HSE Firmware Update
HSE Firmware Update
HaiHoangSoftware
Dear NXP team,
Currently, We are referring to HSE_DEMOAPP_S32K396_0_2_50_0 to see how to update new HSE firmware (AB SWAP to AB SWAP FW update).
The first step is that programs IVT and Encrypted HSE F/w V2 Image in Active Partition as below picture (mentioned in HSE_DEMOAPP_S32K396_0_2_50_0_ReadMe.pdf).
In the Demo App, this step was done by TRACE32 script.
But in our project, we need to get new Encrypted HSE F/w V2 Image from tester tool via UDS CAN, then perform writing this image into Active Partition in this step.
Please help us verify if we can perform programming Encrypted HSE F/w V2 Image into Active Partition(PFLASH BLOCK0 or PFLASH BLOCK1) while SW is executing in Active Partition(PFLASH BLOCK 0) by Mem43 Flash Driver?
Thank you and best regards,
Hai Nguyen Hoang
lukaszadrapa
Hi @HaiHoangSoftware
Generally speaking, read-while-write (RWW) is supported between blocks. So, when a block is being programmed or erased, this block cannot be accessed and the code must run from another block or from RAM.
Mem_43_INFLS driver provides a feature which can load access code to RAM memory in order to avoid RWW issues. For details, see section "3.6.3 Avoiding Read While Write" in user manual RTD_MEM_43_INFLS_UM.pdf. If this feature is enabled, you can program/erase the same block where the code is running from.
But if you want to keep interrupts enabled during the flash operations, it's better to avoid this situation - if your application is running from block 1 then load new pink file to block 0 and there will be no problem.
Lukas
lukaszadrapa
Lukas
HaiHoangSoftware
It's clear for now.
Thanks for your support.
Hai Nguyen Hoang.
%3CLINGO-SUB%20id%3D%22lingo-sub-2187356%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EHSE%20Firmware%20Update%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2187356%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EDear%20NXP%20team%2C%3C%2FP%3E%3CP%3ECurrently%2C%20We%20are%20referring%20to%26nbsp%3BHSE_DEMOAPP_S32K396_0_2_50_0%20to%20see%20how%20to%20update%20new%20HSE%20firmware%20(AB%20SWAP%20to%20AB%20SWAP%20FW%20update).%3C%2FP%3E%3CP%3EThe%20first%20step%20is%20that%20programs%20IVT%20and%20%3CFONT%20color%3D%22%23FF00FF%22%3E%3CSTRONG%3EEncrypted%20HSE%20F%2Fw%20V2%20Image%3C%2FSTRONG%3E%3C%2FFONT%3E%20in%20%3CFONT%20color%3D%22%2399CC00%22%3E%3CSTRONG%3EActive%20Partition%3C%2FSTRONG%3E%3C%2FFONT%3E%20as%20below%20picture%20(mentioned%20in%20HSE_DEMOAPP_S32K396_0_2_50_0_ReadMe.pdf).%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22HaiHoangSoftware_0-1760603654989.png%22%20style%3D%22width%3A%20614px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22HaiHoangSoftware_0-1760603654989.png%22%20style%3D%22width%3A%20614px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F361126iAE9C040D73B88DDE%2Fimage-dimensions%2F614x431%3Fv%3Dv2%22%20width%3D%22614%22%20height%3D%22431%22%20role%3D%22button%22%20title%3D%22HaiHoangSoftware_0-1760603654989.png%22%20alt%3D%22HaiHoangSoftware_0-1760603654989.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EIn%20the%20Demo%20App%2C%20this%20step%20was%20done%20by%20TRACE32%20script.%3C%2FP%3E%3CP%3EBut%20in%20our%20project%2C%20we%20need%20to%20get%20new%20%3CFONT%20color%3D%22%23FF00FF%22%3E%3CSTRONG%3EEncrypted%20HSE%20F%2Fw%20V2%20Image%3C%2FSTRONG%3E%3C%2FFONT%3E%20from%20tester%20tool%20via%20UDS%20CAN%2C%20then%20perform%20writing%20this%20image%20into%20%3CFONT%20color%3D%22%2399CC00%22%3E%3CSTRONG%3EActive%20Partition%3C%2FSTRONG%3E%3C%2FFONT%3E%20in%20this%20step.%3C%2FP%3E%3CP%3EPlease%20help%20us%20verify%20if%20we%20can%20perform%20programming%26nbsp%3B%3CFONT%20color%3D%22%23FF00FF%22%3E%3CSTRONG%3EEncrypted%20HSE%20F%2Fw%20V2%20Image%20%3C%2FSTRONG%3E%3CFONT%20color%3D%22%23000000%22%3Einto%20%3CSTRONG%3E%3CFONT%20color%3D%22%2399CC00%22%3EA%3C%2FFONT%3E%3C%2FSTRONG%3E%3C%2FFONT%3E%3CFONT%20color%3D%22%23000000%22%3E%3CSTRONG%3E%3CFONT%20color%3D%22%2399CC00%22%3Ective%20Partition%3C%2FFONT%3E%3C%2FSTRONG%3E(PFLASH%20BLOCK0%20or%20PFLASH%20BLOCK1)%20while%20SW%20is%20executing%20in%20%3CFONT%20color%3D%22%2399CC00%22%3E%3CSTRONG%3EActive%20Partition%3C%2FSTRONG%3E%3C%2FFONT%3E(PFLASH%20BLOCK%200)%20by%20Mem43%20Flash%20Driver%3F%3C%2FFONT%3E%3C%2FFONT%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CFONT%20color%3D%22%23FF00FF%22%3E%3CFONT%20color%3D%22%23000000%22%3EThank%20you%20and%20best%20regards%2C%3C%2FFONT%3E%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20color%3D%22%23FF00FF%22%3E%3CFONT%20color%3D%22%23000000%22%3EHai%20Nguyen%20Hoang%3C%2FFONT%3E%3C%2FFONT%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2187938%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20Firmware%20Update%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2187938%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EHi%2C%3CBR%20%2F%3E%3CBR%20%2F%3EIt's%20clear%20for%20now.%3CBR%20%2F%3EThanks%20for%20your%20support.%3CBR%20%2F%3E%3CBR%20%2F%3ERegards%2C%3CBR%20%2F%3EHai%20Nguyen%20Hoang.%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2187709%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20Firmware%20Update%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2187709%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F247218%22%20target%3D%22_blank%22%3E%40HaiHoangSoftware%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EGenerally%20speaking%2C%20read-while-write%20(RWW)%20is%20supported%20between%20blocks.%20So%2C%20when%20a%20block%20is%20being%20programmed%20or%20erased%2C%20this%20block%20cannot%20be%20accessed%20and%20the%20code%20must%20run%20from%20another%20block%20or%20from%20RAM.%3C%2FP%3E%0A%3CP%3EMem_43_INFLS%20driver%20provides%20a%20feature%20which%20can%20load%20access%20code%20to%20RAM%20memory%20in%20order%20to%20avoid%20RWW%20issues.%20For%20details%2C%20see%20section%20%223.6.3%20Avoiding%20Read%20While%20Write%22%20in%20user%20manual%20RTD_MEM_43_INFLS_UM.pdf.%20If%20this%20feature%20is%20enabled%2C%20you%20can%20program%2Ferase%20the%20same%20block%20where%20the%20code%20is%20running%20from.%20%3CBR%20%2F%3EBut%20if%20you%20want%20to%20keep%20interrupts%20enabled%20during%20the%20flash%20operations%2C%20it's%20better%20to%20avoid%20this%20situation%20-%20if%20your%20application%20is%20running%20from%20block%201%20then%20load%20new%20pink%20file%20to%20block%200%20and%20there%20will%20be%20no%20problem.%3C%2FP%3E%0A%3CP%3ERegards%2C%3CBR%20%2F%3ELukas%3C%2FP%3E%3C%2FLINGO-BODY%3E
