How to wake up VLPS mode with interrupt
952 次查看
ShaoTianzhi
After setting the mode of the S32K146 to VLPS,The frequency obtained by CLOCK_SYS_GetFreq after the external interrupt is triggered does not change,How do I use interrupts to get power mode back from VLPS to RUN?
918 次查看
Senlent
Hi@ShaoTianzhi
1.please try to test the demo in S32 DS,"power_mode_switch_s32k146"
2.for you better undersantding, i recommand your to read the application note for S32K1 power  management:AN5425:https://www.nxp.com/search?keyword=AN5425&start=0
3.A test process written in chinese:
破坏者
