How to config Lin module as slave node base MCAL driver in S32K series board?
3,764件の閲覧回数
zyt
Now I try to add lin slave node application base MCAL driver, but when I find lin configuration in EB tresos, it does not have item to assign master or slave node. And in MCAL driver, it only provide Lin_SendFrame() to send frame, but not have receive function.
So does it mean lin can only be master node in MCAL? What can I do to config it as slave node? Any example?
タグ(4)
3,567件の閲覧回数
namnguyenviet
For S32K platform, MCAL packages available for AUTOSAR version 4.3 and below. Unfortunately, AUTOSAR version 4.3 and below have not defined LIN slave mode (LIN slave has been defined from AUTOSAR 4.4), so LIN slave is not available in S32K AUTOSAR MCAL.
Nam
3,568件の閲覧回数
namnguyenviet
Nam
