Inquiry S32K148 LPI2C0 slave setup
已解决
跳至解决方案
1,854 次查看
my_tesla
Hi NXP community,
I would like to use the lpi2c0 interface on my S32K148 microcontroller and set it up as a slave. But in the examples library in the S32DS IDE I only found an exampe code for lpi2c1.Is there an example code I can use or is it possible to change the lpi2c1 code to lpi2c0?
Any help or ideas are much appreciated!
1 解答
1,845 次查看
danielmartynek
Just change the module
Enable the LPI2C0 pins:
And generate the code:
在原帖中查看解决方案
2 回复数
1,846 次查看
danielmartynek
1,839 次查看
my_tesla
Hi Daniel,
Thank you for your support!
