How to detect illegal opcode in S32K1XX
ソリューションへジャンプ
2,931件の閲覧回数
Pratheek
How to detect ECU reset due to Illegal op code/undefined instructions. I think Usage fault exception will trigger if illegal opcode is executed. But, how to confirm the Usage fault exception is due to illgale opcode?
2,918件の閲覧回数
danielmartynek
Hi @Pratheek,
Yes, this is a usage fault exception.
In the fault handler, read the CFSR[UNDEFINSTR] register.
Since the CM7 core is very similar to the CM4 on S32K14x in this regard, you can refer to this document/example:
https://community.nxp.com/t5/S32K-Knowledge-Base/Fault-handling-on-S32K14x/ta-p/1114447
2 返答(返信)
2,919件の閲覧回数
danielmartynek
Hi @Pratheek,
2,891件の閲覧回数
Pratheek
Hello Daniel,
Thank you veru much for your support, issue solved.
Thanks & Regards,
Pratheek
