I have considered S32R294 SWT with jd_Watchpt(IAC8 register) is possible to implement 'Logical monitoring of programme sequence' for safety mechanism.
According to S32R294 reference manual Chapter 48.1.4, SWT address execution mode with instruction address compare 8(IAC8) register can be solution of control flow.
I can not guess how 'fixed address mode' SWT is related with jd_Watchpt.
Is there any use case of this?
