Import Project Problems
4,561件の閲覧回数
kemingkai
Hi NXP Engineer:
     As the title,The popup view gives an error when I import the project with S32K148.
     In the first window,I chose the latest component,SDK S32K1xx 15/S32K148_176.version 01.197
     And then,the second popup chose 'SDK_S32K1xx_15/PinSettings,version 1.2.0' and push OK.
But still keep fault
I don't know how to deal with this window to solve the problem.
Hope reply
Thanks in advance.
6 返答(返信)
4,488件の閲覧回数
kemingkai
The reason has been found, the IDE version is not compatible.
4,488件の閲覧回数
dianabatrlova
Thank you fr your comment. May I ask which version of S32DS you had in that project?
Thank you.
Diana
4,488件の閲覧回数
kemingkai
This problem happen when i use S32DS 2018.R1 to import the program which create with S32DS V2.2
4,488件の閲覧回数
dianabatrlova
Hello Knight,
Have you tried to select correct path of SDK in ARM v2.2?
C:\NXP\S32DS_ARM_v2.2\S32DS\software\S32SDK_S32K1xx_RTM_3.0.0
Diana
4,488件の閲覧回数
kemingkai
4,488件の閲覧回数
kemingkai
Description Resource Path Location Type
Generator: ERROR: There are errors in the project, please review components configuration. It is not possible to generate code. demo Code Generator Processor Expert Problem
