Getting wrong value of cell 14 and stack voltage when using FRDM33771B and S32k144
2,545 次查看
Shobha
I have interfaced mc33771 with S32K144 and used 7 cells. I have done the cell tapping as per the given connection in datasheet given for cells less than 14. I'm getting wrong value of cell 14 and total stack voltage. I am not able to get why is this happening. Also I'm getting FAULT1 and FAULT3 as yes. How can I know what's this fault is for? I've attached the snip below
It would be great if you can help me with this.
Thanks in advance!
5 回复数
2,307 次查看
Gad_usr1
Hi, were you able to solve this issue?
2,499 次查看
guoweisun
HI
Please install 14 cells for this HW/SW,if less than 14 cells the hardware also need update.
2,493 次查看
Shobha
Hey
Can you pl elaborate on how to install 14 cells for this HW/SW, if less than 14 cells.
2,480 次查看
guoweisun
You can down AN12536 for getting more information.
2,476 次查看
Shobha
Yes I've already downloaded AN12536 and done the connection of 7 cells as per the Type A wiring shown. Below is the attached connection that I've followed.
