IPCF v3.7.0 problem
IPCF v3.7.0 problem
chuanlin
Can S32DSV3.5 import IPCF routines suitable for S32K324 from IPCF V3.7.0?
chuanlin
Hello, I found a make method routine in IPCF v3.6.0. Is the routine integrated into S32DS currently not open.
jiri_kral
if I understand your question correctly - you like to build IPCF example from command line by make command?
The procedure is described step by step in  SW32K3_IPCF_3.6.0_D2206_UserManual.pdf  - page 22.
chuanlin
Hello:
 No, I know the 'make' method, But ,there are no S32DS engineering examples related to S32K324 found here.
jiri_kral
I checked the content of IPCF package and based on README.rst file - the s32_rtd_S32K3XX example supports S32K324. At least in stand alone version (the .exe file installer for IPCF).
jiri_kral
no, as you can see in Release Notes - S32K3 IPCF v3.7.0 supports S32K358 device.
Please use your existing threads - this is your fourth thread related to the same topic.
