Invalid project path: Include path not found (\include).
5,300 次查看
KeepGoing
S32K142
MCSXTE2BK142_PMSM_FOC_1Sh
I have tried many methods, but I still can't solve the problem of path. I hope I can get help. Thank you very much
5,262 次查看
Senlent
Hi@KeepGoing
         please install IDE: S32DS for ARM v2018.R1 & SDK: S32K1xx SDK RTM 3.0.0,then try again,
as i said above, i don't have the motor kits,so can not  test it for you
6 回复数
5,288 次查看
Senlent
Hi@KeepGoing
please read the release note:
SW Requirements:
AMMCLib: S32K14x_AMMCLIB_v1.1.15
FreeMASTER(MCAT): v2.5 or later
and I made a test on S32DS for ARM v2018.R1 ,which works fine on my side.
BR!
      Jim,
5,280 次查看
KeepGoing
5,284 次查看
KeepGoing
Thank you very much for your answer. I solved a path problem by modifying debug - > debug ram.
Now I'm working on it
Warnings:The launch configuration
MCSXTE2BK142_ PMSM_ FOC_ 2Sh_ Debug_ Lauterbach. launch missing specification of a launch type
As shown in the figure
Finally, I would like to ask you whether my operation meets the specifications and is correct.
5,270 次查看
Senlent
Hi@KeepGoing
You can download the program and test whether the motor development kit is working properly.
and I don't have such hardware, so i can't test it for you.
5,266 次查看
KeepGoing
Yes,When I debug, I am prompted that the register reading fails. I don't know how to solve it. I hope I can get your help. Thank you.
5,263 次查看
Senlent
Hi@KeepGoing
