GHS Multi debugger - Not resuming after Microcontroller POR
1,243 次查看
Lokesh_0109
Hi, I'm using GHS multi debugger with Renasas E1 debugger. whenever microcontroller power is turned off and turned on back the debugger window is stuck. I need it to be resumed for debugging purpose. please provide a solution for this. is this possible to do so without flashing the software again to resume the session.
1,202 次查看
petervlna
I'm using Renesas RH850 - RH850/C1M-A2
Since you are not using NXP product I will answer only generally.
I am not sure what you mean by the sentence above. The GIU is stuck or you debugger is not attached to running target after POR?
After POR you need to attach debugger to micro to put it in debug mode again.
You can do such using debugger scripts, on some advanced debuggers.
Also for third party products, please get in touch directly with product manufacturer support.
Peter
1,229 次查看
danielmartynek
Hi @Lokesh_0109,
Please specify the MCU part,
Thank you
1,214 次查看
Lokesh_0109
Hi @danielmartynek,
Thank you
%3CLINGO-SUB%20id%3D%22lingo-sub-2135780%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EGHS%20%E5%A4%9A%E8%B7%AF%E8%B0%83%E8%AF%95%E5%99%A8%20-%20%E5%BE%AE%E6%8E%A7%E5%88%B6%E5%99%A8%20POR%20%E4%B9%8B%E5%90%8E%E6%97%A0%E6%B3%95%E6%81%A2%E5%A4%8D%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2135780%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%20GHS%20%E5%A4%9A%E8%B0%83%E8%AF%95%E5%99%A8%E5%92%8C%20Renasas%20E1%20%E8%B0%83%E8%AF%95%E5%99%A8%E3%80%82%E6%AF%8F%E5%BD%93%E5%85%B3%E9%97%AD%E5%BE%AE%E6%8E%A7%E5%88%B6%E5%99%A8%E7%94%B5%E6%BA%90%E5%B9%B6%E9%87%8D%E6%96%B0%E6%89%93%E5%BC%80%E6%97%B6%EF%BC%8C%E8%B0%83%E8%AF%95%E5%99%A8%E7%AA%97%E5%8F%A3%E9%83%BD%E4%BC%9A%E5%8D%A1%E4%BD%8F%E3%80%82%E6%88%91%E9%9C%80%E8%A6%81%E6%81%A2%E5%A4%8D%E8%B0%83%E8%AF%95%E3%80%82%E8%AF%B7%E6%8F%90%E4%BE%9B%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%E3%80%82%E6%98%AF%E5%90%A6%E5%8F%AF%E4%BB%A5%E5%9C%A8%E4%B8%8D%E9%87%8D%E6%96%B0%E5%88%B7%E6%96%B0%E8%BD%AF%E4%BB%B6%E7%9A%84%E6%83%85%E5%86%B5%E4%B8%8B%E6%81%A2%E5%A4%8D%E4%BC%9A%E8%AF%9D%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2136211%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20GHS%20Multi%20debugger%20-%20Not%20resuming%20after%20Microcontroller%20POR%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2136211%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F160001%22%20target%3D%22_blank%22%3E%40danielmartynek%3C%2FA%3E%EF%BC%8C%3CBR%20%2F%3E%3CBR%20%2F%3E%EF%BC%8C%E6%88%91%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%20Renesas%20RH850%20-%20RH850%2FC1M-A2%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E8%B0%A2%E8%B0%A2%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2135874%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20GHS%20Multi%20debugger%20-%20Not%20resuming%20after%20Microcontroller%20POR%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2135874%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F252805%22%20target%3D%22_blank%22%3E%40Lokesh_0109%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E8%AF%B7%E6%B3%A8%E6%98%8E%20MCU%20%E9%83%A8%E4%BB%B6%E3%80%81%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E8%B0%A2%E8%B0%A2%3C%2FP%3E%3C%2FLINGO-BODY%3E
