ISELED under FREERTOS
Mike565
Hello:
     I'm trying to run an iseled sample under freertos,but it can not work.I created only one task which controls one led, runs every 20ms.I checked the waveform and found that a piece of the waveform is missing,as attachment shows.The normal waveform is a sample without freertos runs the same task.Is there any suggestion about how to fix this problem?Or any sample code about iseled run under freertos?
Mike565
problem solved.iseled init error,lack of some paramenter.
Senlent
Hi@Mike565
         Okay, I will close this case.
BR!
     Jim.
