How to assign data and function to specific section in S32DS for Arm
2,964 次查看
hurongbo
Hello everyone:
I use S32K148 MCU ,and S32DS for Arm IDE V2.2.
I want to assign data and code to specific sections.
At first, I use #pragma section it not work, S32DS ignore it (Unknow pragmas).
Then,I use __attribute__ ((section(".mycode"))), It worked.But only one function was assigned to ".mycode" section below __attribute__ ((section(".mycode"))) instruct.
My code like this:
void AAA()
void BBB()
After link,Only function AAA in section ".mycode".Function BBB in default ".text" section.
How to assign all function in one module to a section with one instruction like #pragma section in other platform?
Thanks.
标记 (1)
2,954 次查看
davidtosenovjan
Hi, you have actually answered yourself.
There are no pragmas in GCC, you will have to add mentioned attribute before every function.
2,955 次查看
davidtosenovjan
2,937 次查看
hurongbo
Thanks a lot.
