How to use SWT jd_watchpt of S32R294
1,485 次查看
otterNsnake
I have considered S32R294 SWT with jd_Watchpt(IAC8 register) is possible to implement 'Logical monitoring of programme sequence' for safety mechanism.
According to S32R294 reference manual Chapter 48.1.4, SWT address execution mode with instruction address compare 8(IAC8) register can be solution of control flow.
I can not guess how 'fixed address mode' SWT is related with jd_Watchpt.
Is there any use case of this?
标记 (3)
4 回复数
1,432 次查看
otterNsnake
For S32R294, I found a errata about this SWT mode.
- ERR010880
It looks Fixed address/Incremental address mode is not applied to S32R294.
Is it correct?
1,460 次查看
petervlna
Regarding watchpoint signals:
Peter
1,430 次查看
otterNsnake
- ERR010880
Is it correct?
1,411 次查看
petervlna
Is it correct?
It is applied, but it is not recommend to use those modes for servicing due to errata.
Peter
