A5%E5%8F%8C%E7%A8%B3%E6%80%81%E5%8D%8F%E8%AE%AE%E5%B7%A5%E4%BD%9C%E3%80%82%E6%AD%A4%E9%85%8D%E7%BD%AE%E4%B8%8D%E5%8F%AF%E6%9B%B4%E6%94%B9%3C%2FP%3E%3CP%3E%E5%9B%A0%E4%B8%BA%20S32K3%20%E5%8F%AA%E6%94%AF%E6%8C%81%E8%AF%A5%E5%8D%8F%E8%AE%AE%E3%80%82%E6%95%85%E9%9A%9C%E5%8F%91%E7%94%9F%E6%97%B6%EF%BC%8CFCCU%20%E5%BC%95%E8%84%9A%E7%9A%84%E6%9E%81%E6%80%A7%E5%92%8C%20SBC%20%E7%9A%84%E5%8F%8D%E5%BA%94%E5%8F%AF%E4%BB%A5%E6%98%AF%3C%2FP%3E%3CP%3E%E4%BD%86%E8%BF%98%E6%98%AF%E8%A6%81%E6%94%B9%E3%80%82%3C%2FP%3E%3CP%3EFCCU%20%E5%BC%95%E8%84%9A%E7%9A%84%E9%BB%98%E8%AE%A4%E8%AE%BE%E7%BD%AE%E5%A6%82%E4%B8%8B%EF%BC%9A%3C%2FP%3E%3CP%3E-%20FCCU1%20%3D%200%20%E6%88%96%20FCCU2%20%3D%201%20%E8%A2%AB%E8%A7%86%E4%B8%BA%E6%95%85%E9%9A%9C%EF%BC%88%E5%8F%AF%E4%BD%BF%E7%94%A8%20FCCU12_FLT_POL%20%E4%BD%8D%E8%BF%9B%E8%A1%8C%E5%8F%8D%E5%90%91%E8%AE%BE%E7%BD%AE%EF%BC%89%3C%2FP%3E%3CP%3E-%20%E5%BD%93%E5%8F%91%E7%94%9F%E6%95%85%E9%9A%9C%E6%97%B6%EF%BC%8C%E5%8F%AF%E5%9C%A8%20RSTB%E3%80%81FS0B%20%E5%92%8C%20LIMP0%20%E4%B8%8A%E9%85%8D%E7%BD%AE%E5%BD%B1%E5%93%8D%EF%BC%88%E4%BD%BF%E7%94%A8%20FCCU12_%5BRSTB%2F%5D%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3Efs0b%2Flimp0%5D_impact)%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E8%B0%A2%E8%B0%A2%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2360887%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Is%20using%20one%20FCCU%20pin%20enough%20for%20ASIL%20D%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2360887%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F258585%22%20target%3D%22_blank%22%3E%40haythemLtifi%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3ES32K3xx%20%E6%98%AF%20SEooC%EF%BC%8C%E5%9B%A0%E6%AD%A4%20ASIL-D%20%E9%80%82%E7%94%A8%E4%BA%8E%E6%95%B4%E4%B8%AA%E7%B3%BB%E7%BB%9F%EF%BC%8C%E8%80%8C%E4%B8%8D%E4%BB%85%E4%BB%85%E6%98%AF%20MCU%E3%80%82%3CBR%20%2F%3E%E4%BD%BF%E7%94%A8%E5%8D%95%E4%B8%AAFCCU%20EOUT%E4%BF%A1%E5%8F%B7%E5%8D%B3%E5%8F%AF%E5%AE%9E%E7%8E%B0ASIL%E2%80%91D%EF%BC%9B%E4%BD%86%E6%98%AF%EF%BC%8C%E8%BF%99%E4%BC%9A%E5%9C%A8%E5%8A%9F%E8%83%BD%E5%AE%89%E5%85%A8%E8%B7%AF%E5%BE%84%E4%B8%8A%E5%BC%95%E5%85%A5%E6%BD%9C%E5%9C%A8%E7%9A%84%E6%95%85%E9%9A%9C%E5%9C%BA%E6%99%AF%EF%BC%88%E4%BE%8B%E5%A6%82%EF%BC%8C%E7%94%B1%E4%BA%8EGND%E6%88%96VDD%E7%9F%AD%E8%B7%AF%EF%BC%8C%E5%BC%95%E8%84%9A%E5%81%9C%E6%BB%9E%E5%9C%A8%20%E2%80%9C%E6%97%A0%E6%95%85%E9%9A%9C%E2%80%9D%20%E7%8A%B6%E6%80%81%EF%BC%8C%E5%85%B7%E4%BD%93%E5%8F%96%E5%86%B3%E4%BA%8E%E6%9E%81%E6%80%A7%EF%BC%89%E3%80%82%3CBR%20%2F%3E%E5%8F%82%E7%85%A7%20FMEDA%20(SM3.FCCU_MON)%EF%BC%8C%E7%90%86%E7%94%B1%E6%98%AF%E5%81%87%E8%AE%BE%E8%AF%8A%E6%96%AD%E8%A6%86%E7%9B%96%E7%8E%87%E8%BE%83%E9%AB%98%20(~99%25)%E3%80%82%E8%BF%99%E9%9C%80%E8%A6%81%E5%A4%96%E9%83%A8%E7%9B%91%E6%B5%8B%EF%BC%8C%E9%80%9A%E5%B8%B8%E7%94%B1%20SBC%20%E5%AE%9E%E6%96%BD%EF%BC%88%E4%BE%8B%E5%A6%82FS26%EF%BC%89%E3%80%82%E5%BD%93%E4%BB%A5%E5%8F%8C%E7%A8%B3%E5%AE%9A%EF%BC%88%E6%88%96%E6%95%85%E9%9A%9C%E5%88%87%E6%8D%A2%EF%BC%89%E9%85%8D%E7%BD%AE%E4%BD%BF%E7%94%A8%E5%92%8C%E7%9B%91%E6%8E%A7%E4%B8%A4%E4%B8%AA%20FCCU%20EOUT%20%E4%BF%A1%E5%8F%B7%E6%97%B6%EF%BC%8CSBC%20%E5%8F%AF%E4%BB%A5%E8%BE%BE%E5%88%B0%E6%89%80%E9%9C%80%E7%9A%84%E8%AF%8A%E6%96%AD%E8%A6%86%E7%9B%96%E8%8C%83%E5%9B%B4%E3%80%82%E5%9B%A0%E4%B8%BA%E5%AE%83%E8%83%BD%E4%BB%8E%E7%BB%93%E6%9E%84%E4%B8%8A%E6%A3%80%E6%B5%8B%E5%87%BA%E5%8D%A1%E4%BD%8F%E5%92%8C%E7%BA%BF%E8%B7%AF%E6%95%85%E9%9A%9C%E3%80%82%E7%9B%B8%E6%AF%94%E4%B9%8B%E4%B8%8B%EF%BC%8C%E5%9C%A8%E4%BD%BF%E7%94%A8%E5%8D%95%E4%B8%AA%20FCCU%20%E4%BF%A1%E5%8F%B7%E6%97%B6%EF%BC%8C%E9%9C%80%E8%A6%81%E9%A2%9D%E5%A4%96%E7%9A%84%E7%8B%AC%E7%AB%8B%E6%9C%BA%E5%88%B6%E6%89%8D%E8%83%BD%E8%BE%BE%E5%88%B0%E7%9B%B8%E5%90%8C%E7%9A%84%E8%A6%86%E7%9B%96%E6%B0%B4%E5%B9%B3%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%0A%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%0A%3CP%3E%E4%B8%B9%E5%B0%BC%E5%B0%94%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
