Integrate Non Autosar RTD 3.0.0 version with Example source code FlexCAN_Ip_Example_S32K34RTD 7.0.0
575件の閲覧回数
sharathkumar2026
Is It Possible to Integrate Non Autosar RTD 3.0.0 version with (S32DS-36.8 version IDE) FlexCAN_Ip_Example_S32K34 _RTD_R23-11_7.0.1_D2603_DesignStudio_updatesite
1. I need to integrate our Current UDS Application code with FlexCAN_Ip_Example_S32K34 _RTD_R23-11_7.0.1_D2603_DesignStudio source code
2. I already added FreeRtos config into the RTD 7.0.0 does this support into  _RTD_R23-11_7.0.1_D2603_DesignStudio_updatesite
534件の閲覧回数
PetrS
This question seems related to your other thread regarding RTD 3.0.0 → RTD 7.x migration;
https://community.nxp.com/t5/S32K/Clarification-on-RTD-3-0-0-to-RTD-7-0-0-Migration-and-FreeRTOS/m-p...
For RTD 3.0.0 (non-AUTOSAR), please note:
  • RTD 3.0.0 already contains a number of demo/example projects (both AUTOSAR and non-AUTOSAR), which can be used as a reference for driver usage and project structure.
  • However, these examples are standalone and tightly coupled with their generated configuration (clocks, pins, peripherals), so they cannot be directly “plugged” into an existing project without alignment.
  • Integrating example source code into your application always requires manual adaptation of configuration and initialization.
From migration perspective:
  • There is no automatic migration tool between RTD versions.
  • Even when using *.mex import, configuration differences between RTD versions often lead to errors that must be resolved manually.
  • Recommended approach is to create a new project (especially when moving to RTD 7.x) and port the application incrementally.
The SW32K3 FreeRTOS 11.1.0 version 0.8.0 CD1 is intended to be used with SW32K3_S32M27x_RTD_R23-11_7.0.1_D2603_DesignStudio_updatesite
BR, Petr
%3CLINGO-SUB%20id%3D%22lingo-sub-2379534%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E9%9D%9EAUTOSAR%20RTD%203.0.0%20%E3%82%92%E7%B5%B1%E5%90%88%E3%81%99%E3%82%8B%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E5%90%AB%E3%82%80%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%20FlexCAN_Ip_Example_S32K34RTD%207.0.0%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2379534%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E9%9D%9EAUTOSAR%20RTD%203.0.0%E3%82%92%E7%B5%B1%E5%90%88%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F(S32DS-36.8%20%E3%82%92%E5%90%AB%E3%82%80%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3)%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%20IDE)%20FlexCAN_Ip_Example_S32K34%20_RTD_R23-11_7.0.1_D2603_DesignStudio_updatesite%3CBR%20%2F%3E%3CBR%20%2F%3E%201.%E7%8F%BE%E5%9C%A8%E3%81%AEUDS%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92FlexCAN_Ip_Example_S32K34_RTD_R23-11_7.0.1_D2603_DesignStudio%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E3%81%A8%E7%B5%B1%E5%90%88%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E2.%20%E7%A7%81%E3%81%AF%E6%97%A2%E3%81%ABFreeRTOS%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%82%92RTD%207.0.0%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF_RTD_R23-11_7.0.1_D2603_DesignStudio_updatesite%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2379941%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Integrate%20Non%20Autosar%20RTD%203.0.0%20version%20with%20Example%20source%20code%20FlexCAN_Ip_Example_S32K34RTD%207.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2379941%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%0A%3CP%3E%E3%81%93%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%AF%E3%80%81RTD%203.0.0%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E5%88%A5%E3%81%AE%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%E3%81%AB%E9%96%A2%E9%80%A3%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%E2%86%92%20RTD%207.x%E3%81%B8%E3%81%AE%E7%A7%BB%E8%A1%8C%3B%3CBR%20%2F%3E%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K%2FClarification-on-RTD-3-0-0-to-RTD-7-0-0-Migration-and-FreeRTOS%2Fm-p%2F2379535%2Fhighlight%2Ffalse%23M59186%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K%2FClarification-on-RTD-3-0-0-to-RTD-7-0-0-Migration-and-FreeRTOS%2Fmp%2F2379535%2Fhighlight%2Ffalse%23M59186%3C%2FA%3E%3C%2FP%3E%0A%3CP%3ERTD%203.0.0%E3%81%AE%E5%A0%B4%E5%90%88%EF%BC%88AUTOSAR%E4%BB%A5%E5%A4%96%EF%BC%89%E3%81%94%E6%B3%A8%E6%84%8F%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%EF%BC%9A%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3ERTD%203.0.0%E6%97%A2%E3%81%AB%E5%A4%9A%E6%95%B0%E3%81%AE%E3%83%87%E3%83%A2%2F%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%EF%BC%88AUTOSAR%E5%AF%BE%E5%BF%9C%E3%81%8A%E3%82%88%E3%81%B3%E9%9D%9EAUTOSAR%E5%AF%BE%E5%BF%9C%E3%81%AE%E4%B8%A1%E6%96%B9%EF%BC%89%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AE%E4%BD%BF%E7%94%A8%E6%96%B9%E6%B3%95%E3%82%84%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E6%A7%8B%E9%80%A0%E3%81%AE%E5%8F%82%E8%80%83%E3%81%A8%E3%81%97%E3%81%A6%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%0A%3CLI%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E4%BE%8B%E3%81%AF%E3%82%B9%E3%82%BF%E3%83%B3%E3%83%89%E3%82%A2%E3%83%AD%E3%83%B3%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81%E7%94%9F%E6%88%90%E3%81%95%E3%82%8C%E3%81%9F%E6%A7%8B%E6%88%90%EF%BC%88%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%80%81%E3%83%94%E3%83%B3%E3%80%81%E3%83%9A%E3%83%AA%E3%83%95%E3%82%A7%E3%83%A9%E3%83%AB%EF%BC%89%E3%81%A8%E5%AF%86%E6%8E%A5%E3%81%AB%E7%B5%90%E5%90%88%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E8%AA%BF%E6%95%B4%E3%81%AA%E3%81%97%E3%81%AB%E6%97%A2%E5%AD%98%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AB%E7%9B%B4%E6%8E%A5%E3%80%8C%E7%B5%84%E3%81%BF%E8%BE%BC%E3%82%80%E3%80%8D%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FLI%3E%0A%3CLI%3E%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AB%E7%B5%84%E3%81%BF%E8%BE%BC%E3%82%80%E5%A0%B4%E5%90%88%E3%80%81%E8%A8%AD%E5%AE%9A%E3%81%A8%E5%88%9D%E6%9C%9F%E5%8C%96%E3%82%92%E6%89%8B%E5%8B%95%E3%81%A7%E8%AA%BF%E6%95%B4%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E5%BF%85%E3%81%9A%E7%94%9F%E3%81%98%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%E7%A7%BB%E6%B0%91%E3%81%AE%E8%A6%B3%E7%82%B9%E3%81%8B%E3%82%89%EF%BC%9A%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3ERTD%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E9%96%93%E3%81%AE%E8%87%AA%E5%8B%95%E7%A7%BB%E8%A1%8C%E3%83%84%E3%83%BC%E3%83%AB%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FLI%3E%0A%3CLI%3E*.mex%E3%82%A4%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%88%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%A7%E3%82%82%E3%80%81RTD%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E9%96%93%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%AE%E9%81%95%E3%81%84%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81%E6%89%8B%E5%8B%95%E3%81%A7%E8%A7%A3%E6%B1%BA%E3%81%97%E3%81%AA%E3%81%91%E3%82%8C%E3%81%B0%E3%81%AA%E3%82%89%E3%81%AA%E3%81%84%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%82%88%E3%81%8F%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%0A%3CLI%3E%E6%8E%A8%E5%A5%A8%E3%81%95%E3%82%8C%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AF%E3%80%81%E6%96%B0%E3%81%97%E3%81%84%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%EF%BC%88%E7%89%B9%E3%81%ABRTD%207.x%E3%81%AB%E7%A7%BB%E8%A1%8C%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%EF%BC%89%E3%80%81%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E6%AE%B5%E9%9A%8E%E7%9A%84%E3%81%AB%E7%A7%BB%E6%A4%8D%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3ESW32K3%20FreeRTOS%2011.1.0%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B30.8.0%20CD1%E3%81%AF%E3%80%81SW32K3_S32M27x_RTD_R23-11_7.0.1_D2603_DesignStudio_updatesite%E3%81%A8%E4%BD%B5%E7%94%A8%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E6%83%B3%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3EBR%E3%80%81%E3%83%9A%E3%83%88%E3%83%AB%3C%2FP%3E%3C%2FLINGO-BODY%3E
