Can the binary file downloaded to the evaluation board flash be saved to a computer?
testyoung
I am using the NTBMS evaluation board.
The downloader uses PE Multilink Universal.
I would like to check if the software provided by NXP and the file downloaded to the evaluation board flash are the same.
Can I load the .elf file written on the flash to my computer? Or is it possible to verify with the compiled .elf file?
Robin_Shen
Hi testyoung,
You may need to use PROGACMP ARM Flash Programming Software for Multilink and Multink FX debug probes.
About how to use PROGACMP with Multilink, you can read the manual or ask question in forums of PEMicro.
Robin
Robin_Shen
Hi testyoung,
Robin
testyoung
Thank you!
