Get header file paths for certain c file in IAR NXP compiler
1,371 次查看
kerdany
I'm compiling a c file from CMD using NXP compiler and adding to the command include directories with -I flag, is there a way to print out the paths of headers files that where used for compiling?
1,312 次查看
kerdany
I figured it out, you add --dependencies flag to command
1,313 次查看
kerdany
