HSE code errors
HSE code errors
1,199 次查看
vikmonti7804
   I am creating a seperate project for the HSE where i am adding the services, frameworks and interface folder from the example code, i am getting some erroe and i am keep including the respective header files to the source code but the errors are still there and i am not able to remove them. these error seems to be related to some settings. kindly look and help  to remove them.
C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/fw_attribute/non-otp/hse_get_capabilities.c:82: undefined reference to `gsrvResponse'
C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/fw_attribute/non-otp/hse_get_version.c:123: undefined reference to `gHseFwVersion'
C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/fw_attribute/non-otp/hse_mu_config.c:129: undefined reference to `gsrvResponse'
c:/nxp/s32ds.3.4/s32ds/build_tools/gcc_v10.2/gcc-10.2-arm32-eabi/bin/../lib/gcc/arm-none-eabi/10.2.0/../../../../arm-none-eabi/bin/real-ld.exe: C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/fw_attribute/non-otp/hse_mu_config.c:129: undefined reference to `write_attr'
c:/nxp/s32ds.3.4/s32ds/build_tools/gcc_v10.2/gcc-10.2-arm32-eabi/bin/../lib/gcc/arm-none-eabi/10.2.0/../../../../arm-none-eabi/bin/real-ld.exe: C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/fw_attribute/non-otp/hse_mu_config.c:129: undefined reference to `WriteMu1Config'
c:/nxp/s32ds.3.4/s32ds/build_tools/gcc_v10.2/gcc-10.2-arm32-eabi/bin/../lib/gcc/arm-none-eabi/10.2.0/../../../../arm-none-eabi/bin/real-ld.exe: C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/fw_attribute/non-otp/hse_mu_config.c:129: undefined reference to `ReadMu1Config'
C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/fw_attribute/otp/hse_advance_LC.c:157: undefined reference to `gsrvResponse'
c:/nxp/s32ds.3.4/s32ds/build_tools/gcc_v10.2/gcc-10.2-arm32-eabi/bin/../lib/gcc/arm-none-eabi/10.2.0/../../../../arm-none-eabi/bin/real-ld.exe: C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/fw_attribute/otp/hse_advance_LC.c:157: undefined reference to `write_attr'
C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/fw_attribute/otp/hse_boot_auth.c:153: undefined reference to `gsrvResponse'
c:/nxp/s32ds.3.4/s32ds/build_tools/gcc_v10.2/gcc-10.2-arm32-eabi/bin/../lib/gcc/arm-none-eabi/10.2.0/../../../../arm-none-eabi/bin/real-ld.exe: C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/fw_attribute/otp/hse_boot_auth.c:153: undefined reference to `write_attr'
C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/fw_attribute/otp/hse_debug_auth_mode.c:136: undefined reference to `gsrvResponse'
c:/nxp/s32ds.3.4/s32ds/build_tools/gcc_v10.2/gcc-10.2-arm32-eabi/bin/../lib/gcc/arm-none-eabi/10.2.0/../../../../arm-none-eabi/bin/real-ld.exe: C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/fw_attribute/otp/hse_debug_auth_mode.c:136: undefined reference to `write_attr'
C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/fw_attribute/otp/hse_debug_key.c:299: undefined reference to `write_attr'
c:/nxp/s32ds.3.4/s32ds/build_tools/gcc_v10.2/gcc-10.2-arm32-eabi/bin/../lib/gcc/arm-none-eabi/10.2.0/../../../../arm-none-eabi/bin/real-ld.exe: C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/fw_attribute/otp/hse_debug_key.c:299: undefined reference to `gsrvResponse'
c:/nxp/s32ds.3.4/s32ds/build_tools/gcc_v10.2/gcc-10.2-arm32-eabi/bin/../lib/gcc/arm-none-eabi/10.2.0/../../../../arm-none-eabi/bin/real-ld.exe: ./services/src/fw_attribute/otp/hse_extend_cust_security_policy.o: in function `ExtendCustomerSecurityPolicyService':
C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/fw_attribute/otp/hse_extend_cust_security_policy.c:148: undefined reference to `gsrvResponse'
c:/nxp/s32ds.3.4/s32ds/build_tools/gcc_v10.2/gcc-10.2-arm32-eabi/bin/../lib/gcc/arm-none-eabi/10.2.0/../../../../arm-none-eabi/bin/real-ld.exe: C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/fw_attribute/otp/hse_extend_cust_security_policy.c:148: undefined reference to `write_attr'
c:/nxp/s32ds.3.4/s32ds/build_tools/gcc_v10.2/gcc-10.2-arm32-eabi/bin/../lib/gcc/arm-none-eabi/10.2.0/../../../../arm-none-eabi/bin/real-ld.exe: C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/fw_attribute/otp/hse_extend_cust_security_policy.c:148: undefined reference to `GetStartAsUserBit'
c:/nxp/s32ds.3.4/s32ds/build_tools/gcc_v10.2/gcc-10.2-arm32-eabi/bin/../lib/gcc/arm-none-eabi/10.2.0/../../../../arm-none-eabi/bin/real-ld.exe: C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/fw_attribute/otp/hse_extend_cust_security_policy.c:148: undefined reference to `GetEnableAdkmBit'
c:/nxp/s32ds.3.4/s32ds/build_tools/gcc_v10.2/gcc-10.2-arm32-eabi/bin/../lib/gcc/arm-none-eabi/10.2.0/../../../../arm-none-eabi/bin/real-ld.exe: ./services/src/fw_update/standard/hse_fw_update.o: in function `firmwareUpdateService':
C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/fw_update/standard/hse_fw_update.c:402: undefined reference to `gsrvResponse'
c:/nxp/s32ds.3.4/s32ds/build_tools/gcc_v10.2/gcc-10.2-arm32-eabi/bin/../lib/gcc/arm-none-eabi/10.2.0/../../../../arm-none-eabi/bin/real-ld.exe: C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/fw_update/standard/hse_fw_update.c:402: undefined reference to `fwudpate_only'
c:/nxp/s32ds.3.4/s32ds/build_tools/gcc_v10.2/gcc-10.2-arm32-eabi/bin/../lib/gcc/arm-none-eabi/10.2.0/../../../../arm-none-eabi/bin/real-ld.exe: C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/fw_update/standard/hse_fw_update.c:402: undefined reference to `ActivatePassiveBlock'
c:/nxp/s32ds.3.4/s32ds/build_tools/gcc_v10.2/gcc-10.2-arm32-eabi/bin/../lib/gcc/arm-none-eabi/10.2.0/../../../../arm-none-eabi/bin/real-ld.exe: C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/fw_update/standard/hse_fw_update.c:402: undefined reference to `gHseFwVersion'
C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/hse_demo_app_config.c:27: undefined reference to `gProgramAttributes'
c:/nxp/s32ds.3.4/s32ds/build_tools/gcc_v10.2/gcc-10.2-arm32-eabi/bin/../lib/gcc/arm-none-eabi/10.2.0/../../../../arm-none-eabi/bin/real-ld.exe: C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/hse_demo_app_config.c:27: undefined reference to `gsrvResponse'
c:/nxp/s32ds.3.4/s32ds/build_tools/gcc_v10.2/gcc-10.2-arm32-eabi/bin/../lib/gcc/arm-none-eabi/10.2.0/../../../../arm-none-eabi/bin/real-ld.exe: ./services/src/hse_demo_app_config.o: in function `CopyFlashToSRAMHseHost':
C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/hse_demo_app_config.c:75: undefined reference to `HSE_HOST_FLASH_SRC_START_ADDR'
c:/nxp/s32ds.3.4/s32ds/build_tools/gcc_v10.2/gcc-10.2-arm32-eabi/bin/../lib/gcc/arm-none-eabi/10.2.0/../../../../arm-none-eabi/bin/real-ld.exe: C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/hse_demo_app_config.c:75: undefined reference to `HSE_HOST_FLASH_SRC_END_ADDR'
c:/nxp/s32ds.3.4/s32ds/build_tools/gcc_v10.2/gcc-10.2-arm32-eabi/bin/../lib/gcc/arm-none-eabi/10.2.0/../../../../arm-none-eabi/bin/real-ld.exe: C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/hse_demo_app_config.c:75: undefined reference to `HSE_HOST_RAM_DST_START_ADDR'
c:/nxp/s32ds.3.4/s32ds/build_tools/gcc_v10.2/gcc-10.2-arm32-eabi/bin/../lib/gcc/arm-none-eabi/10.2.0/../../../../arm-none-eabi/bin/real-ld.exe: ./services/src/hse_demo_app_config.o: in function `attributeProgrammingService':
C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/hse_demo_app_config.c:172: undefined reference to `gEnableIVTAuthBit'
c:/nxp/s32ds.3.4/s32ds/build_tools/gcc_v10.2/gcc-10.2-arm32-eabi/bin/../lib/gcc/arm-none-eabi/10.2.0/../../../../arm-none-eabi/bin/real-ld.exe: ./services/src/hse_host_flash.o: in function `HostFlash_Init':
C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/hse_host_flash.c:156: undefined reference to `FLASH_DRIVER_FLASH_SRC_START_ADDRESS'
c:/nxp/s32ds.3.4/s32ds/build_tools/gcc_v10.2/gcc-10.2-arm32-eabi/bin/../lib/gcc/arm-none-eabi/10.2.0/../../../../arm-none-eabi/bin/real-ld.exe: C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/hse_host_flash.c:156: undefined reference to `FLASH_DRIVER_FLASH_SRC_END_ADDRESS'
c:/nxp/s32ds.3.4/s32ds/build_tools/gcc_v10.2/gcc-10.2-arm32-eabi/bin/../lib/gcc/arm-none-eabi/10.2.0/../../../../arm-none-eabi/bin/real-ld.exe: C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/hse_host_flash.c:156: undefined reference to `FLASH_DRIVER_RAM_DST_START_ADDRESS'
make: *** [makefile:55: Hse_Ip_AesEncAsyncIrq_S32K312.elf] Error 1
1 回复
690 次查看
Jason88619
I've encountered the same problem as yours. Could you please tell me how you solved it?
%3CLINGO-SUB%20id%3D%22lingo-sub-1784141%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EHSE%20%E4%BB%A3%E7%A0%81%E9%94%99%E8%AF%AF%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1784141%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CP%3E%20%20%20%E6%88%91%E4%B8%BA%20HSE%20%E5%88%9B%E5%BB%BA%E4%BA%86%E4%B8%80%E4%B8%AA%E5%8D%95%E7%8B%AC%E7%9A%84%E9%A1%B9%E7%9B%AE%EF%BC%8C%E5%9C%A8%E8%AF%A5%E9%A1%B9%E7%9B%AE%E4%B8%AD%EF%BC%8C%E6%88%91%E4%BB%8E%E7%A4%BA%E4%BE%8B%E4%BB%A3%E7%A0%81%E4%B8%AD%E6%B7%BB%E5%8A%A0%E4%BA%86%E6%9C%8D%E5%8A%A1%E3%80%81%E6%A1%86%E6%9E%B6%E5%92%8C%E6%8E%A5%E5%8F%A3%E6%96%87%E4%BB%B6%E5%A4%B9%EF%BC%8C%E4%BD%86%E5%8D%B4%E5%87%BA%E7%8E%B0%E4%BA%86%E4%B8%80%E4%BA%9B%E9%94%99%E8%AF%AF%EF%BC%8C%E6%88%91%E4%B8%8D%E6%96%AD%E5%9C%B0%E5%9C%A8%E6%BA%90%E4%BB%A3%E7%A0%81%E4%B8%AD%E6%B7%BB%E5%8A%A0%E7%9B%B8%E5%BA%94%E7%9A%84%E5%A4%B4%E6%96%87%E4%BB%B6%EF%BC%8C%E4%BD%86%E9%94%99%E8%AF%AF%E4%BE%9D%E7%84%B6%E5%AD%98%E5%9C%A8%EF%BC%8C%E6%97%A0%E6%B3%95%E6%B6%88%E9%99%A4%E3%80%82%E8%BF%99%E4%BA%9B%E9%94%99%E8%AF%AF%E4%BC%BC%E4%B9%8E%E4%B8%8E%E6%9F%90%E4%BA%9B%E8%AE%BE%E7%BD%AE%E6%9C%89%E5%85%B3%E3%80%82%E8%AF%B7%E6%9F%A5%E7%9C%8B%E5%B9%B6%E5%B8%AE%E5%8A%A9%E5%88%A0%E9%99%A4%E5%AE%83%E4%BB%AC%E3%80%82%3C%2FP%3E%3CP%3EC%3A%5CWork%5CProjects%5CCrypto_TS_T40D34M20I3R0%5Cexamples%5CS32DS%5CHse_Ip_AesEncAsyncIrq_S32K312%5CDebug_FLASH%20%2F..%2Fservices%2Fsrc%2Ffw_attribute%2Fnon-otp%2Fhse_get_capabilities.c%3A%2082%EF%BC%9A%E5%AF%B9%20%E2%80%9CgsrvResponse%E2%80%9D%20%E7%9A%84%E6%9C%AA%E5%AE%9A%E4%B9%89%E5%8F%82%E8%80%83%20C%3A%5CWork%5CProjects%5CCrypto_TS_T40D34M20I3R0%5Cexamples%5CS32DS%5CHse_Ip_AesEncAsyncIrq_S32K312%5CDebug_FLASH%20%2F...%20%3CBR%20%2F%3E%2Fservices%2Fsrc%2Ffw_attribute%2Fnon-otp%2Fhse_get_version.c%3A%20123%EF%BC%9A%E5%AF%B9%20%60ghseFWVersion'%20%E7%9A%84%E6%9C%AA%E5%AE%9A%E4%B9%89%E5%8F%82%E8%80%83%20C%3A%5CWork%5CProjects%5CCrypto_TS_T40D34M20I3R0%5Cexamples%5CS32DS%5CHse_Ip_AesEncAsyncIrq_S32K312%5CDebug_FLASH%20%2F...%20%3CBR%20%2F%3E%2Fservices%2Fsrc%2Ffw_attribute%2Fnon-otp%2Fhse_mu_config.c%3A%20129%EF%BC%9A%E5%AF%B9%20%E2%80%9CgsrvResponse%E2%80%9D%20%E7%9A%84%E6%9C%AA%E5%AE%9A%E4%B9%89%E5%8F%82%E8%80%83%20c%3A%20%2Fnxp%2Fs32ds.3.4%2Fs32ds%2Fbuild_tools%2Fgcc_v10.2%2Fgcc-10.2-Arm32-eabi%2Fbin%2F...%20%3CBR%20%2F%3E%2Flib%2Fgcc%2FArm-none-eabi%2F10.2.0%2F..%2F..%2F..%2F..%2F..%2F..%2F..%2FArm-none-eabi%2Fbin%2Freal-ld.exe%EF%BC%9AC%3A%5CWork%5CProjects%5CCrypto_TS_T40D34M20I3R0%5Cexamples%5CS32DS%5CHse_Ip_AesEncAsyncIrq_S32K312%5CDebug_FLASH%20%2F..%2Fservices%2Fsrc%2Ffw_attribute%2Fnon-otp%2Fhse_mu_config.c%3A%20129%EF%BC%9A%E5%AF%B9%20%E2%80%9Cwrite_attr%E2%80%9D%20%E7%9A%84%E6%9C%AA%E5%AE%9A%E4%B9%89%E5%8F%82%E8%80%83%20c%3A%20%2Fnxp%2Fs32ds.3.4%2Fs32ds%2Fbuild_tools%2Fgcc_v10.2%2Fgcc-10.2-Arm32-eabi%2Fbin%2F...%20%3CBR%20%2F%3E%2Flib%2Fgcc%2FArm-none-eabi%2F10.2.0%2F..%2F..%2F..%2F..%2F..%2F..%2F..%2FArm-none-eabi%2Fbin%2Freal-ld.exe%EF%BC%9AC%3A%5CWork%5CProjects%5CCrypto_TS_T40D34M20I3R0%5Cexamples%5CS32DS%5CHse_Ip_AesEncAsyncIrq_S32K312%5CDebug_FLASH%20%2F..%2Fservices%2Fsrc%2Ffw_attribute%2Fnon-otp%2Fhse_mu_config.c%3A%20129%EF%BC%9A%E5%AF%B9%20%E2%80%9CwriteMu1Config%E2%80%9D%20%E7%9A%84%E6%9C%AA%E5%AE%9A%E4%B9%89%E5%8F%82%E8%80%83%20c%3A%20%2Fnxp%2Fs32ds.3.4%2Fs32ds%2Fbuild_tools%2Fgcc_v10.2%2Fgcc-10.2-Arm32-eabi%2Fbin%2F...%20%3CBR%20%2F%3E%2Flib%2Fgcc%2FArm-none-eabi%2F10.2.0%2F..%2F..%2F..%2F..%2F..%2F..%2F..%2FArm-none-eabi%2Fbin%2Freal-ld.exe%EF%BC%9AC%3A%5CWork%5CProjects%5CCrypto_TS_T40D34M20I3R0%5Cexamples%5CS32DS%5CHse_Ip_AesEncAsyncIrq_S32K312%5CDebug_FLASH%20%2F..%2Fservices%2Fsrc%2Ffw_attribute%2Fnon-otp%2Fhse_mu_config.c%3A%20129%EF%BC%9A%E5%AF%B9%20%E2%80%9Creadmu1Config%E2%80%9D%20%E7%9A%84%E6%9C%AA%E5%AE%9A%E4%B9%89%E5%8F%82%E8%80%83%20C%3A%5CWork%5CProjects%5CCrypto_TS_T40D34M20I3R0%5Cexamples%5CS32DS%5CHse_Ip_AesEncAsyncIrq_S32K312%5CDebug_FLASH%20%2F...%20%3CBR%20%2F%3E%2Fservices%2Fsrc%2Ffw_attribute%2FOTP%2FHSE_advance_lc.c%3A%20157%EF%BC%9A%E5%AF%B9%20%E2%80%9CgsrvResponse%E2%80%9D%20%E7%9A%84%E6%9C%AA%E5%AE%9A%E4%B9%89%E5%8F%82%E8%80%83%20c%3A%20%2Fnxp%2Fs32ds.3.4%2Fs32ds%2Fbuild_tools%2Fgcc_v10.2%2Fgcc-10.2-Arm32-eabi%2Fbin%2F...%20%3CBR%20%2F%3E%2Flib%2Fgcc%2FArm-none-eabi%2F10.2.0%2F..%2F..%2F..%2F..%2F..%2F..%2F..%2FArm-none-eabi%2Fbin%2Freal-ld.exe%EF%BC%9AC%3A%5CWork%5CProjects%5CCrypto_TS_T40D34M20I3R0%5Cexamples%5CS32DS%5CHse_Ip_AesEncAsyncIrq_S32K312%5CDebug_FLASH%20%2F..%2Fservices%2Fsrc%2FFW_attribute%2FOTP%2FHSE_ADVANCE_LC.c%3A157%EF%BC%9A%E5%AF%B9%20%E2%80%9Cwrite_attr%E2%80%9D%20%E7%9A%84%E6%9C%AA%E5%AE%9A%E4%B9%89%E5%8F%82%E8%80%83%20C%3A%5CWork%5CProjects%5CCrypto_TS_T40D34M20I3R0%5Cexamples%5CS32DS%5CHse_Ip_AesEncAsyncIrq_S32K312%5CDebug_FLASH%20%2F...%20%3CBR%20%2F%3E%2Fservices%2Fsrc%2Ffw_attribute%2Fotp%2Fhse_boot_auth.c%3A%20153%EF%BC%9A%E5%AF%B9%20%60gsrvResponse'%E7%9A%84%E6%9C%AA%E5%AE%9A%E4%B9%89%E5%8F%82%E8%80%83%20c%3A%20%2Fnxp%2Fs32ds.3.4%2Fs32ds%2Fbuild_tools%2Fgcc_v10.2%2Fgcc-10.2-Arm32-eabi%2Fbin%2F...%20%3CBR%20%2F%3E%2Flib%2Fgcc%2Farm-none-eabi%2F10.2.0%2F..%2F..%2F..%2F..%2F..%2F..%2F..%2Farm-none-eabi%2Fbin%2Freal-ld.exe%EF%BC%9AC%3A%5CWork%5CProjects%5CCrypto_TS_T40D34M20I3R0%5Cexamples%5CS32DS%5CHse_Ip_AesEncAsyncIrq_S32K312%5CDebug_FLASH%20%2F..%2Fservices%2Fsrc%2Ffw_attribute%2Fotp%2Fhse_boot_auth.c%3A%20153%EF%BC%9A%E5%AF%B9%20%E2%80%9Cwrite_attr%E2%80%9D%20%E7%9A%84%E6%9C%AA%E5%AE%9A%E4%B9%89%E5%8F%82%E8%80%83%20C%3A%5CWork%5CProjects%5CCrypto_TS_T40D34M20I3R0%5Cexamples%5CS32DS%5CHse_Ip_AesEncAsyncIrq_S32K312%5CDebug_FLASH%20%2F...%20%3CBR%20%2F%3E%2Fservices%2Fsrc%2Ffw_attribute%2Fotp%2Fhse_debug_auth_mode.c%3A%20136%EF%BC%9A%E5%AF%B9%20%E2%80%9CgsrvResponse%E2%80%9D%20%E7%9A%84%E6%9C%AA%E5%AE%9A%E4%B9%89%E5%8F%82%E8%80%83%20c%3A%20%2Fnxp%2Fs32ds.3.4%2Fs32ds%2Fbuild_tools%2Fgcc_v10.2%2Fgcc-10.2-Arm-eabi%2Fbin%2F...%20%3CBR%20%2F%3E%2Flib%2Fgcc%2FArm-none-eabi%2F10.2.0%2F..%2F..%2F..%2F..%2F..%2F..%2F..%2FArm-none-eabi%2Fbin%2Freal-ld.exe%EF%BC%9AC%3A%5CWork%5CProjects%5CCrypto_TS_T40D34M20I3R0%5Cexamples%5CS32DS%5CHse_Ip_AesEncAsyncIrq_S32K312%5CDebug_FLASH%2F..%2Fservices%2Fsrc%2Ffw_attribute%2Fotp%2Fhse_debug_auth_mode.c%3A136%3A%20%E5%AF%B9%20%60write_attr%60%20%E7%9A%84%E6%9C%AA%E5%AE%9A%E4%B9%89%E5%8F%82%E8%80%83%3CBR%20%2F%3EC%3A%5CWork%5CProjects%5CCrypto_TS_T40D34M20I3R0%5Cexamples%5CS32DS%5CHse_Ip_AesEncAsyncIrq_S32K312%5CDebug_FLASH%2F..%2Fservices%2Fsrc%2Ffw_attribute%2Fotp%2Fhse_debug_key.c%3A299%3A%20%E5%AF%B9%20%60write_attr%60%20%E7%9A%84%E6%9C%AA%E5%AE%9A%E4%B9%89%E5%8F%82%E8%80%83%3CBR%20%2F%3Ec%3A%2Fnxp%2Fs32ds.3.4%2Fs32ds%2Fbuild_tools%2Fgcc_v10.2%2Fgcc-10.2-Arm32-eabi%2Fbin%2F..%2Flib%2Fgcc%2Farm-none-eabi%2F10.2.0%2F..%2F..%2F..%2F..%2Farm-none-eabi%2Fbin%2Freal-ld.exe%3AC%3A%5CWork%5CProjects%5CCrypto_TS_T40D34M20I3R0%5Cexamples%5CS32DS%5CHse_Ip_AesEncAsyncIrq_S32K312%5CDebug_FLASH%2F..%2Fservices%2Fsrc%2Ffw_attribute%2Fotp%2Fhse_debug_key.c%3A299%3A%20%E5%AF%B9%20%E2%80%9CgsrvResponse%E2%80%9D%20%E7%9A%84%E6%9C%AA%E5%AE%9A%E4%B9%89%E5%8F%82%E8%80%83%3CBR%20%2F%3Ec%3A%2Fnxp%2Fs32ds.3.4%2Fs32ds%2Fbuild_tools%2Fgcc_v10.2%2Fgcc-10.2-Arm32-eabi%2Fbin%2F..%2Flib%2Fgcc%2FArm-none-eabi%2F10.2.0%2F..%2F..%2F..%2F..%2FArm-none-eabi%2Fbin%2Freal-ld.exe%3A.%2Fservices%2Fsrc%2Ffw_attribute%2Fotp%2Fhse_extend_cust_security_policy.o%EF%BC%9A%E5%9C%A8%20%E2%80%9C%E6%89%A9%E5%B1%95%E5%AE%A2%E6%88%B7%E5%AE%89%E5%85%A8%E7%AD%96%E7%95%A5%E6%9C%8D%E5%8A%A1%E2%80%9D%20%E5%8A%9F%E8%83%BD%E4%B8%AD%EF%BC%9AC%3A%5CWork%5CProjects%5CCrypto_TS_T40D34M20I3R0%5Cexamples%5CS32DS%5CHse_Ip_AesEncAsyncIrq_S32K312%5CDebug_FLASH%20%2F...%20%3CBR%20%2F%3E%2Fservices%2Fsrc%2Ffw_attribute%2Fotp%2Fhse_extend_cust_security_policy.c%3A%20148%EF%BC%9A%E5%AF%B9%20%E2%80%9CgsrvResponse%E2%80%9D%20%E7%9A%84%E6%9C%AA%E5%AE%9A%E4%B9%89%E5%8F%82%E8%80%83%20c%3A%20%2Fnxp%2Fs32ds.3.4%2Fs32ds%2Fbuild_tools%2Fgcc_v10.2%2Fgcc-10.2-Arm32-eabi%2Fbin%2F...%20%3CBR%20%2F%3E%2Flib%2Fgcc%2Farm-none-eabi%2F10.2.0%2F..%2F..%2F..%2F..%2F..%2F..%2F..%2Farm-none-eabi%2Fbin%2Freal-ld.exe%EF%BC%9AC%3A%5CWork%5CProjects%5CCrypto_TS_T40D34M20I3R0%5Cexamples%5CS32DS%5CHse_Ip_AesEncAsyncIrq_S32K312%5CDebug_FLASH%20%2F..%2Fservices%2Fsrc%2Ffw_attribute%2Fotp%2Fhse_extend_cust_security_policy.c%3A%20148%EF%BC%9A%E5%AF%B9%20%E2%80%9Cwrite_attr%E2%80%9D%20%E7%9A%84%E6%9C%AA%E5%AE%9A%E4%B9%89%E5%8F%82%E8%80%83%20c%3A%20%2Fnxp%2Fs32ds.3.4%2Fs32ds%2Fbuild_tools%2Fgcc_v10.2%2Fgcc-10.2-Arm32-eabi%2Fbin%2F...%20%3CBR%20%2F%3E%2Flib%2Fgcc%2FArm-none-eabi%2F10.2.0%2F..%2F..%2F..%2F..%2F..%2F..%2F..%2FArm-none-eabi%2Fbin%2Freal-ld.exe%EF%BC%9AC%3A%5CWork%5CProjects%5CCrypto_TS_T40D34M20I3R0%5Cexamples%5CS32DS%5CHse_Ip_AesEncAsyncIrq_S32K312%5CDebug_FLASH%20%2F..%2Fservices%2Fsrc%2Ffw_attribute%2Fotp%2Fhse_extend_cust_security_policy.c%3A%20148%EF%BC%9A%E5%AF%B9%20%E2%80%9CgetStartasUserBit%E2%80%9D%20%E7%9A%84%E6%9C%AA%E5%AE%9A%E4%B9%89%E5%8F%82%E8%80%83%20c%3A%20%2Fnxp%2Fs32ds.3.4%2Fs32ds%2Fbuild_tools%2Fgcc_v10.2%2Fgcc-10.2-Arm32-eabi%2Fbin%2F...%20%3CBR%20%2F%3E%2Flib%2Fgcc%2FArm-none-eabi%2F10.2.0%2F..%2F..%2F..%2F..%2F..%2F..%2F..%2FArm-none-eabi%2Fbin%2Freal-ld.exe%EF%BC%9AC%3A%5CWork%5CProjects%5CCrypto_TS_T40D34M20I3R0%5Cexamples%5CS32DS%5CHse_Ip_AesEncAsyncIrq_S32K312%5CDebug_FLASH%2F..%2Fservices%2Fsrc%2Ffw_attribute%2Fotp%2Fhse_extend_cust_security_policy.c%3A148%3A%20%E5%AF%B9%20%E2%80%9CGetEnableAdkmBit%E2%80%9D%20%E7%9A%84%E6%9C%AA%E5%AE%9A%E4%B9%89%E5%8F%82%E8%80%83%3CBR%20%2F%3Ec%3A%2Fnxp%2Fs32ds.3.4%2Fs32ds%2Fbuild_tools%2Fgcc_v10.2%2Fgcc-10.2-Arm32-eabi%2Fbin%2F..%2Flib%2Fgcc%2FArm-none-eabi%2F10.2.0%2F..%2F..%2F..%2F..%2FArm-none-eabi%2Fbin%2Freal-ld.exe%3A%20.%2Fservices%2Fsrc%2Ffw_update%2Fstandard%2Fhse_fw_update.o%EF%BC%9A%E5%9C%A8%E5%87%BD%E6%95%B0%20%E2%80%9CFirmwareUpdateService%E2%80%9D%20%E4%B8%AD%EF%BC%9AC%3A%5CWork%5CProjects%5CCrypto_TS_T40D34M20I3R0%5Cexamples%5CS32DS%5CHse_Ip_AesEncAsyncIrq_S32K312%5CDebug_FLASH%20%2F...%20%3CBR%20%2F%3E%2Fservices%2Fsrc%2Ffw_update%2Fstandard%2Fhse_fw_update.c%3A%20402%EF%BC%9A%E5%AF%B9%20%E2%80%9CgsrvResponse%E2%80%9D%20%E7%9A%84%E6%9C%AA%E5%AE%9A%E4%B9%89%E5%8F%82%E8%80%83%20c%3A%20%2Fnxp%2Fs32ds.3.4%2Fs32ds%2Fbuild_tools%2Fgcc_v10.2%2Fgcc-10.2-Arm32-eabi%2Fbin%2F...%20%3CBR%20%2F%3E%2Flib%2Fgcc%2Farm-none-eabi%2F10.2.0%2F..%2F..%2F..%2F..%2F..%2F..%2F..%2Farm-none-eabi%2Fbin%2Freal-ld.exe%EF%BC%9AC%3A%5CWork%5CProjects%5CCrypto_TS_T40D34M20I3R0%5Cexamples%5CS32DS%5CHse_Ip_AesEncAsyncIrq_S32K312%5CDebug_FLASH%20%2F..%2Fservices%2Fsrc%2Ffw_update%2Fstandard%2Fhse_fw_update.c%3A%20402%EF%BC%9A%E5%AF%B9%20%E2%80%9Cfwudpate_only%E2%80%9D%20%E7%9A%84%E6%9C%AA%E5%AE%9A%E4%B9%89%E5%8F%82%E8%80%83%20c%3A%20%2Fnxp%2Fs32ds.3.4%2Fs32ds%2Fbuild_tools%2Fgcc_v10.2%2Fgcc-10.2-Arm32-eabi%2Fbin%2F...%20%3CBR%20%2F%3E%2Flib%2Fgcc%2Farm-none-eabi%2F10.2.0%2F..%2F..%2F..%2F..%2F..%2F..%2F..%2Farm-none-eabi%2Fbin%2Freal-ld.exe%EF%BC%9AC%3A%5CWork%5CProjects%5CCrypto_TS_T40D34M20I3R0%5Cexamples%5CS32DS%5CHse_Ip_AesEncAsyncIrq_S32K312%5CDebug_FLASH%20%2F..%2Fservices%2Fsrc%2Ffw_update%2Fstandard%2Fhse_fw_update.c%3A%20402%EF%BC%9A%E5%AF%B9%20%E2%80%9CActivatePassiveBlock%E2%80%9D%20%E7%9A%84%E6%9C%AA%E5%AE%9A%E4%B9%89%E5%8F%82%E8%80%83%20c%3A%20%2Fnxp%2Fs32ds.3.4%2Fs32ds%2Fbuild_tools%2Fgcc_v10.2%2Fgcc-10.2-Arm32-eabi%2Fbin%2F...%20%3CBR%20%2F%3E%2Flib%2Fgcc%2FArm-none-eabi%2F10.2.0%2F..%2F..%2F..%2F..%2F..%2F..%2F..%2FArm-none-eabi%2Fbin%2Freal-ld.exe%EF%BC%9AC%3A%5CWork%5CProjects%5CCrypto_TS_T40D34M20I3R0%5Cexamples%5CS32DS%5CHse_Ip_AesEncAsyncIrq_S32K312%5CDebug_FLASH%20%2F..%2Fservices%2Fsrc%2Ffw_update%2Fstandard%2Fhse_fw_update.c%3A%20402%EF%BC%9A%E5%AF%B9%20%60ghseFWVersion'%20%E7%9A%84%E6%9C%AA%E5%AE%9A%E4%B9%89%E5%8F%82%E8%80%83%20C%3A%5CWork%5CProjects%5CCrypto_TS_T40D34M20I3R0%5Cexamples%5CS32DS%5CHse_Ip_AesEncAsyncIrq_S32K312%5CDebug_FLASH%20%2F...%20%3CBR%20%2F%3E%2Fservices%2Fsrc%2Fhse_demo_app_config.c%3A%2027%EF%BC%9A%E5%AF%B9%20%E2%80%9CGProgramAttributes%E2%80%9D%20%E7%9A%84%E6%9C%AA%E5%AE%9A%E4%B9%89%E5%8F%82%E8%80%83%20c%3A%20%2Fnxp%2Fs32ds.3.4%2Fs32ds%2Fbuild_tools%2Fgcc_v10.2%2Fgcc-10.2-Arm32-eabi%2Fbin%2F...%20%3CBR%20%2F%3E%2Flib%2Fgcc%2Farm-none-eabi%2F10.2.0%2F..%2F..%2F..%2F..%2F..%2F..%2F..%2Farm-none-eabi%2Fbin%2Freal-ld.exe%EF%BC%9AC%3A%5CWork%5CProjects%5CCrypto_TS_T40D34M20I3R0%5Cexamples%5CS32DS%5CHse_Ip_AesEncAsyncIrq_S32K312%5CDebug_FLASH%2F..%2Fservices%2Fsrc%2Fhse_demo_app_config.c%3A27%3A%20%E5%AF%B9%20%60gsrvResponse%60%20%E7%9A%84%E6%9C%AA%E5%AE%9A%E4%B9%89%E5%8F%82%E8%80%83%3CBR%20%2F%3Ec%3A%2Fnxp%2Fs32ds.3.4%2Fs32ds%2Fbuild_tools%2Fgcc_v10.2%2Fgcc-10.2-Arm32-eabi%2Fbin%2F..%2Flib%2Fgcc%2FArm-none-eabi%2F10.2.0%2F..%2F..%2F..%2F..%2FArm-none-eabi%2Fbin%2Freal-ld.exe%3A.%2Fservices%2Fsrc%2Fhse_demo_app_config.o%3A%20in%20function%20%60CopyFlashToSRAMHseHost'%3A%3CBR%20%2F%3EC%3A%5CWork%5CProjects%5CCrypto_TS_T40D34M20I3R0%5Cexamples%5CS32DS%5CHse_Ip_AesEncAsyncIrq_S32K312%5CDebug_FLASH%2F..%2Fservices%2Fsrc%2Fhse_demo_app_config.c%3A75%3A%20undefined%20%E5%8F%82%E8%80%83%20to%20%60HSE_HOST_FLASH_SRC_START_ADDR'%3CBR%20%2F%3Ec%3A%2Fnxp%2Fs32ds.3.4%2Fs32ds%2Fbuild_tools%2Fgcc_v10.2%2Fgcc-10.2-Arm32-eabi%2Fbin%2F..%2Flib%2Fgcc%2Farm-none-eabi%2F10.2.0%2F..%2F..%2F..%2F..%2Farm-none-eabi%2Fbin%2Freal-ld.exe%3AC%3A%5CWork%5CProjects%5CCrypto_TS_T40D34M20I3R0%5Cexamples%5CS32DS%5CHse_Ip_AesEncAsyncIrq_S32K312%5CDebug_FLASH%2F..%2Fservices%2Fsrc%2Fhse_demo_app_config.c%3A75%3A%20%E5%AF%B9%20%60HSE_HOST_FLASH_SRC_END_ADDR'%E7%9A%84%E6%9C%AA%E5%AE%9A%E4%B9%89%E5%8F%82%E8%80%83%3CBR%20%2F%3Ec%3A%2Fnxp%2Fs32ds.3.4%2Fs32ds%2Fbuild_tools%2Fgcc_v10.2%2Fgcc-10.2-Arm32-eabi%2Fbin%2F..%2Flib%2Fgcc%2FArm-none-eabi%2F10.2.0%2F..%2F..%2F..%2F..%2FArm-none-eabi%2Fbin%2Freal-ld.exe%3A%20C%3A%5CWork%5CProjects%5CCrypto_TS_T40D34M20I3R0%5Cexamples%5CS32DS%5CHse_Ip_AesEncAsyncIrq_S32K312%5CDebug_FLASH%2F..%2Fservices%2Fsrc%2Fhse_demo_app_config.c%3A75%3A%20%E5%AF%B9%20%60HSE_HOST_RAM_DST_START_ADDR'%E7%9A%84%E6%9C%AA%E5%AE%9A%E4%B9%89%E5%8F%82%E8%80%83%3CBR%20%2F%3Ec%3A%2Fnxp%2Fs32ds.3.4%2Fs32ds%2Fbuild_tools%2Fgcc_v10.2%2Fgcc-10.2-Arm32-eabi%2Fbin%2F..%2Flib%2Fgcc%2Farm-none-eabi%2F10.2.0%2F..%2F..%2F..%2F..%2Farm-none-eabi%2Fbin%2Freal-ld.exe%3A.%2Fservices%2Fsrc%2Fhse_demo_app_config.o%3A%20%E5%9C%A8%E5%87%BD%E6%95%B0%20%60attributeProgrammingService'%20%E4%B8%AD%EF%BC%9A%3CBR%20%2F%3EC%3A%5CWork%5CProjects%5CCrypto_TS_T40D34M20I3R0%5Cexamples%5CS32DS%5CHse_Ip_AesEncAsyncIrq_S32K312%5CDebug_FLASH%2F..%2Fservices%2Fsrc%2Fhse_demo_app_config.c%3A172%3A%20%E5%AF%B9%20%60gEnableIVTAuthBit'%20%E7%9A%84%E6%9C%AA%E5%AE%9A%E4%B9%89%E5%8F%82%E8%80%83%3CBR%20%2F%3Ec%3A%2Fnxp%2Fs32ds.3.4%2Fs32ds%2Fbuild_tools%2Fgcc_v10.2%2Fgcc-10.2-Arm32-eabi%2Fbin%2F..%2Flib%2Fgcc%2FArm-none-eabi%2F10.2.0%2F..%2F..%2F..%2F..%2FArm-none-eabi%2Fbin%2Freal-ld.exe%3A.%2Fservices%2Fsrc%2Fhse_host_flash.o%3A%20%E5%9C%A8%E5%87%BD%E6%95%B0%20%60HostFlash_Init'%20%E4%B8%AD%EF%BC%9A%3CBR%20%2F%3EC%3A%5CWork%5CProjects%5CCrypto_TS_T40D34M20I3R0%5Cexamples%5CS32DS%5CHse_Ip_AesEncAsyncIrq_S32K312%5CDebug_FLASH%2F..%2Fservices%2Fsrc%2Fhse_host_flash.c%3A156%3A%20%E5%AF%B9%20%60FLASH_DRIVER_FLASH_SRC_START_ADDRESS'%20%E7%9A%84%E6%9C%AA%E5%AE%9A%E4%B9%89%E5%8F%82%E8%80%83%3CBR%20%2F%3Ec%3A%2Fnxp%2Fs32ds.3.4%2Fs32ds%2Fbuild_tools%2Fgcc_v10.2%2Fgcc-10.2-Arm32-eabi%2Fbin%2F..%2Flib%2Fgcc%2Farm-none-eabi%2F10.2.0%2F..%2F..%2F..%2F..%2Farm-none-eabi%2Fbin%2Freal-ld.exe%3AC%3A%5CWork%5CProjects%5CCrypto_TS_T40D34M20I3R0%5Cexamples%5CS32DS%5CHse_Ip_AesEncAsyncIrq_S32K312%5CDebug_FLASH%20%2F..%2Fservices%2Fsrc%2Fhse_host_flash.c%3A%20156%EF%BC%9A%E5%AF%B9%20%E2%80%9CFLASH_DRIVER_FLASH_SRC_END_ADDRESS%E2%80%9D%20%E7%9A%84%E6%9C%AA%E5%AE%9A%E4%B9%89%E5%8F%82%E8%80%83%20c%3A%20%2Fnxp%2Fs32ds.3.4%2Fs32ds%2Fbuild_tools%2Fgcc_v10.2%2Fgcc-10.2-Arm32-eabi%2Fbin%2F...%20%3CBR%20%2F%3E%2Flib%2Fgcc%2FArm-none-eabi%2F10.2.0%2F..%2F..%2F..%2F..%2F..%2F..%2F..%2FArm-none-eabi%2Fbin%2Freal-ld.exe%EF%BC%9AC%3A%5CWork%5CProjects%5CCrypto_TS_T40D34M20I3R0%5Cexamples%5CS32DS%5CHse_Ip_AesEncAsyncIrq_S32K312%5CDebug_FLASH%20%2F..%2Fservices%2Fsrc%2Fhse_host_flash.c%3A%20156%EF%BC%9A%E5%AF%B9%20%E2%80%9CFLASH_DRIVER_RAM_DST_START_ADDRESS%E2%80%9D%20%E7%9A%84%E6%9C%AA%E5%AE%9A%E4%B9%89%E5%8F%82%E8%80%83%20make%3A%20***%20%5Bmakefile%3A%2055%3A%20hse_ip_aesencasyncirq_s32K312.elf%5D%20%3CBR%20%2F%3E%E9%94%99%E8%AF%AF%201%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2250716%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20code%20errors%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2250716%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3E%E6%88%91%E9%81%87%E5%88%B0%E4%BA%86%E5%92%8C%E4%BD%A0%E4%B8%80%E6%A0%B7%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%E8%AF%B7%E5%91%8A%E8%AF%89%E6%88%91%E6%82%A8%E6%98%AF%E5%A6%82%E4%BD%95%E8%A7%A3%E5%86%B3%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E7%9A%84%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
