How to test the ADC input is not connected
2,641 次查看
zhaoyanling
Dear expert,
I use S32K144, The ADC result is gotten with DMA interrupt. There is a problem about ADC, Could you help me ?
I found, When I disconnected the ADC1_SE0, which means the ADC annalog input is nothing, but I still can get the DMA interrupt, and the Digital output is nearly 5V. By the way, Vref_h = 5V, Vref_L = grand.
1.How can I know the ADC input is open circuit?
2.When a pin is not used as GPIO, the pull down can not be set.
Thank you very much!
标记 (2)
2,561 次查看
zhaoyanling
Hi, Daniel,
Do you mean, If the pin ADC1_Se0 is enabled pull-down, when the PTA2 pin (in ADC1_SE0 function) is not connected,then the digital output is  0 voltage?
Thank you very much for your reply!
2,561 次查看
danielmartynek
Hi zhaoyanling@bhap.com.cn,
Yes, that's what I mean.
Or do you observe something else?
2,561 次查看
danielmartynek
Hello zhaoyanling@bhap.com.cn,
1. When the PTA2 pin (in ADC1_SE0 function) is not connected to any circuit, the pin is floating, and the state of the pin cannot be defined.
2. But the internal pull-down can be enabled in every function of the PTA2 pin, including ADC1_SE0.
